I want to flash ssd instalation in my jetson orin nano dev kit, but somehow i got stuck in this error that shows up in sdk manager
03:53:48 SUMMARY: CUDA on Host - host: Install completed successfully.
03:53:48 SUMMARY: CUDA Cross Compile Package on Host - host: Install completed successfully.
03:53:48 SUMMARY: NvSci - host: Install completed successfully.
03:53:48 SUMMARY: VPI on Host - host: Install completed successfully.
03:53:48 SUMMARY: Nsight Systems - host: Install completed successfully.
03:53:48 SUMMARY: Nsight Graphics - host: Install completed successfully.
03:53:48 SUMMARY: Nsight Perf SDK - host: Install completed successfully.
03:53:52 ERROR: File System and OS - target_image: Download 'File System and OS' failure
03:53:52 ERROR: File System and OS - target_image: download failed
04:17:11 SUMMARY: VPI on Host - host: Install completed successfully.
04:17:11 SUMMARY: Nsight Systems - host: Install completed successfully.
04:17:11 SUMMARY: Nsight Graphics - host: Install completed successfully.
04:22:14 SUMMARY: DateTime Target Setup - target: Depends on failed component
04:38:10 SUMMARY: NvSci - host: Install completed successfully.
04:38:10 SUMMARY: Nsight Perf SDK - host: Install completed successfully.
04:39:10 ERROR: Flash Jetson Linux - flash: [   0.0108 ] ERROR: failed to read rcm_state
04:39:33 ERROR: Flash Jetson Linux - flash: [   0.0110 ] ERROR: failed to read rcm_state
04:41:00 ERROR: Flash Jetson Linux - flash: [   0.0117 ] ERROR: failed to read rcm_state
04:41:44 ERROR: Flash Jetson Linux - flash: [   0.4162 ] ERROR: might be timeout in USB write.
04:41:44 SUMMARY: Flash Jetson Linux - flash: Installation failed.
04:41:44 SUMMARY: Gstreamer - target: Depends on failed component
04:41:44 SUMMARY: DLA Compiler - target: Depends on failed component
04:41:44 SUMMARY: DateTime Target Setup - target: Depends on failed component
04:55:20 SUMMARY: CUDA on Host - host: Install completed successfully.
04:55:20 SUMMARY: CUDA Cross Compile Package on Host - host: Install completed successfully.
04:55:20 SUMMARY: NvSci - host: Install completed successfully.
04:55:20 SUMMARY: VPI on Host - host: Install completed successfully.
04:55:20 SUMMARY: Nsight Systems - host: Install completed successfully.
04:55:20 SUMMARY: Nsight Graphics - host: Install completed successfully.
04:55:20 SUMMARY: Nsight Perf SDK - host: Install completed successfully.
04:55:20 SUMMARY: Drivers for Jetson - target_image: Install completed successfully.
04:55:20 SUMMARY: File System and OS - target_image: Install completed successfully.
04:55:42 ERROR: [   0.0109 ] ERROR: failed to read rcm_state
04:55:52 ERROR: [   0.1208 ] ERROR: might be timeout in USB write.
04:55:52 ERROR: Error: Return value 3
04:55:52 ERROR: --- Error: Reading board information failed.
04:55:52 ERROR: Bootrom status check failed.
04:56:44 ERROR: [   0.0112 ] ERROR: failed to read rcm_state
04:57:02 ERROR: Flash Jetson Linux - flash: [   0.0109 ] ERROR: failed to read rcm_state
04:57:23 ERROR: Flash Jetson Linux - flash: [   0.0130 ] ERROR: failed to read rcm_state
04:57:46 ERROR: Flash Jetson Linux - flash: [   0.0118 ] ERROR: failed to read rcm_state
04:59:20 ERROR: Flash Jetson Linux - flash: [   0.0148 ] ERROR: failed to read rcm_state
05:00:06 ERROR: Flash Jetson Linux - flash: [   0.4209 ] ERROR: might be timeout in USB write.
05:00:06 ERROR: Flash Jetson Linux - flash: Error: Return value 3
05:00:06 ERROR: Flash Jetson Linux - flash: [exec_command]: /bin/bash -c /home/stephany/.nvsdkm/replays/scripts/JetPack_6.2_Linux/NV_L4T_FLASH_JETSON_LINUX_COMP.sh; [error]: rpcbind: another rpcbind is already running. Aborting
05:00:06 ERROR: Flash Jetson Linux - flash: command error code: 11
05:00:06 ERROR: Flash Jetson Linux - flash: command terminated with error
05:00:06 SUMMARY: Flash Jetson Linux - flash: Installation failed.
05:00:06 SUMMARY: Gstreamer - target: Depends on failed component
05:00:06 SUMMARY: DLA Compiler - target: Depends on failed component
05:00:06 SUMMARY: DateTime Target Setup - target: Depends on failed component
is there any solution?
The Jetson Orin Nano series is a part of the NVIDIA Jetson Orin family, which includes the Jetson Orin NX series and the Jetson AGX Orin series. The Jetson Orin Nano series is designed to provide a compact and power-efficient solution for various applications such as AI, robotics, and IoT.
The Jetson Orin Nano series modules are available in different configurations, including 4GB and 8GB versions. These modules are designed to be used with a carrier board, which provides the necessary interfaces and connectors for the module.
In terms of thermal design, the Jetson Orin Nano series modules have a shutdown temperature of 105°C, which is the maximum junction temperature that the module can operate at. The module also has hardware shutdown mechanisms that enforce this limit by automatically halting the system when this temperature is exceeded.
For power management, the Jetson Orin Nano series modules require a power supply of 5.0V to 20V, with a nominal voltage of 5.0V. The module is not hot-pluggable, and the main power supply must be disconnected and adequate time allowed for the various power rails to fully discharge before installing or removing the module.
The Jetson Orin Nano series modules also support various interfaces such as PCIe, USB, and HDMI, and are designed to work with the Jetson Linux operating system.
In comparison to the Jetson Orin NX series, the Jetson Orin Nano series is more compact and power-efficient, making it suitable for applications where space and power consumption are limited. However, the Jetson Orin NX series provides more features and interfaces, such as support for more cameras and displays, making it suitable for more complex applications.
In summary, the Jetson Orin Nano series provides a compact and power-efficient solution for various applications, with a range of features and interfaces, and is designed to work with the Jetson Linux operating system.
Here are some key specifications of the Jetson Orin Nano series:
  • Module type: Jetson Orin Nano
  • Memory: 4GB or 8GB
  • Shutdown temperature: 105°C
  • Power supply: 5.0V to 20V, nominal 5.0V
  • Interfaces: PCIe, USB, HDMI
  • Operating system: Jetson Linux
  • Applications: AI, robotics, IoT, and more
Note: The information provided is based on the context and may not be comprehensive or up-to-date. For more detailed and accurate information, please refer to the official NVIDIA documentation and specifications.
Please make sure the device whether in recovery mode.
hi, it’s already in recovery mode, but still same problem is
[ 3.5589 ] Added binary blob_eks_t234_sigheader.img.encrypt of size 9232
[ 3.5675 ] Sending membct and RCM blob
[ 3.5681 ] tegrarcm_v2 --chip 0x23 0 --pollbl --download bct_mem mem_rcm_sigheader.bct.encrypt --download blob blob.bin
[ 3.5684 ] BL: version 1.4.0.4-t234-54845784-e89ea9bc last_boot_error: 0
[ 3.5909 ] Sending bct_mem
[ 3.6201 ] Sending blob
[ 3.6634 ] ERROR: might be timeout in USB write.
Command tegrarcm_v2 --chip 0x23 0 --pollbl --download bct_mem mem_rcm_sigheader.bct.encrypt --download blob blob.bin
Failed flashing generic.
~$ lsusb | grep -i nvidia
Bus 003 Device 008: ID 0955:7523 NVIDIA Corp. APX
pls help me, what should i do next, i’m new here and not have idea what’s wrong
want to clarify that what is the environment of host PC you are using there?
I am using Ubuntu 22.04.3 LTS (Jammy) on my host PC
sudo ./flash.sh jetson-orin-nano-devkit-nvme internal
L4T BSP Information:
R36 , REVISION: 4.2
User release: 0.0
ECID is 0x80012344705DE7801C00000007010040
Target Board Information:
Name: jetson-orin-nano-devkit-nvme, Board Family: generic, SoC: Tegra 234,
OpMode: production, Boot Authentication: NS,
Disk encryption: disabled ,
copying device_config(/home/stephany/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_8GB_DEVKIT/Linux_for_Tegra/bootloader/generic/BCT/tegra234-mb1-bct-device-p3767-0000.dts)… done.
copying misc_config(/home/stephany/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_8GB_DEVKIT/Linux_for_Tegra/bootloader/generic/BCT/tegra234-mb1-bct-misc-p3767-0000.dts)… done.
copying emc_fuse_dev_params(/home/stephany/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_8GB_DEVKIT/Linux_for_Tegra/bootloader/generic/BCT/tegra234-br-bct-diag-boot.dts)… done.
Existing emcfuse(/home/stephany/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_8GB_DEVKIT/Linux_for_Tegra/bootloader/fuse_t234.xml) reused.
