It’s also when i use the original sources!
Info: [ Disk Avail:26.35 GB ]
Info: NV_L4T_OPENCV_TARGET_POST_INSTALL_COMP include 5 package
Info: [ Package PreInstall Started ]
Info: current working directory is /home/lihuawei/nvidia/nvidia_sdk/JetPack_4.3_Linux_P3310
Info: exec_command [target]:
#!/bin/bash
set -e
function safe_apt_install {
echo “*begin $1, $2”
tmp_log=/tmp/jetpack_dpkg_log.txt
sudo rm -f $tmp_log
set +e; $1 2>&1 | tee $tmp_log; CMD_STATUS=${PIPESTATUS[0]}; set -e
while [ ${CMD_STATUS} -ne 0 ]; do
if grep -q -e “is locked by another process” -e “E: Could not get lock /var/lib” $tmp_log; then
sudo rm -f $tmp_log
echo “Waiting $2 seconds for apt to be available”; sleep ${2}
else
echo “Unhandled error when running $1”; exit 1
fi
done
export LC_ALL=en_US.UTF-8 LANG=en_US.UTF-8 LANGUAGE=en_US.UTF-8
safe_apt_install “sudo apt-get update” 5
safe_apt_install “sudo apt-get install -y libtbb2 libtbb-dev” 5
safe_apt_install “sudo apt-get install -y python-dev python-numpy python-py python-pytest” 5
Info: exec_command: scp -q -o UserKnownHostsFile=/dev/null -o StrictHostKeyChecking=no /tmp/tmp_NV_L4T_OPENCV_TARGET_POST_INSTALL_COMP.sh li@192.168.55.1:~; ssh -t -q -o UserKnownHostsFile=/dev/null -o StrictHostKeyChecking=no li@192.168.55.1 “~/tmp_NV_L4T_OPENCV_TARGET_POST_INSTALL_COMP.sh && rm -f ~/tmp_NV_L4T_OPENCV_TARGET_POST_INSTALL_COMP.sh”
*begin sudo apt-get update, 5
[sudo] password for li:
Get:1 file:/var/cuda-repo-10-0-local-10.0.326 InRelease
Ign:1 file:/var/cuda-repo-10-0-local-10.0.326 InRelease
Get:2 file:/var/cuda-repo-10-0-local-10.0.326 Release [574 B]
Hit:4 Index of /ubuntu bionic InRelease
Get:5 Index of /ubuntu bionic InRelease [242 kB]
Hit:8 Index of /ubuntu-ports bionic-security InRelease
Hit:10 Index of /ubuntu-ports bionic InRelease
Hit:9 https://repo.download.nvidia.cn/jetson/common r32 InRelease
Get:11 https://repo.download.nvidia.cn/jetson/t186 r32 InRelease [2,554 B]
Get:12 https://repo.download.nvidia.cn/jetson/t186 r32/main arm64 Packages [7,930 B]
Err:12 https://repo.download.nvidia.cn/jetson/t186 r32/main arm64 Packages
File has unexpected size (8084 != 7930). Mirror sync in progress? [IP: 36.156.21.81 443]
Hashes of expected file:
Filesize:7930 [weak]
SHA256:a80383566cab2ea7baa68c7c17ac6f581b7ec47d376d832c1824d2fd1ab8916e
SHA1:268b9c78b441a358f804dab1b1c67c7c91ffbad7 [weak]
MD5Sum:6d1e8cb93e0f23410eecfd8007d2e4df [weak]
Release file created at: Tue, 17 Dec 2019 23:52:06 +0000
Get:6 Index of /ubuntu bionic-updates InRelease [88.7 kB]
Get:7 Index of /ubuntu bionic-backports InRelease [74.6 kB]
Get:13 Index of /ubuntu bionic/main arm64 Packages [975 kB]
Ign:13 Index of /ubuntu bionic/main arm64 Packages
Ign:44 Index of /ubuntu bionic/restricted arm64 Packages
Ign:45 Index of /ubuntu bionic/universe arm64 Packages
Ign:46 Index of /ubuntu bionic/multiverse arm64 Packages
Ign:47 Index of /ubuntu bionic-updates/main arm64 Packages
Ign:48 Index of /ubuntu bionic-updates/restricted arm64 Packages
Ign:49 Index of /ubuntu bionic-updates/universe arm64 Packages
Ign:50 Index of /ubuntu bionic-updates/multiverse arm64 Packages
Ign:51 Index of /ubuntu bionic-backports/main arm64 Packages
Ign:52 Index of /ubuntu bionic-backports/universe arm64 Packages
Get:53 Index of /ubuntu bionic-backports/universe Translation-en [1,900 B]
Get:54 Index of /ubuntu bionic-backports/universe arm64 DEP-11 Metadata [8,284 B]
Get:55 Index of /ubuntu bionic-backports/universe DEP-11 48x48 Icons [29 B]
Get:56 Index of /ubuntu bionic-backports/universe DEP-11 64x64 Icons [29 B]
Err:13 Index of /ubuntu bionic/main arm64 Packages
404 Not Found [IP: 91.189.91.14 80]
Err:47 Index of /ubuntu bionic-updates/main arm64 Packages
Err:51 Index of /ubuntu bionic-backports/main arm64 Packages
Fetched 408 kB in 12s (34.5 kB/s)
Reading package lists…
E: Failed to fetch https://repo.download.nvidia.cn/jetson/t186/dists/r32/main/binary-arm64/Packages.gz File has unexpected size (8084 != 7930). Mirror sync in progress? [IP: 36.156.21.81 443]
- Filesize:7930 [weak]
- SHA256:a80383566cab2ea7baa68c7c17ac6f581b7ec47d376d832c1824d2fd1ab8916e
- SHA1:268b9c78b441a358f804dab1b1c67c7c91ffbad7 [weak]
- MD5Sum:6d1e8cb93e0f23410eecfd8007d2e4df [weak]
E: Failed to fetch http://cn.archive.ubuntu.com/ubuntu/dists/bionic/main/binary-arm64/Packages 404 Not Found [IP: 91.189.91.14 80]
E: Failed to fetch http://cn.archive.ubuntu.com/ubuntu/dists/bionic-updates/main/binary-arm64/Packages 404 Not Found [IP: 91.189.91.14 80]
E: Failed to fetch http://cn.archive.ubuntu.com/ubuntu/dists/bionic-backports/main/binary-arm64/Packages 404 Not Found [IP: 91.189.91.14 80]
E: Some index files failed to download. They have been ignored, or old ones used instead.
Unhandled error when running sudo apt-get update
Info: [ Package PreInstall Finished with Error ]
Info: [ 36.00 KB used. Disk Avail: 26.35 GB ]
Info: [ NV_L4T_OPENCV_TARGET_POST_INSTALL_COMP Install took 29s ]
Error: Run commands failed at step PreInstall: command scp -q -o UserKnownHostsFile=/dev/null -o StrictHostKeyChecking=no /tmp/tmp_NV_L4T_OPENCV_TARGET_POST_INSTALL_COMP.sh li@192.168.55.1:~; ssh -t -q -o UserKnownHostsFile=/dev/null -o StrictHostKeyChecking=no li@192.168.55.1 “~/tmp_NV_L4T_OPENCV_TARGET_POST_INSTALL_COMP.sh && rm -f ~/tmp_NV_L4T_OPENCV_TARGET_POST_INSTALL_COMP.sh” finished with error
