could you share the while media pipeline? could you share the metadata content? do you want to show the metadata content on GUI? please refer to \opt\nvidia\deepstream\deepstream-6.4\sources\apps\sample_apps\deepstream-image-meta-test\deepstream_image_meta_test.c, which will use nvds_add_display_meta_to_frame to show some information on the frames.
could you share the whole media pipeline? In DeepSteram, nvdsosd is used to draw bboxes or other information on the frames and nvsegvisual is used to draw segmenattion. what do you mean about “GUI to render”? you can use nvds_add_user_meta_to_obj add information for objects.
nvdsmetainsert is opensoure. it will call low-level lib to add more meta. please refer to low-level sample \opt\nvidia\deepstream\deepstream-6.4\sources\gst-plugins\gst-nvdsmetautils\sei_serialization\sei_serialization.cpp.
I’m using modified version of rtspin-rtspout example in python examples I’m using my jetson as a server for the analytics and want to read the metadata at client device for the rtsp server on the jetson
seems you want to get meta data at the client side, RTSP protocol is used to transmit video and audio. encoding plugin nvv4l2h264enc does not support add other information to encoded video data. please refer to this topic for Attaching CustomMeta as SEI data in H264
yes, We do not have library for Jetson.
there is another solution. After encoder NAL unit that comes out of encoder, create SEI NAL unit with custom metadata and attach it before NAL unit of encoder.
There is no ready-made sample on Jetson DeepStream. encoder plugin will output
encoded stream, which is NAL unit. you can attach SEI NAL before NAL unit.