./tegraflash.py --chip “0x23” --applet “/home/stephany/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_8GB_DEVKIT/Linux_for_Tegra/bootloader/mb1_t234_prod.bin” --skipuid --cfg readinfo_t234_min_prod.xml --dev_params tegra234-br-bct-diag-boot.dts --device_config tegra234-mb1-bct-device-p3767-0000.dts --misc_config tegra234-mb1-bct-misc-p3767-0000.dts --bins “mb2_applet applet_t234.bin” --cmd “readfuses fuse_t234.bin fuse_t234.xml; dump eeprom cvm cvm.bin; dump try_custinfo custinfo_out.bin; reboot recovery”
Welcome to Tegra Flash
version 1.0.0
Type ? or help for help and q or quit to exit
Use ! to execute system commands
[   0.0094 ] Reading fuses
[   0.0100 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[   0.0103 ] File rcm_state open failed
[   0.0106 ] ERROR: failed to read rcm_state
[   0.0106 ]
[   0.0110 ] tegrasign_v3.py --key None --getmode mode.txt
[   0.0111 ] Assuming zero filled SBK key
[   0.0108 ] Pre-processing config: tegra234-mb1-bct-device-p3767-0000.dts
[   0.0163 ] Pre-processing config: tegra234-mb1-bct-misc-p3767-0000.dts
[   0.0238 ] Parsing partition layout
[   0.0242 ] tegraparser_v2 --pt readinfo_t234_min_prod.xml.tmp
[   0.0254 ] Kernel DTB used: None
[   0.0254 ] WARNING: dce base dtb is not provided
[   0.0254 ] Parsing partition layout
[   0.0257 ] tegraparser_v2 --pt readinfo_t234_min_prod.xml.tmp
[   0.0262 ] Creating list of images to be signed
[   0.0265 ] tegrahost_v2 --chip 0x23 0 --partitionlayout readinfo_t234_min_prod.xml.bin --list images_list.xml zerosbk
[   0.0269 ] MB1: Nvheader already present is mb1_t234_prod_aligned.bin
[   0.0278 ] Header already present for mb1_t234_prod_aligned_sigheader.bin
[   0.0281 ] MB1: Nvheader already present is mb1_t234_prod_aligned.bin
[   0.0316 ] Header already present for mb1_t234_prod_aligned_sigheader.bin
[   0.0330 ] MB1: Nvheader already present is psc_bl1_t234_prod_aligned.bin
[   0.0354 ] Header already present for psc_bl1_t234_prod_aligned_sigheader.bin
[   0.0357 ] adding BCH for mb2_t234_aligned.bin
[   0.0370 ] MB1: Nvheader already present is psc_bl1_t234_prod_aligned.bin
[   0.0439 ] Header already present for psc_bl1_t234_prod_aligned_sigheader.bin
[   0.0442 ] adding BCH for mb2_t234_aligned.bin
[   0.0520 ] Filling MB1 storage info
[   0.0520 ] Parsing dev params for multi chains
[   0.0579 ] Generating br-bct
[   0.0583 ] Updating dev and MSS params in BR BCT
[   0.0583 ] tegrabct_v2 --dev_param tegra234-br-bct-diag-boot_cpp.dtb --brbct br_bct.cfg --chip 0x23 0
[   0.0589 ] Updating bl info
[   0.0592 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updateblinfo readinfo_t234_min_prod.xml.bin
[   0.0595 ] WARNING: boot chain is not completed. set to 0
[   0.0617 ] Generating signatures
[   0.0622 ] tegrasign_v3.py --key None --list images_list.xml --pubkeyhash pub_key.key --sha sha512
[   0.0623 ] Assuming zero filled SBK key
[   0.0699 ] Warning: pub_key.key is not found
[   0.0697 ] Parsing dev params for multi chains
[   0.0697 ] Generating br-bct
[   0.0699 ] Updating dev and MSS params in BR BCT
[   0.0699 ] tegrabct_v2 --dev_param tegra234-br-bct-diag-boot_cpp.dtb --brbct br_bct.cfg --chip 0x23 0
[   0.0704 ] Updating bl info
[   0.0706 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updateblinfo readinfo_t234_min_prod.xml.bin --updatesig images_list_signed.xml
[   0.0708 ] WARNING: boot chain is not completed. set to 0
[   0.0756 ] Generating SHA2 Hash
[   0.0769 ] Sha saved in br_bct_BR.sha
[   0.0766 ] Get Signed section of bct
[   0.0768 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --listbct bct_list.xml
[   0.0775 ] Signing BCT
[   0.0779 ] tegrasign_v3.py --key None --list bct_list.xml --pubkeyhash pub_key.key --sha sha512
[   0.0780 ] Assuming zero filled SBK key
[   0.0795 ] Sha saved in br_bct_BR.sha
[   0.0796 ] Warning: pub_key.key is not found
[   0.0792 ] Updating BCT with signature
[   0.0794 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updatesig bct_list_signed.xml
[   0.0796 ] Offset :4608 Len :3584
[   0.0805 ] Generating SHA2 Hash
[   0.0810 ] tegrasign_v3.py --key None --list bct_list.xml --sha sha512
[   0.0811 ] Assuming zero filled SBK key
[   0.0832 ] Sha saved in br_bct_BR.sha
[   0.0831 ] Updating BCT with SHA2 Hash
[   0.0835 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updatesha bct_list_signed.xml
[   0.0839 ] Offset :4608 Len :3584
[   0.0844 ] Offset :68 Len :8124
[   0.0857 ] Generating coldboot mb1-bct
[   0.0863 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_cold_boot_bct.cfg --misc tegra234-mb1-bct-misc-p3767-0000_cpp.dtb --device tegra234-mb1-bct-device-p3767-0000_cpp.dtb
[   0.0868 ] MB1-BCT version: 0.13
[   0.0902 ] Parsing config file :tegra234-mb1-bct-device-p3767-0000_cpp.dtb
[   0.0904 ] Added Platform Config 9 data with size :- 100
[   0.0904 ]
[   0.0904 ] Updating mb1-bct with firmware information
[   0.0908 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_cold_boot_bct_MB1.bct --updatefwinfo readinfo_t234_min_prod.xml.bin
[   0.0932 ] tegrahost_v2 --chip 0x23 0 --align mb1_cold_boot_bct_MB1_aligned.bct
[   0.0936 ] Generating SHA2 Hash for mb1bct
[   0.0949 ] Sha saved in mb1_cold_boot_bct_MB1_aligned.sha
[   0.0958 ] Sha saved in mb1_cold_boot_bct_MB1.sha
[   0.0957 ] tegrahost_v2 --chip 0x23 0 --magicid MBCT --appendsigheader mb1_cold_boot_bct_MB1_aligned.bct zerosbk
[   0.0960 ] adding BCH for mb1_cold_boot_bct_MB1_aligned.bct
[   0.0977 ] tegrasign_v3.py --key None --list mb1_cold_boot_bct_MB1_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[   0.0980 ] Assuming zero filled SBK key
[   0.0999 ] Warning: pub_key.key is not found
[   0.0999 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mb1_cold_boot_bct_MB1_aligned_sigheader.bct.encrypt mb1_cold_boot_bct_MB1_aligned_sigheader.bct.hash zerosbk
[   0.1010 ] Generating recovery mb1-bct
[   0.1014 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_bct.cfg --misc tegra234-mb1-bct-misc-p3767-0000_cpp.dtb --device tegra234-mb1-bct-device-p3767-0000_cpp.dtb
[   0.1017 ] MB1-BCT version: 0.13
[   0.1045 ] Parsing config file :tegra234-mb1-bct-device-p3767-0000_cpp.dtb
[   0.1048 ] Added Platform Config 9 data with size :- 100
[   0.1048 ]
[   0.1048 ] Updating mb1-bct with firmware information
[   0.1054 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_bct_MB1.bct --recov --updatefwinfo readinfo_t234_min_prod.xml.bin
[   0.1087 ] tegrahost_v2 --chip 0x23 0 --align mb1_bct_MB1_aligned.bct
[   0.1094 ] Generating SHA2 Hash for mb1bct
[   0.1115 ] Sha saved in mb1_bct_MB1_aligned.sha
[   0.1129 ] Sha saved in mb1_bct_MB1.sha
[   0.1129 ] tegrahost_v2 --chip 0x23 0 --magicid MBCT --appendsigheader mb1_bct_MB1_aligned.bct zerosbk
[   0.1132 ] adding BCH for mb1_bct_MB1_aligned.bct
[   0.1151 ] tegrasign_v3.py --key None --list mb1_bct_MB1_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[   0.1153 ] Assuming zero filled SBK key
[   0.1177 ] Warning: pub_key.key is not found
[   0.1181 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mb1_bct_MB1_aligned_sigheader.bct.encrypt mb1_bct_MB1_aligned_sigheader.bct.hash zerosbk
[   0.1194 ] Info: Skip generating mem_bct because sdram_config is not defined
[   0.1195 ] Info: Skip generating mem_bct because sdram_config is not defined
[   0.1195 ] Copying signatures
[   0.1200 ] tegrahost_v2 --chip 0x23 0 --partitionlayout readinfo_t234_min_prod.xml.bin --updatesig images_list_signed.xml
[   0.1280 ] mb1_t234_prod_aligned_sigheader.bin.encrypt filename is from images_list
[   0.1283 ] psc_bl1_t234_prod_aligned_sigheader.bin.encrypt filename is from images_list
[   0.1283 ] Boot Rom communication
[   0.1289 ] tegrarcm_v2 --new_session --chip 0x23 0 --uid --download bct_br br_bct_BR.bct --download mb1 mb1_t234_prod_aligned_sigheader.bin.encrypt --download psc_bl1 psc_bl1_t234_prod_aligned_sigheader.bin.encrypt --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt
[   0.1293 ] BR_CID: 0x80012344705DE7801C00000007010040
[   0.1542 ] Sending bct_br
[   0.1835 ] Sending mb1
[   0.1849 ] Sending psc_bl1
[   0.2010 ] Sending bct_mb1
[   0.2096 ] Boot Rom communication completed
[   0.2119 ] tegrahost_v2 --chip 0x23 0 --align applet_t234_aligned.bin
[   0.2139 ] tegrahost_v2 --chip 0x23 0 --magicid MB2A --appendsigheader applet_t234_aligned.bin zerosbk
[   0.2148 ] adding BCH for applet_t234_aligned.bin
[   0.2249 ] tegrasign_v3.py --key None --list applet_t234_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key --sha sha512
[   0.2250 ] Assuming zero filled SBK key
[   0.2266 ] Warning: pub_key.key is not found
[   0.2266 ] tegrahost_v2 --chip 0x23 0 --updatesigheader applet_t234_aligned_sigheader.bin.encrypt applet_t234_aligned_sigheader.bin.hash zerosbk
[   0.2282 ] Sending mb2_applet…
[   0.2285 ] tegrarcm_v2 --chip 0x23 0 --pollbl --download applet applet_t234_sigheader.bin.encrypt
[   0.2287 ] BL: version 1.4.0.4-t234-54845784-e89ea9bc last_boot_error: 0
[   0.4338 ] Sending applet
[   0.5375 ] completed
[   0.5392 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[   0.5404 ] MB2 Applet version 01.00.0000
[   0.7274 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[   0.7287 ] MB2 Applet version 01.00.0000
[   0.7557 ] Parsing fuse info as per xml file
[   0.7570 ] tegraparser_v2 --chip 0x23 0 --get_fuse_names fuse_t234.xml read_fuse_names.txt
[   0.7580 ] MagicId=0x45535546 version=0x2
[   0.7586 ] trying to read fuse with MB2 Applet
[   0.7598 ] tegraparser_v2 --chip 0x23 0 --read_fusetype PublicKeyHash read_fuse.bin
[   0.7618 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[   0.7627 ] MB2 Applet version 01.00.0000
[   0.8205 ] Saved read fuses in file __fuse_read_scatter.bin
[   0.8276 ] Fuse read successful
[   0.8302 ] tegraparser_v2 --chip 0x23 0 --read_fusetype PkcPubkeyHash1 read_fuse.bin
[   0.8331 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[   0.8341 ] MB2 Applet version 01.00.0000
[   0.8597 ] Saved read fuses in file __fuse_read_scatter.bin
[   0.8661 ] Fuse read successful
[   0.8684 ] tegraparser_v2 --chip 0x23 0 --read_fusetype PkcPubkeyHash2 read_fuse.bin
[   0.8710 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[   0.8717 ] MB2 Applet version 01.00.0000
[   0.8980 ] Saved read fuses in file __fuse_read_scatter.bin
