I made some minor changes in my jetson nano board and i want to change my operating system according to it . What should i do? what is the procedure for that.
kayccc
March 10, 2021, 7:14am
2
Hi @nainakashyap888 ,
Here, the examples of custom image for Jetson Nano using Xubuntu, it may helps you too
Hello All!!
This is a custom image I have created for the Jetson Nano. ( Download link at the bottom. )
Built from the ground up using debootstrap, this image is based on a minimal Xubuntu-core / Xfce4 installation for a snappy desktop experience and a lighter weight alternative to the L4T Ubuntu image. This image is only 3.5 Gigabytes.
INSTRUCTIONS
(Please note: Your device must be rebooted at least once before all the drivers will be loaded correctly. The first boot is a good time to creat…
There is already a retropie installation script for the nano I saw on one of the githubs I tested it out and it seemed to work well, although I did have to modify it slightly when I was testing it on ubuntu 19.10.
Do a Google search for retropie Jetson nano and it should come up