[   0.9047 ] Fuse read successful
[   0.9064 ] tegraparser_v2 --chip 0x23 0 --read_fusetype BootSecurityInfo read_fuse.bin
[   0.9085 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[   0.9090 ] MB2 Applet version 01.00.0000
[   0.9365 ] Saved read fuses in file __fuse_read_scatter.bin
[   0.9435 ] Fuse read successful
[   0.9457 ] tegraparser_v2 --chip 0x23 0 --read_fusetype ArmJtagDisable read_fuse.bin
[   0.9484 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[   0.9491 ] MB2 Applet version 01.00.0000
[   1.0079 ] Saved read fuses in file __fuse_read_scatter.bin
[   1.0141 ] Fuse read successful
[   1.0161 ] tegraparser_v2 --chip 0x23 0 --read_fusetype SecurityMode read_fuse.bin
[   1.0181 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[   1.0187 ] MB2 Applet version 01.00.0000
[   1.0458 ] Saved read fuses in file __fuse_read_scatter.bin
[   1.0532 ] Fuse read successful
[   1.0555 ] tegraparser_v2 --chip 0x23 0 --read_fusetype SwReserved read_fuse.bin
[   1.0585 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[   1.0592 ] MB2 Applet version 01.00.0000
[   1.1162 ] Saved read fuses in file __fuse_read_scatter.bin
[   1.1231 ] Fuse read successful
[   1.1251 ] tegraparser_v2 --chip 0x23 0 --read_fusetype DebugAuthentication read_fuse.bin
[   1.1273 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[   1.1279 ] MB2 Applet version 01.00.0000
[   1.1554 ] Saved read fuses in file __fuse_read_scatter.bin
[   1.1616 ] Fuse read successful
[   1.1642 ] tegraparser_v2 --chip 0x23 0 --read_fusetype OdmInfo read_fuse.bin
[   1.1666 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[   1.1672 ] MB2 Applet version 01.00.0000
[   1.1940 ] Saved read fuses in file __fuse_read_scatter.bin
[   1.2003 ] Fuse read successful
[   1.2025 ] tegraparser_v2 --chip 0x23 0 --read_fusetype OdmId read_fuse.bin
[   1.2049 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[   1.2059 ] MB2 Applet version 01.00.0000
[   1.2334 ] Saved read fuses in file __fuse_read_scatter.bin
[   1.2398 ] Fuse read successful
[   1.2417 ] tegraparser_v2 --chip 0x23 0 --read_fusetype OdmLock read_fuse.bin
[   1.2436 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[   1.2441 ] MB2 Applet version 01.00.0000
[   1.2710 ] Saved read fuses in file __fuse_read_scatter.bin
[   1.2770 ] Fuse read successful
[   1.2791 ] tegraparser_v2 --chip 0x23 0 --read_fusetype ReservedOdm0 read_fuse.bin
[   1.2821 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[   1.2831 ] MB2 Applet version 01.00.0000
[   1.3401 ] Saved read fuses in file __fuse_read_scatter.bin
[   1.3468 ] Fuse read successful
[   1.3487 ] tegraparser_v2 --chip 0x23 0 --read_fusetype ReservedOdm1 read_fuse.bin
[   1.3508 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[   1.3514 ] MB2 Applet version 01.00.0000
[   1.3781 ] Saved read fuses in file __fuse_read_scatter.bin
[   1.3847 ] Fuse read successful
[   1.3867 ] tegraparser_v2 --chip 0x23 0 --read_fusetype ReservedOdm2 read_fuse.bin
[   1.3890 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[   1.3896 ] MB2 Applet version 01.00.0000
[   1.4464 ] Saved read fuses in file __fuse_read_scatter.bin
[   1.4528 ] Fuse read successful
[   1.4555 ] tegraparser_v2 --chip 0x23 0 --read_fusetype ReservedOdm3 read_fuse.bin
[   1.4582 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[   1.4590 ] MB2 Applet version 01.00.0000
[   1.4845 ] Saved read fuses in file __fuse_read_scatter.bin
[   1.4908 ] Fuse read successful
[   1.4943 ] tegraparser_v2 --chip 0x23 0 --read_fusetype ReservedOdm4 read_fuse.bin
[   1.4971 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[   1.4980 ] MB2 Applet version 01.00.0000
[   1.5237 ] Saved read fuses in file __fuse_read_scatter.bin
[   1.5298 ] Fuse read successful
[   1.5322 ] tegraparser_v2 --chip 0x23 0 --read_fusetype ReservedOdm5 read_fuse.bin
[   1.5353 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[   1.5361 ] MB2 Applet version 01.00.0000
[   1.5915 ] Saved read fuses in file __fuse_read_scatter.bin
[   1.5977 ] Fuse read successful
[   1.6000 ] tegraparser_v2 --chip 0x23 0 --read_fusetype ReservedOdm6 read_fuse.bin
[   1.6025 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[   1.6032 ] MB2 Applet version 01.00.0000
[   1.6591 ] Saved read fuses in file __fuse_read_scatter.bin
[   1.6655 ] Fuse read successful
[   1.6682 ] tegraparser_v2 --chip 0x23 0 --read_fusetype ReservedOdm7 read_fuse.bin
[   1.6704 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[   1.6711 ] MB2 Applet version 01.00.0000
[   1.7254 ] Saved read fuses in file __fuse_read_scatter.bin
[   1.7326 ] Fuse read successful
[   1.7347 ] tegraparser_v2 --chip 0x23 0 --read_fusetype Sku read_fuse.bin
[   1.7367 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[   1.7374 ] MB2 Applet version 01.00.0000
[   1.7633 ] Saved read fuses in file __fuse_read_scatter.bin
[   1.7697 ] Fuse read successful
[   1.7720 ] tegraparser_v2 --chip 0x23 0 --read_fusetype Uid read_fuse.bin
[   1.7743 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[   1.7749 ] MB2 Applet version 01.00.0000
[   1.8299 ] Saved read fuses in file __fuse_read_scatter.bin
[   1.8376 ] Fuse read successful
[   1.8396 ] tegraparser_v2 --chip 0x23 0 --read_fusetype OptEmcDisable read_fuse.bin
[   1.8421 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[   1.8428 ] MB2 Applet version 01.00.0000
[   1.8684 ] Saved read fuses in file __fuse_read_scatter.bin
[   1.8748 ] Fuse read successful
[   1.8779 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[   1.8787 ] MB2 Applet version 01.00.0000
[   1.9060 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[   1.9068 ] MB2 Applet version 01.00.0000
[   1.9420 ] Retrieving board information
[   1.9429 ] tegrarcm_v2 --chip 0x23 0 --oem platformdetails chip chip_info.bin
[   1.9436 ] MB2 Applet version 01.00.0000
[   1.9765 ] Saved platform info in chip_info.bin
[   1.9823 ] Chip minor revision: 1
[   1.9826 ] Bootrom revision: 0x7
[   1.9828 ] Ram code: 0x2
[   1.9830 ] Chip sku: 0xd5
[   1.9834 ] Chip Sample: prod
[   1.9834 ]
[   1.9839 ] Retrieving EEPROM data
[   1.9840 ] tegrarcm_v2 --oem platformdetails eeprom cvm /home/stephany/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_8GB_DEVKIT/Linux_for_Tegra/bootloader/cvm.bin --chip 0x23 0
[   1.9852 ] MB2 Applet version 01.00.0000
[   2.0112 ] Saved platform info in /home/stephany/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_8GB_DEVKIT/Linux_for_Tegra/bootloader/cvm.bin
[   2.0473 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[   2.0484 ] MB2 Applet version 01.00.0000
[   2.0762 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[   2.0772 ] MB2 Applet version 01.00.0000
[   2.1107 ] Dumping customer Info
[   2.1120 ] tegrarcm_v2 --chip 0x23 0 --oem dump bct tmp.bct
[   2.1129 ] MB2 Applet version 01.00.0000
[   2.1448 ] Saved bct in tmp.bct
[   2.1686 ] tegrabct_v2 --brbct tmp.bct --chip 0x23 0 --custinfo /home/stephany/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_8GB_DEVKIT/Linux_for_Tegra/bootloader/custinfo_out.bin
[   2.1699 ] Customer data s[   2.1710 ] aved in /home/stephany/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_8GB_DEVKIT/Linux_for_Tegra/bootloader/custinfo_out.bin successfully
[   2.1711 ] Rebooting to recovery mode
[   2.1719 ] tegrarcm_v2 --chip 0x23 0 --ismb2
[   2.2001 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[   2.2007 ] MB2 Applet version 01.00.0000
[   2.2335 ] Booting to recovery mode
[   2.2346 ] tegrarcm_v2 --chip 0x23 0 --reboot recovery
[   2.2355 ] MB2 Applet version 01.00.0000
Board ID(3767) version(300) sku(0003) revision(R.1)
Preset RAMCODE is 2
Chip SKU(00:00:00:D5) ramcode(2) fuselevel(fuselevel_production) board_FAB(300)
emc_opt_disable_fuse:(0)
Copy /home/stephany/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_8GB_DEVKIT/Linux_for_Tegra/kernel/dtb/tegra234-p3768-0000+p3767-0003-nv.dtb to /home/stephany/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_8GB_DEVKIT/Linux_for_Tegra/kernel/dtb/tegra234-p3768-0000+p3767-0003-nv.dtb.rec
Generated UUID 55d1e956-9e1c-4631-9513-7f43aef4a75d for mounting root APP partition.
copying bctfile(/home/stephany/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_8GB_DEVKIT/Linux_for_Tegra/bootloader/generic/BCT/tegra234-p3767-0001-sdram-l4t.dts)… done.
copying minratchet_config(/home/stephany/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_8GB_DEVKIT/Linux_for_Tegra/bootloader/generic/BCT/tegra234-mb1-bct-ratchet-p3767-0000.dts)… done.
copying pinmux_config(/home/stephany/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_8GB_DEVKIT/Linux_for_Tegra/bootloader/generic/BCT/tegra234-mb1-bct-pinmux-p3767-dp-a03.dtsi)… done.
copying gpioint_config(/home/stephany/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_8GB_DEVKIT/Linux_for_Tegra/bootloader/generic/BCT/tegra234-mb1-bct-gpioint-p3767-0000.dts)… done.
copying pmic_config(/home/stephany/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_8GB_DEVKIT/Linux_for_Tegra/bootloader/generic/BCT/tegra234-mb1-bct-pmic-p3767-0000-a02.dts)… done.
copying pmc_config(/home/stephany/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_8GB_DEVKIT/Linux_for_Tegra/bootloader/generic/BCT/tegra234-mb1-bct-padvoltage-p3767-dp-a03.dtsi)… done.
copying deviceprod_config(/home/stephany/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_8GB_DEVKIT/Linux_for_Tegra/bootloader/generic/BCT/tegra234-mb1-bct-cprod-p3767-0000.dts)… done.
copying prod_config(/home/stephany/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_8GB_DEVKIT/Linux_for_Tegra/bootloader/generic/BCT/tegra234-mb1-bct-prod-p3767-0000.dts)… done.
copying scr_config(/home/stephany/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_8GB_DEVKIT/Linux_for_Tegra/bootloader/generic/BCT/tegra234-mb2-bct-scr-p3767-0000.dts)… done.
copying wb0sdram(/home/stephany/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_8GB_DEVKIT/Linux_for_Tegra/bootloader/generic/BCT/tegra234-p3767-0001-wb0sdram-l4t.dts)… done.
copying bootrom_config(/home/stephany/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_8GB_DEVKIT/Linux_for_Tegra/bootloader/generic/BCT/tegra234-mb1-bct-reset-p3767-0000.dts)… done.
Existing uphylane_config(/home/stephany/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_8GB_DEVKIT/Linux_for_Tegra/bootloader/tegra234-mb1-bct-uphylane-si.dtsi) reused.
copying dev_params(/home/stephany/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_8GB_DEVKIT/Linux_for_Tegra/bootloader/generic/BCT/tegra234-br-bct-p3767-0000-l4t.dts)… done.
copying dev_params_b(/home/stephany/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_8GB_DEVKIT/Linux_for_Tegra/bootloader/generic/BCT/tegra234-br-bct_b-p3767-0000-l4t.dts)… done.
copying mb2bct_cfg(/home/stephany/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_8GB_DEVKIT/Linux_for_Tegra/bootloader/generic/BCT/tegra234-mb2-bct-misc-p3767-0000.dts)… done.
Existing pscfwfile(/home/stephany/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_8GB_DEVKIT/Linux_for_Tegra/bootloader/pscfw_t234_prod.bin) reused.
Existing pscbl1file(/home/stephany/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_8GB_DEVKIT/Linux_for_Tegra/bootloader/psc_bl1_t234_prod.bin) reused.
Existing mtsmcefile(/home/stephany/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_8GB_DEVKIT/Linux_for_Tegra/bootloader/mce_flash_o10_cr_prod.bin) reused.
Existing tscfwfile(/home/stephany/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_8GB_DEVKIT/Linux_for_Tegra/bootloader/tsec_t234.bin) reused.
Existing mb2applet(/home/stephany/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_8GB_DEVKIT/Linux_for_Tegra/bootloader/applet_t234.bin) reused.
Existing bootloader(/home/stephany/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_8GB_DEVKIT/Linux_for_Tegra/bootloader/mb2_t234.bin) reused.
copying initrd(/home/stephany/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_8GB_DEVKIT/Linux_for_Tegra/bootloader/l4t_initrd.img)… done.
bl is uefi
Making Boot image… done.
Not signing of boot.img
Making recovery ramdisk for recovery image…
Re-generating recovery ramdisk for recovery image…
/home/stephany/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_8GB_DEVKIT/Linux_for_Tegra/bootloader/ramdisk_tmp /home/stephany/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_8GB_DEVKIT/Linux_for_Tegra/bootloader /home/stephany/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_8GB_DEVKIT/Linux_for_Tegra
72720 blocks
gzip: /home/stephany/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_8GB_DEVKIT/Linux_for_Tegra/kernel/Image: not in gzip format
_BASE_KERNEL_VERSION=5.15.148-tegra
96293 blocks
Making Recovery image…
copying recdtbfile(/home/stephany/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_8GB_DEVKIT/Linux_for_Tegra/kernel/dtb/tegra234-p3768-0000+p3767-0003-nv.dtb.rec)… done.
20+0 records in
20+0 records out
20 bytes copied, 0,00015195 s, 132 kB/s
Existing sosfile(/home/stephany/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_8GB_DEVKIT/Linux_for_Tegra/bootloader/mb1_t234_prod.bin) reused.
Existing tegraboot(/home/stephany/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_8GB_DEVKIT/Linux_for_Tegra/bootloader/mb2_t234.bin) reused.
Existing cpu_bootloader(/home/stephany/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_8GB_DEVKIT/Linux_for_Tegra/bootloader/mb2_t234.bin) reused.
Existing mb2blfile(/home/stephany/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_8GB_DEVKIT/Linux_for_Tegra/bootloader/mb2_t234.bin) reused.
Existing xusbfile(/home/stephany/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_8GB_DEVKIT/Linux_for_Tegra/bootloader/xusb_t234_prod.bin) reused.
Existing pvafile(/home/stephany/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_8GB_DEVKIT/Linux_for_Tegra/bootloader/nvpva_020.fw) reused.
Existing dcefile(/home/stephany/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_8GB_DEVKIT/Linux_for_Tegra/bootloader/display-t234-dce.bin) reused.
Existing nvdecfile(/home/stephany/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_8GB_DEVKIT/Linux_for_Tegra/bootloader/nvdec_t234_prod.fw) reused.
Existing psc_rf(/home/stephany/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_8GB_DEVKIT/Linux_for_Tegra/bootloader/psc_rf_t234_prod.bin) reused.
Existing mb2_rf(/home/stephany/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_8GB_DEVKIT/Linux_for_Tegra/bootloader/mb2rf_t234.bin) reused.
Existing mb1file(/home/stephany/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_8GB_DEVKIT/Linux_for_Tegra/bootloader/mb1_t234_prod.bin) reused.
Existing bpffile(/home/stephany/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_8GB_DEVKIT/Linux_for_Tegra/bootloader/bpmp_t234-TE950M-A1_prod.bin) reused.
copying bpfdtbfile(/home/stephany/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_8GB_DEVKIT/Linux_for_Tegra/bootloader/generic/tegra234-bpmp-3767-0003-3509-a02.dtb)… done.
Existing camerafw(/home/stephany/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_8GB_DEVKIT/Linux_for_Tegra/bootloader/camera-rtcpu-t234-rce.img) reused.
Existing apefile(/home/stephany/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_8GB_DEVKIT/Linux_for_Tegra/bootloader/adsp-fw.bin) reused.
Existing spefile(/home/stephany/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_8GB_DEVKIT/Linux_for_Tegra/bootloader/spe_t234.bin) reused.
Existing wb0boot(/home/stephany/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_8GB_DEVKIT/Linux_for_Tegra/bootloader/sc7_t234_prod.bin) reused.
Existing tosfile(/home/stephany/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_8GB_DEVKIT/Linux_for_Tegra/bootloader/tos-optee_t234.img) reused.
Existing eksfile(/home/stephany/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_8GB_DEVKIT/Linux_for_Tegra/bootloader/eks_t234.img) reused.
copying dtbfile(/home/stephany/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_8GB_DEVKIT/Linux_for_Tegra/kernel/dtb/tegra234-p3768-0000+p3767-0003-nv.dtb)… done.
Copying nv_boot_control.conf to rootfs
populating kernel to rootfs… done.
populating initrd to rootfs… done.
populating kernel_tegra234-p3768-0000+p3767-0003-nv.dtb to rootfs… done.
Making system.img…
populating rootfs from /home/stephany/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_8GB_DEVKIT/Linux_for_Tegra/rootfs … 	populating /boot/extlinux/extlinux.conf … done.
Sync’ing system.img … done.
Converting RAW image to Sparse image… done.
system.img built successfully.
Not signing of kernel-dtb
Existing tbcfile(/home/stephany/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_8GB_DEVKIT/Linux_for_Tegra/bootloader/uefi_jetson.bin) reused.
Existing rcm_tbcfile(/home/stephany/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_8GB_DEVKIT/Linux_for_Tegra/bootloader/uefi_jetson_minimal.bin) reused.
131072+0 records in
131072+0 records out
67108864 bytes (67 MB, 64 MiB) copied, 0,10241 s, 655 MB/s
Sync’ing esp.img … done.
copying tbcdtbfile(/home/stephany/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_8GB_DEVKIT/Linux_for_Tegra/kernel/dtb/tegra234-p3768-0000+p3767-0003-nv.dtb)… done.
copying cfgfile(/home/stephany/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_8GB_DEVKIT/Linux_for_Tegra/bootloader/generic/cfg/flash_t234_qspi_nvme.xml) to flash.xml… done.
Existing flashapp(/home/stephany/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_8GB_DEVKIT/Linux_for_Tegra/bootloader/tegraflash.py) reused.
copying overlay_dtb(/home/stephany/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_8GB_DEVKIT/Linux_for_Tegra/kernel/dtb/L4TConfiguration.dtbo)… done.
copying overlay_dtb(/home/stephany/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_8GB_DEVKIT/Linux_for_Tegra/kernel/dtb/tegra234-carveouts.dtbo)… done.
copying overlay_dtb(/home/stephany/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_8GB_DEVKIT/Linux_for_Tegra/kernel/dtb/tegra-optee.dtbo)… done.
copying overlay_dtb(/home/stephany/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_8GB_DEVKIT/Linux_for_Tegra/kernel/dtb/tegra234-p3768-0000+p3767-0000-dynamic.dtbo)… done.
/home/stephany/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_8GB_DEVKIT/Linux_for_Tegra/bootloader/L4TConfiguration_updated.dts: Warning (unit_address_vs_reg): Node /fragment@0 has a unit name, but no reg property
/home/stephany/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_8GB_DEVKIT/Linux_for_Tegra/bootloader/L4TConfiguration.dtbo: Warning (unit_address_vs_reg): Node /fragment@0 has a unit name, but no reg property
./tegraflash.py  --bl uefi_jetson_minimal_with_dtb.bin  --odmdata gbe-uphy-config-8,hsstp-lane-map-3,hsio-uphy-config-0  --overlay_dtb L4TConfiguration.dtbo,tegra234-carveouts.dtbo,tegra-optee.dtbo,tegra234-p3768-0000+p3767-0000-dynamic.dtbo,  --bldtb tegra234-p3768-0000+p3767-0003-nv.dtb --applet mb1_t234_prod.bin --cmd “flash; reboot”  --cfg flash.xml --chip “0x23” --concat_cpubl_bldtb --cpubl uefi_jetson.bin --cpubl_rcm uefi_jetson_minimal.bin --minratchet_config tegra234-mb1-bct-ratchet-p3767-0000.dts --device_config tegra234-mb1-bct-device-p3767-0000.dts --misc_config tegra234-mb1-bct-misc-p3767-0000.dts --pinmux_config tegra234-mb1-bct-pinmux-p3767-dp-a03.dtsi --gpioint_config tegra234-mb1-bct-gpioint-p3767-0000.dts --pmic_config tegra234-mb1-bct-pmic-p3767-0000-a02.dts --pmc_config tegra234-mb1-bct-padvoltage-p3767-dp-a03.dtsi --deviceprod_config tegra234-mb1-bct-cprod-p3767-0000.dts --prod_config tegra234-mb1-bct-prod-p3767-0000.dts --scr_config tegra234-mb2-bct-scr-p3767-0000.dts --wb0sdram_config tegra234-p3767-0001-wb0sdram-l4t.dts --br_cmd_config tegra234-mb1-bct-reset-p3767-0000.dts --uphy tegra234-mb1-bct-uphylane-si.dtsi --dev_params tegra234-br-bct-p3767-0000-l4t.dts,tegra234-br-bct_b-p3767-0000-l4t.dts --mb2bct_cfg tegra234-mb2-bct-misc-p3767-0000.dts  --bins “psc_fw pscfw_t234_prod.bin; mts_mce mce_flash_o10_cr_prod.bin; tsec_fw tsec_t234.bin; mb2_applet applet_t234.bin; mb2_bootloader mb2_t234.bin; xusb_fw xusb_t234_prod.bin; pva_fw nvpva_020.fw; dce_fw display-t234-dce.bin; nvdec nvdec_t234_prod.fw; bpmp_fw bpmp_t234-TE950M-A1_prod.bin; bpmp_fw_dtb tegra234-bpmp-3767-0003-3509-a02.dtb; rce_fw camera-rtcpu-t234-rce.img; ape_fw adsp-fw.bin; spe_fw spe_t234.bin; tos tos-optee_t234.img; eks eks_t234.img”  --sdram_config tegra234-p3767-0001-sdram-l4t.dts  --cust_info custinfo_out.bin  --bct_backup  --boot_chain A  --ramcode 2
saving flash command in /home/stephany/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_8GB_DEVKIT/Linux_for_Tegra/bootloader/flashcmd.txt
saving Windows flash command to /home/stephany/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_8GB_DEVKIT/Linux_for_Tegra/bootloader/flash_win.bat
*** Flashing target device started. ***
version 1.0.0
[   0.0119 ] tegrasign_v3.py --key None --getmode mode.txt
[   0.0120 ] Assuming zero filled SBK key
[   0.0114 ] Parsing partition layout
[   0.0120 ] tegraparser_v2 --pt flash.xml.tmp
[   0.0153 ] Change tegra234-bpmp-3767-0003-3509-a02.dtb to tegra234-bpmp-3767-0003-3509-a02_with_odm.dtb
[   0.0362 ] /usr/bin/python3 dtbcheck.py -c t234 -o tegra234-bpmp-3767-0003-3509-a02_with_odm.dtb tegra234-bpmp-3767-0003-3509-a02_with_odm_tmp.dtb
[   0.1770 ] Concatenating L4TConfiguration.dtbo,tegra234-carveouts.dtbo,tegra-optee.dtbo,tegra234-p3768-0000+p3767-0000-dynamic.dtbo to tegra234-p3768-0000+p3767-0003-nv_with_odm_overlay.dtb.updated
[   0.1771 ] Concatenating bl dtb to cpubl binary
[   0.1782 ] Concatenating bl dtb:(tegra234-p3768-0000+p3767-0003-nv_with_odm_overlay.dtb.updated), to cpubl binary: uefi_jetson_minimal.bin
[   0.1793 ] MB2 binary: mb2_t234.bin
[   0.1794 ] Pre-processing mb2bct config: tegra234-mb2-bct-misc-p3767-0000.dts
[   0.1887 ] Pre-processing mb2bct config: tegra234-mb2-bct-scr-p3767-0000.dts
[   0.3664 ] Generating coldboot mb2-bct
[   0.3664 ] tegrabct_v2 --chip 0x23 0 --mb2bct mb2_cold_boot_bct.cfg --mb2bctcfg tegra234-mb2-bct-misc-p3767-0000_cpp.dtb --scr tegra234-mb2-bct-scr-p3767-0000_cpp.dtb
[   0.3667 ] ERROR: value 0x31 is out of range
[   0.3676 ] ERROR: value 0x31 is out of range
[   0.3677 ] ERROR: value 0x31 is out of range
[   0.3678 ] ERROR: value 0x31 is out of range
[   0.3679 ] WARNING: unknown property ‘tfc_version’
[   0.3680 ] WARNING: unknown property ‘addr_header_version’
[   0.3771 ] Updating mb2-bct with storage information
[   0.3775 ] tegrabct_v2 --chip 0x23 0 --mb2bct mb2_cold_boot_bct_MB2.bct --updatestorageinfo flash.xml.bin
[   0.3870 ] Concatenating mb2-bct to mb2 binary
[   0.3870 ] mb2_bin_file = mb2_t234.bin
[   0.3870 ] mb2_bct_file = mb2_cold_boot_bct_MB2.bct
[   0.3888 ] DCE binary: display-t234-dce.bin
[   0.3888 ] Kernel DTB used: kernel_tegra234-p3768-0000+p3767-0003-nv.dtb
[   0.3888 ] Concatenating kernel-dtb to dce-fw binary
[   0.3889 ] dce_bin = display-t234-dce.bin
[   0.3889 ] kernel_dtb = kernel_tegra234-p3768-0000+p3767-0003-nv.dtb
[   0.3889 ] dce_with_dtb = display-t234-dce_with_kernel_tegra234-p3768-0000+p3767-0003-nv.bin
[   0.3964 ] Update display-t234-dce_with_kernel_tegra234-p3768-0000+p3767-0003-nv.bin to dce_fw partitions
[   0.3979 ] Parsing partition layout
[   0.3983 ] tegraparser_v2 --pt flash.xml.tmp
[   0.3992 ] Creating list of images to be signed
[   0.3996 ] Generating ratchet blob
[   0.3996 ] Pre-processing config: tegra234-mb1-bct-reset-p3767-0000.dts
[   0.4050 ] Pre-processing config: tegra234-mb1-bct-device-p3767-0000.dts
[   0.4107 ] Pre-processing config: tegra234-mb1-bct-cprod-p3767-0000.dts
[   0.4173 ] Pre-processing config: tegra234-mb1-bct-gpioint-p3767-0000.dts
[   0.4259 ] Pre-processing config: tegra234-mb1-bct-misc-p3767-0000.dts
[   0.4400 ] Pre-processing config: tegra234-mb1-bct-pinmux-p3767-dp-a03.dtsi
[   0.4518 ] Pre-processing config: tegra234-mb1-bct-padvoltage-p3767-dp-a03.dtsi
[   0.4577 ] Pre-processing config: tegra234-mb1-bct-pmic-p3767-0000-a02.dts
[   0.4660 ] Pre-processing config: tegra234-mb1-bct-prod-p3767-0000.dts
[   0.4736 ] Pre-processing config: tegra234-p3767-0001-sdram-l4t.dts
[   0.9960 ] Pre-processing config: tegra234-mb1-bct-uphylane-si.dtsi
[   1.0098 ] Pre-processing config: tegra234-p3767-0001-wb0sdram-l4t.dts
[   1.5307 ] Pre-processing config: tegra234-mb1-bct-ratchet-p3767-0000.dts
[   1.5458 ] Generating coldboot mb1-bct
[   1.5463 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_cold_boot_bct.cfg --misc tegra234-mb1-bct-misc-p3767-0000_cpp.dtb --wb0sdram tegra234-p3767-0001-wb0sdram-l4t_cpp.dtb --pinmux tegra234-mb1-bct-pinmux-p3767-dp-a03_cpp.dtb --pmc tegra234-mb1-bct-padvoltage-p3767-dp-a03_cpp.dtb --pmic tegra234-mb1-bct-pmic-p3767-0000-a02_cpp.dtb --brcommand tegra234-mb1-bct-reset-p3767-0000_cpp.dtb --prod tegra234-mb1-bct-prod-p3767-0000_cpp.dtb --gpioint tegra234-mb1-bct-gpioint-p3767-0000_cpp.dtb --uphy tegra234-mb1-bct-uphylane-si_cpp.dtb --device tegra234-mb1-bct-device-p3767-0000_cpp.dtb --deviceprod tegra234-mb1-bct-cprod-p3767-0000_cpp.dtb --minratchet tegra234-mb1-bct-ratchet-p3767-0000_cpp.dtb --ratchet_blob ratchet_blob.bin
[   1.5467 ] MB1-BCT version: 0.13
[   1.5487 ] Parsing config file :tegra234-mb1-bct-pinmux-p3767-dp-a03_cpp.dtb
[   1.5488 ] Added Platform Config 0 data with size :- 2416
[   1.5512 ] Parsing config file :tegra234-mb1-bct-padvoltage-p3767-dp-a03_cpp.dtb
[   1.5513 ] WARNING: unknown node ‘g2’
[   1.5514 ] WARNING: unknown node ‘g9’
[   1.5516 ] Added Platform Config 2 data with size :- 24
[   1.5516 ]
[   1.5516 ] Parsing config file :tegra234-mb1-bct-pmic-p3767-0000-a02_cpp.dtb
[   1.5516 ] Added Platform Config 4 data with size :- 288
[   1.5516 ]
[   1.5516 ] Parsing config file :tegra234-mb1-bct-reset-p3767-0000_cpp.dtb
[   1.5516 ] Added Platform Config 3 data with size :- 52
[   1.5516 ]
[   1.5516 ] Parsing config file :tegra234-mb1-bct-prod-p3767-0000_cpp.dtb
[   1.5516 ] WARNING: unknown property ‘major’
[   1.5516 ] WARNING: unknown property ‘minor’
[   1.5516 ] Added Platform Config 5 data with size :- 512
[   1.5516 ]
[   1.5516 ] Parsing config file :tegra234-mb1-bct-gpioint-p3767-0000_cpp.dtb
[   1.5516 ] Added Platform Config 7 data with size :- 380
[   1.5516 ]
[   1.5516 ] Parsing config file :tegra234-mb1-bct-uphylane-si_cpp.dtb
[   1.5516 ] Added Platform Config 8 data with size :- 24
[   1.5516 ]
[   1.5516 ] Parsing config file :tegra234-mb1-bct-device-p3767-0000_cpp.dtb
[   1.5516 ] Added Platform Config 9 data with size :- 100
[   1.5516 ]
[   1.5516 ] Parsing config file :tegra234-mb1-bct-cprod-p3767-0000_cpp.dtb
[   1.5516 ] ModuleCount 0 NumProdNames 0
[   1.5516 ] Added Platform Config 6 data with size :- 16
[   1.5516 ]
[   1.5516 ] Parsing config file :tegra234-mb1-bct-ratchet-p3767-0000_cpp.dtb
[   1.5516 ]
[   1.5516 ] Updating mb1-bct with firmware information
[   1.5520 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_cold_boot_bct_MB1.bct --updatefwinfo flash.xml.bin
[   1.5529 ] tegrahost_v2 --chip 0x23 0 --align mb1_cold_boot_bct_MB1_aligned.bct
[   1.5533 ] Generating SHA2 Hash for mb1bct
[   1.5545 ] Sha saved in mb1_cold_boot_bct_MB1_aligned.sha
[   1.5551 ] Sha saved in mb1_cold_boot_bct_MB1.sha
[   1.5547 ] tegrahost_v2 --chip 0x23 0 --magicid MBCT --ratchet_blob ratchet_blob.bin --appendsigheader mb1_cold_boot_bct_MB1_aligned.bct zerosbk
[   1.5549 ] adding BCH for mb1_cold_boot_bct_MB1_aligned.bct
[   1.5563 ] tegrasign_v3.py --key None --list mb1_cold_boot_bct_MB1_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[   1.5564 ] Assuming zero filled SBK key
[   1.5574 ] Warning: pub_key.key is not found
[   1.5572 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mb1_cold_boot_bct_MB1_aligned_sigheader.bct.encrypt mb1_cold_boot_bct_MB1_aligned_sigheader.bct.hash zerosbk
[   1.5579 ] tegrahost_v2 --chip 0x23 0 --partitionlayout flash.xml.bin --ratchet_blob ratchet_blob.bin --list images_list.xml zerosbk
[   1.5584 ] MB1: Nvheader already present is mb1_t234_prod_aligned.bin
[   1.5594 ] Header already present for mb1_t234_prod_aligned_sigheader.bin
[   1.5597 ] MB1: Nvheader already present is psc_bl1_t234_prod_aligned.bin
[   1.5627 ] Header already present for psc_bl1_t234_prod_aligned_sigheader.bin
[   1.5629 ] Header already present for tsec_t234_aligned.bin
[   1.5641 ] Header already present for nvdec_t234_prod_aligned.fw
[   1.5664 ] adding BCH for mb2_t234_with_mb2_cold_boot_bct_MB2_aligned.bin
[   1.5694 ] adding BCH for xusb_t234_prod_aligned.bin
[   1.5761 ] Header already present for bpmp_t234-TE950M-A1_prod_aligned.bin
[   1.5801 ] adding BCH for tegra234-bpmp-3767-0003-3509-a02_with_odm_aligned.dtb
[   1.5872 ] Header already present for pscfw_t234_prod_aligned.bin
[   1.5905 ] Header already present for mce_flash_o10_cr_prod_aligned.bin
[   1.5929 ] Header already present for sc7_t234_prod.bin
[   1.5945 ] Header already present for psc_rf_t234_prod_aligned.bin
[   1.5963 ] adding BCH for mb2rf_t234_aligned.bin
[   1.5974 ] INFO: compressing uefi_jetson_with_dtb_aligned.bin
[   1.6275 ] INFO: complete compression, uefi_jetson_with_dtb_aligned.bin, ratio = 92%
[   1.6312 ] adding BCH for uefi_jetson_with_dtb_aligned_blob_w_bin_aligned.bin
[   1.6584 ] adding BCH for tos-optee_t234_aligned.img
[   1.6855 ] adding BCH for eks_t234_aligned.img
[   1.7129 ] INFO: compressing display-t234-dce_with_kernel_tegra234-p3768-0000+p3767-0003-nv_aligned.bin
[   1.8097 ] INFO: complete compression, display-t234-dce_with_kernel_tegra234-p3768-0000+p3767-0003-nv_aligned.bin, ratio = 6%
[   1.8197 ] adding BCH for display-t234-dce_with_kernel_tegra234-p3768-0000+p3767-0003-nv_aligned_blob_w_bin_aligned.bin
[   1.8299 ] adding BCH for spe_t234_aligned.bin
[   1.8445 ] adding BCH for camera-rtcpu-t234-rce_aligned.img
[   1.8494 ] adding BCH for adsp-fw_aligned.bin
[   1.8562 ] INFO: compressing nvpva_020_aligned.fw
[   1.8801 ] INFO: complete compression, nvpva_020_aligned.fw, ratio = 2%
[   1.8814 ] adding BCH for nvpva_020_aligned_blob_w_bin_aligned.fw
[   1.8826 ] MB1: Nvheader already present is mb1_t234_prod_aligned.bin
[   1.8834 ] Header already present for mb1_t234_prod_aligned_sigheader.bin
[   1.8836 ] MB1: Nvheader already present is psc_bl1_t234_prod_aligned.bin
[   1.8858 ] Header already present for psc_bl1_t234_prod_aligned_sigheader.bin
[   1.8859 ] Header already present for tsec_t234_aligned.bin
[   1.8869 ] Header already present for nvdec_t234_prod_aligned.fw
[   1.8884 ] adding BCH for mb2_t234_with_mb2_cold_boot_bct_MB2_aligned.bin
[   1.8911 ] adding BCH for xusb_t234_prod_aligned.bin
[   1.8973 ] Header already present for bpmp_t234-TE950M-A1_prod_aligned.bin
[   1.9013 ] adding BCH for tegra234-bpmp-3767-0003-3509-a02_with_odm_aligned.dtb
[   1.9086 ] Header already present for pscfw_t234_prod_aligned.bin
[   1.9117 ] Header already present for mce_flash_o10_cr_prod_aligned.bin
[   1.9144 ] Header already present for sc7_t234_prod.bin
[   1.9158 ] Header already present for psc_rf_t234_prod_aligned.bin
[   1.9172 ] adding BCH for mb2rf_t234_aligned.bin
[   1.9182 ] INFO: compressing uefi_jetson_with_dtb_aligned.bin
[   1.9485 ] INFO: complete compression, uefi_jetson_with_dtb_aligned.bin, ratio = 92%
[   1.9522 ] adding BCH for uefi_jetson_with_dtb_aligned_blob_w_bin_aligned.bin
[   1.9809 ] adding BCH for tos-optee_t234_aligned.img
[   2.0079 ] adding BCH for eks_t234_aligned.img
[   2.0355 ] INFO: compressing display-t234-dce_with_kernel_tegra234-p3768-0000+p3767-0003-nv_aligned.bin
[   2.1340 ] INFO: complete compression, display-t234-dce_with_kernel_tegra234-p3768-0000+p3767-0003-nv_aligned.bin, ratio = 6%
[   2.1441 ] adding BCH for display-t234-dce_with_kernel_tegra234-p3768-0000+p3767-0003-nv_aligned_blob_w_bin_aligned.bin
[   2.1542 ] adding BCH for spe_t234_aligned.bin
[   2.1599 ] adding BCH for camera-rtcpu-t234-rce_aligned.img
[   2.1645 ] adding BCH for adsp-fw_aligned.bin
[   2.1714 ] INFO: compressing nvpva_020_aligned.fw
[   2.1951 ] INFO: complete compression, nvpva_020_aligned.fw, ratio = 2%
[   2.1967 ] adding BCH for nvpva_020_aligned_blob_w_bin_aligned.fw
[   2.1986 ] Filling MB1 storage info
[   2.1986 ] Parsing dev params for multi chains
[   2.2046 ] Generating br-bct
[   2.2050 ] Updating dev and MSS params in BR BCT
[   2.2050 ] tegrabct_v2 --dev_param tegra234-br-bct-p3767-0000-l4t_cpp.dtb --sdram tegra234-p3767-0001-sdram-l4t_cpp.dtb --brbct br_bct.cfg --chip 0x23 0
[   2.2606 ] Updating bl info
[   2.2613 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updateblinfo flash.xml.bin
[   2.2693 ] Generating br-bct
[   2.2696 ] Updating dev and MSS params in BR BCT
[   2.2697 ] tegrabct_v2 --dev_param tegra234-br-bct_b-p3767-0000-l4t_cpp.dtb --sdram tegra234-p3767-0001-sdram-l4t_cpp.dtb --brbct br_bct.cfg --chip 0x23 0
[   2.3305 ] Updating bl info
[   2.3311 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updateblinfo flash.xml.bin
[   2.3321 ] Generating BCT backup image
[   2.3321 ] dd if=/dev/zero of=bct_backup.img bs=1 count=32768
[   2.3324 ] 32768+0 records in
[   2.3495 ] 32768+0 records out
[   2.3495 ] 32768 bytes (33 kB, 32 KiB) copied, 0,016488 s, 2,0 MB/s
[   2.3495 ]
[   2.3495 ] Concatenating BCT for chain A to bct_backup.img
[   2.3495 ] dd if=br_bct_BR.bct of=bct_backup.img bs=1 seek=0 conv=notrunc
[   2.3501 ] 8192+0 records in
[   2.3573 ] 8192+0 records out
[   2.3573 ] 8192 bytes (8,2 kB, 8,0 KiB) copied, 0,00682899 s, 1,2 MB/s
[   2.3573 ]
[   2.3573 ] Concatenating BCT for chain B to bct_backup.img
[   2.3573 ] dd if=br_bct_b_BR.bct of=bct_backup.img bs=1 seek=16384 conv=notrunc
[   2.3576 ] 8192+0 records in
[   2.3631 ] 8192+0 records out
[   2.3631 ] 8192 bytes (8,2 kB, 8,0 KiB) copied, 0,00492845 s, 1,7 MB/s
[   2.3631 ]
[   2.3631 ] Generating signatures
[   2.3638 ] tegrasign_v3.py --key None --list images_list.xml --pubkeyhash pub_key.key --sha sha512
[   2.3639 ] Assuming zero filled SBK key
[   2.4149 ] Warning: pub_key.key is not found
[   2.4168 ] Parsing dev params for multi chains
[   2.4168 ] Generating br-bct
[   2.4171 ] Updating dev and MSS params in BR BCT
[   2.4172 ] tegrabct_v2 --dev_param tegra234-br-bct-p3767-0000-l4t_cpp.dtb --sdram tegra234-p3767-0001-sdram-l4t_cpp.dtb --brbct br_bct.cfg --chip 0x23 0
[   2.4751 ] Updating customer data section
[   2.4756 ] tegrabct_v2 --chip 0x23 0 --brbct br_bct_BR.bct --update_custinfo custinfo_out.bin
[   2.4779 ] Updating bl info
[   2.4783 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updateblinfo flash.xml.bin --updatesig images_list_signed.xml
[   2.4825 ] Generating SHA2 Hash
[   2.4839 ] Sha saved in br_bct_BR.sha
[   2.4834 ] Get Signed section of bct
[   2.4836 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --listbct bct_list.xml
[   2.4841 ] Signing BCT
[   2.4848 ] tegrasign_v3.py --key None --list bct_list.xml --pubkeyhash pub_key.key --sha sha512
[   2.4849 ] Assuming zero filled SBK key
[   2.4867 ] Sha saved in br_bct_BR.sha
[   2.4869 ] Warning: pub_key.key is not found
[   2.4862 ] Updating BCT with signature
[   2.4865 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updatesig bct_list_signed.xml
[   2.4867 ] Offset :4608 Len :3584
[   2.4871 ] Generating SHA2 Hash
[   2.4877 ] tegrasign_v3.py --key None --list bct_list.xml --sha sha512
[   2.4878 ] Assuming zero filled SBK key
[   2.4894 ] Sha saved in br_bct_BR.sha
[   2.4890 ] Updating BCT with SHA2 Hash
[   2.4892 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updatesha bct_list_signed.xml
[   2.4894 ] Offset :4608 Len :3584
[   2.4897 ] Offset :68 Len :8124
[   2.4898 ] Generating br-bct
[   2.4901 ] Updating dev and MSS params in BR BCT
[   2.4901 ] tegrabct_v2 --dev_param tegra234-br-bct_b-p3767-0000-l4t_cpp.dtb --sdram tegra234-p3767-0001-sdram-l4t_cpp.dtb --brbct br_bct.cfg --chip 0x23 0
[   2.5487 ] Updating customer data section
[   2.5493 ] tegrabct_v2 --chip 0x23 0 --brbct br_bct_BR.bct --update_custinfo custinfo_out.bin
[   2.5514 ] Updating bl info
[   2.5516 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updateblinfo flash.xml.bin --updatesig images_list_signed.xml
[   2.5540 ] Generating SHA2 Hash
[   2.5551 ] Sha saved in br_bct_BR.sha
[   2.5545 ] Get Signed section of bct
[   2.5546 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --listbct bct_list.xml
[   2.5550 ] Signing BCT
[   2.5557 ] tegrasign_v3.py --key None --list bct_list.xml --pubkeyhash pub_key.key --sha sha512
[   2.5558 ] Assuming zero filled SBK key
[   2.5569 ] Sha saved in br_bct_BR.sha
[   2.5570 ] Warning: pub_key.key is not found
[   2.5563 ] Updating BCT with signature
[   2.5565 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updatesig bct_list_signed.xml
[   2.5567 ] Offset :4608 Len :3584
[   2.5570 ] Generating SHA2 Hash
[   2.5577 ] tegrasign_v3.py --key None --list bct_list.xml --sha sha512
[   2.5578 ] Assuming zero filled SBK key
[   2.5593 ] Sha saved in br_bct_BR.sha
[   2.5588 ] Updating BCT with SHA2 Hash
[   2.5591 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updatesha bct_list_signed.xml
[   2.5594 ] Offset :4608 Len :3584
[   2.5597 ] Offset :68 Len :8124
[   2.5598 ] Generating BCT backup image
[   2.5599 ] dd if=/dev/zero of=bct_backup.img bs=1 count=32768
[   2.5601 ] 32768+0 records in
[   2.5765 ] 32768+0 records out
[   2.5765 ] 32768 bytes (33 kB, 32 KiB) copied, 0,0158258 s, 2,1 MB/s
[   2.5765 ]
[   2.5765 ] Concatenating BCT for chain A to bct_backup.img
[   2.5765 ] dd if=br_bct_BR.bct of=bct_backup.img bs=1 seek=0 conv=notrunc
[   2.5770 ] 8192+0 records in
[   2.5849 ] 8192+0 records out
[   2.5849 ] 8192 bytes (8,2 kB, 8,0 KiB) copied, 0,00721111 s, 1,1 MB/s
[   2.5849 ]
[   2.5849 ] Concatenating BCT for chain B to bct_backup.img
[   2.5849 ] dd if=br_bct_b_BR.bct of=bct_backup.img bs=1 seek=16384 conv=notrunc
[   2.5853 ] 8192+0 records in
[   2.5914 ] 8192+0 records out
[   2.5914 ] 8192 bytes (8,2 kB, 8,0 KiB) copied, 0,00569375 s, 1,4 MB/s
[   2.5914 ]
[   2.5915 ] Generating coldboot mb1-bct
[   2.5918 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_cold_boot_bct.cfg --misc tegra234-mb1-bct-misc-p3767-0000_cpp.dtb --wb0sdram tegra234-p3767-0001-wb0sdram-l4t_cpp.dtb --pinmux tegra234-mb1-bct-pinmux-p3767-dp-a03_cpp.dtb --pmc tegra234-mb1-bct-padvoltage-p3767-dp-a03_cpp.dtb --pmic tegra234-mb1-bct-pmic-p3767-0000-a02_cpp.dtb --brcommand tegra234-mb1-bct-reset-p3767-0000_cpp.dtb --prod tegra234-mb1-bct-prod-p3767-0000_cpp.dtb --gpioint tegra234-mb1-bct-gpioint-p3767-0000_cpp.dtb --uphy tegra234-mb1-bct-uphylane-si_cpp.dtb --device tegra234-mb1-bct-device-p3767-0000_cpp.dtb --deviceprod tegra234-mb1-bct-cprod-p3767-0000_cpp.dtb --minratchet tegra234-mb1-bct-ratchet-p3767-0000_cpp.dtb --ratchet_blob ratchet_blob.bin
[   2.5922 ] MB1-BCT version: 0.13
[   2.5936 ] Parsing config file :tegra234-mb1-bct-pinmux-p3767-dp-a03_cpp.dtb
[   2.5938 ] Added Platform Config 0 data with size :- 2416
[   2.5957 ] Parsing config file :tegra234-mb1-bct-padvoltage-p3767-dp-a03_cpp.dtb
[   2.5960 ] WARNING: unknown node ‘g2’
[   2.5961 ] WARNING: unknown node ‘g2’
[   2.5961 ] WARNING: unknown node ‘g9’
[   2.5962 ] WARNING: unknown node ‘g9’
[   2.5962 ] Added Platform Config 2 data with size :- 24
[   2.5962 ]
[   2.5962 ] Parsing config file :tegra234-mb1-bct-pmic-p3767-0000-a02_cpp.dtb
[   2.5962 ] Added Platform Config 4 data with size :- 288
[   2.5962 ]
[   2.5962 ] Parsing config file :tegra234-mb1-bct-reset-p3767-0000_cpp.dtb
[   2.5962 ] Added Platform Config 3 data with size :- 52
[   2.5962 ]
[   2.5962 ] Parsing config file :tegra234-mb1-bct-prod-p3767-0000_cpp.dtb
[   2.5962 ] WARNING: unknown property ‘major’
[   2.5962 ] WARNING: unknown property ‘minor’
[   2.5962 ] Added Platform Config 5 data with size :- 512
[   2.5962 ]
[   2.5962 ] Parsing config file :tegra234-mb1-bct-gpioint-p3767-0000_cpp.dtb
[   2.5962 ] Added Platform Config 7 data with size :- 380
[   2.5962 ]
[   2.5962 ] Parsing config file :tegra234-mb1-bct-uphylane-si_cpp.dtb
[   2.5962 ] Added Platform Config 8 data with size :- 24
[   2.5962 ]
[   2.5962 ] Parsing config file :tegra234-mb1-bct-device-p3767-0000_cpp.dtb
[   2.5963 ] Added Platform Config 9 data with size :- 100
[   2.5963 ]
[   2.5963 ] Parsing config file :tegra234-mb1-bct-cprod-p3767-0000_cpp.dtb
[   2.5963 ] ModuleCount 0 NumProdNames 0
[   2.5963 ] Added Platform Config 6 data with size :- 16
[   2.5963 ]
[   2.5963 ] Parsing config file :tegra234-mb1-bct-ratchet-p3767-0000_cpp.dtb
[   2.5963 ]
[   2.5963 ] Updating mb1-bct with firmware information
[   2.5966 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_cold_boot_bct_MB1.bct --updatefwinfo flash.xml.bin
[   2.5977 ] tegrahost_v2 --chip 0x23 0 --align mb1_cold_boot_bct_MB1_aligned.bct
[   2.5982 ] Generating SHA2 Hash for mb1bct
[   2.5999 ] Sha saved in mb1_cold_boot_bct_MB1_aligned.sha
[   2.6008 ] Sha saved in mb1_cold_boot_bct_MB1.sha
[   2.6005 ] tegrahost_v2 --chip 0x23 0 --magicid MBCT --ratchet_blob ratchet_blob.bin --appendsigheader mb1_cold_boot_bct_MB1_aligned.bct zerosbk
[   2.6008 ] adding BCH for mb1_cold_boot_bct_MB1_aligned.bct
[   2.6024 ] tegrasign_v3.py --key None --list mb1_cold_boot_bct_MB1_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[   2.6026 ] Assuming zero filled SBK key
[   2.6041 ] Warning: pub_key.key is not found
[   2.6040 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mb1_cold_boot_bct_MB1_aligned_sigheader.bct.encrypt mb1_cold_boot_bct_MB1_aligned_sigheader.bct.hash zerosbk
[   2.6051 ] Generating recovery mb1-bct
[   2.6055 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_bct.cfg --misc tegra234-mb1-bct-misc-p3767-0000_cpp.dtb --wb0sdram tegra234-p3767-0001-wb0sdram-l4t_cpp.dtb --pinmux tegra234-mb1-bct-pinmux-p3767-dp-a03_cpp.dtb --pmc tegra234-mb1-bct-padvoltage-p3767-dp-a03_cpp.dtb --pmic tegra234-mb1-bct-pmic-p3767-0000-a02_cpp.dtb --brcommand tegra234-mb1-bct-reset-p3767-0000_cpp.dtb --prod tegra234-mb1-bct-prod-p3767-0000_cpp.dtb --gpioint tegra234-mb1-bct-gpioint-p3767-0000_cpp.dtb --uphy tegra234-mb1-bct-uphylane-si_cpp.dtb --device tegra234-mb1-bct-device-p3767-0000_cpp.dtb --deviceprod tegra234-mb1-bct-cprod-p3767-0000_cpp.dtb --minratchet tegra234-mb1-bct-ratchet-p3767-0000_cpp.dtb --ratchet_blob ratchet_blob.bin
[   2.6059 ] MB1-BCT version: 0.13
[   2.6077 ] Parsing config file :tegra234-mb1-bct-pinmux-p3767-dp-a03_cpp.dtb
[   2.6081 ] Added Platform Config 0 data with size :- 2416
[   2.6104 ] Parsing config file :tegra234-mb1-bct-padvoltage-p3767-dp-a03_cpp.dtb
[   2.6105 ] WARNING: unknown node ‘g2’
[   2.6106 ] WARNING: unknown node ‘g9’
[   2.6107 ] WARNING: unknown node ‘g9’
[   2.6107 ] Added Platform Config 2 data with size :- 24
[   2.6108 ]
[   2.6108 ] Parsing config file :tegra234-mb1-bct-pmic-p3767-0000-a02_cpp.dtb
[   2.6108 ] Added Platform Config 4 data with size :- 288
[   2.6108 ]
[   2.6108 ] Parsing config file :tegra234-mb1-bct-reset-p3767-0000_cpp.dtb
[   2.6108 ] Added Platform Config 3 data with size :- 52
[   2.6108 ]
[   2.6108 ] Parsing config file :tegra234-mb1-bct-prod-p3767-0000_cpp.dtb
[   2.6108 ] WARNING: unknown property ‘major’
[   2.6108 ] WARNING: unknown property ‘minor’
[   2.6108 ] Added Platform Config 5 data with size :- 512
[   2.6108 ]
[   2.6108 ] Parsing config file :tegra234-mb1-bct-gpioint-p3767-0000_cpp.dtb
[   2.6108 ] Added Platform Config 7 data with size :- 380
[   2.6108 ]
[   2.6108 ] Parsing config file :tegra234-mb1-bct-uphylane-si_cpp.dtb
[   2.6108 ] Added Platform Config 8 data with size :- 24
[   2.6108 ]
[   2.6108 ] Parsing config file :tegra234-mb1-bct-device-p3767-0000_cpp.dtb
[   2.6108 ] Added Platform Config 9 data with size :- 100
[   2.6108 ]
[   2.6108 ] Parsing config file :tegra234-mb1-bct-cprod-p3767-0000_cpp.dtb
[   2.6108 ] ModuleCount 0 NumProdNames 0
[   2.6108 ] Added Platform Config 6 data with size :- 16
[   2.6108 ]
[   2.6108 ] Parsing config file :tegra234-mb1-bct-ratchet-p3767-0000_cpp.dtb
[   2.6108 ]
[   2.6109 ] Updating mb1-bct with firmware information
[   2.6111 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_bct_MB1.bct --recov --updatefwinfo flash.xml.bin
[   2.6126 ] tegrahost_v2 --chip 0x23 0 --align mb1_bct_MB1_aligned.bct
[   2.6129 ] Generating SHA2 Hash for mb1bct
[   2.6142 ] Sha saved in mb1_bct_MB1_aligned.sha
[   2.6148 ] Sha saved in mb1_bct_MB1.sha
[   2.6146 ] tegrahost_v2 --chip 0x23 0 --magicid MBCT --ratchet_blob ratchet_blob.bin --appendsigheader mb1_bct_MB1_aligned.bct zerosbk
[   2.6149 ] adding BCH for mb1_bct_MB1_aligned.bct
[   2.6162 ] tegrasign_v3.py --key None --list mb1_bct_MB1_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[   2.6164 ] Assuming zero filled SBK key
[   2.6176 ] Warning: pub_key.key is not found
[   2.6174 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mb1_bct_MB1_aligned_sigheader.bct.encrypt mb1_bct_MB1_aligned_sigheader.bct.hash zerosbk
[   2.6185 ] Generating coldboot mem-bct
[   2.6189 ] tegrabct_v2 --chip 0x23 0 --sdram tegra234-p3767-0001-sdram-l4t_cpp.dtb --wb0sdram tegra234-p3767-0001-wb0sdram-l4t_cpp.dtb --membct tegra234-p3767-0001-sdram-l4t_cpp_1.bct tegra234-p3767-0001-sdram-l4t_cpp_2.bct tegra234-p3767-0001-sdram-l4t_cpp_3.bct tegra234-p3767-0001-sdram-l4t_cpp_4.bct
[   2.6192 ]  packing sdram params with Wb0 file tegra234-p3767-0001-wb0sdram-l4t_cpp.dtb
[   2.6766 ] Packing sdram param for instance[0]
[   2.6767 ] Packing sdram param for instance[1]
[   2.6769 ] Packing sdram param for instance[2]
[   2.6770 ] Packing sdram param for instance[3]
[   2.6772 ] Packing sdram param for instance[4]
[   2.6775 ] Packing sdram param for instance[5]
[   2.6777 ] Packing sdram param for instance[6]
[   2.6778 ] Packing sdram param for instance[7]
[   2.6780 ] Packing sdram param for instance[8]
[   2.6781 ] Packing sdram param for instance[9]
[   2.6783 ] Packing sdram param for instance[10]
[   2.6784 ] Packing sdram param for instance[11]
[   2.6786 ] Packing sdram param for instance[12]
[   2.6787 ] Packing sdram param for instance[13]
[   2.6789 ] Packing sdram param for instance[14]
[   2.6790 ] Packing sdram param for instance[15]
[   2.7315 ] Getting sector size from pt
[   2.7322 ] tegraparser_v2 --getsectorsize flash.xml.bin sector_info.bin
[   2.7326 ] BlockSize read from layout is 0x200
[   2.7330 ] tegrahost_v2 --chip 0x23 0 --blocksize 512 --magicid MEMB --addsigheader_multi tegra234-p3767-0001-sdram-l4t_cpp_1.bct tegra234-p3767-0001-sdram-l4t_cpp_2.bct tegra234-p3767-0001-sdram-l4t_cpp_3.bct tegra234-p3767-0001-sdram-l4t_cpp_4.bct
[   2.7333 ] Binary 0 length is 58752
[   2.7335 ] Binary 0 align length is 58880
[   2.7342 ] Binary 1 length is 58752
[   2.7343 ] Binary 1 align length is 58880
[   2.7349 ] Binary 2 length is 58752
[   2.7350 ] Binary 2 align length is 58880
[   2.7356 ] Binary 3 length is 58752
[   2.7357 ] Binary 3 align length is 58880
[   2.7364 ] Buffer length is 235520
[   2.7365 ] adding BCH for tegra234-p3767-0001-sdram-l4t_cpp_1.bct
[   2.7367 ] new length is 243712
[   2.7374 ] tegrahost_v2 --chip 0x23 0 --align mem_coldboot_aligned.bct
[   2.7383 ] tegrahost_v2 --chip 0x23 0 --magicid MEMB --ratchet_blob ratchet_blob.bin --appendsigheader mem_coldboot_aligned.bct zerosbk
[   2.7385 ] Header already present for mem_coldboot_aligned.bct
[   2.7399 ] tegrasign_v3.py --key None --list mem_coldboot_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[   2.7401 ] Assuming zero filled SBK key
[   2.7413 ] Warning: pub_key.key is not found
[   2.7410 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mem_coldboot_aligned_sigheader.bct.encrypt mem_coldboot_aligned_sigheader.bct.hash zerosbk
[   2.7421 ] Generating recovery mem-bct
[   2.7424 ] tegrabct_v2 --chip 0x23 0 --sdram tegra234-p3767-0001-sdram-l4t_cpp.dtb --wb0sdram tegra234-p3767-0001-wb0sdram-l4t_cpp.dtb --membct tegra234-p3767-0001-sdram-l4t_cpp_1.bct tegra234-p3767-0001-sdram-l4t_cpp_2.bct tegra234-p3767-0001-sdram-l4t_cpp_3.bct tegra234-p3767-0001-sdram-l4t_cpp_4.bct
[   2.7427 ]  packing sdram params with Wb0 file tegra234-p3767-0001-wb0sdram-l4t_cpp.dtb
[   2.7979 ] Packing sdram param for instance[0]
[   2.7980 ] Packing sdram param for instance[1]
[   2.7981 ] Packing sdram param for instance[2]
[   2.7981 ] Packing sdram param for instance[3]
[   2.7982 ] Packing sdram param for instance[4]
[   2.7983 ] Packing sdram param for instance[5]
[   2.7983 ] Packing sdram param for instance[6]
[   2.7984 ] Packing sdram param for instance[7]
[   2.7985 ] Packing sdram param for instance[8]
[   2.7985 ] Packing sdram param for instance[9]
[   2.7986 ] Packing sdram param for instance[10]
[   2.7987 ] Packing sdram param for instance[11]
[   2.7987 ] Packing sdram param for instance[12]
[   2.7988 ] Packing sdram param for instance[13]
[   2.7989 ] Packing sdram param for instance[14]
[   2.7989 ] Packing sdram param for instance[15]
[   2.8517 ] Generating mem_bct based on ramcode group number
[   2.8518 ] Got ramcode 2 from the command line
[   2.8518 ] Using ramcode group number 0
[   2.8518 ] Disabled BPMP dtb trim, using default dtb
[   2.8518 ]
[   2.8522 ] tegrahost_v2 --chip 0x23 0 --align mem_rcm_aligned.bct
[   2.8528 ] tegrahost_v2 --chip 0x23 0 --magicid MEM0 --ratchet_blob ratchet_blob.bin --appendsigheader mem_rcm_aligned.bct zerosbk
[   2.8530 ] adding BCH for mem_rcm_aligned.bct
[   2.8553 ] tegrasign_v3.py --key None --list mem_rcm_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[   2.8554 ] Assuming zero filled SBK key
[   2.8565 ] Warning: pub_key.key is not found
[   2.8562 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mem_rcm_aligned_sigheader.bct.encrypt mem_rcm_aligned_sigheader.bct.hash zerosbk
[   2.8571 ] Generating all 4 mem_bct for ramcode group (0..3)
[   2.8571 ] Disabled BPMP dtb trim, using default dtb
[   2.8572 ]
[   2.8576 ] tegrahost_v2 --chip 0x23 0 --align mem_rcm_0_aligned.bct
[   2.8582 ] tegrahost_v2 --chip 0x23 0 --magicid MEM0 --ratchet_blob ratchet_blob.bin --appendsigheader mem_rcm_0_aligned.bct zerosbk
[   2.8584 ] adding BCH for mem_rcm_0_aligned.bct
[   2.8609 ] tegrasign_v3.py --key None --list mem_rcm_0_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[   2.8610 ] Assuming zero filled SBK key
[   2.8623 ] Warning: pub_key.key is not found
[   2.8623 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mem_rcm_0_aligned_sigheader.bct.encrypt mem_rcm_0_aligned_sigheader.bct.hash zerosbk
[   2.8633 ] Disabled BPMP dtb trim, using default dtb
[   2.8633 ]
[   2.8637 ] tegrahost_v2 --chip 0x23 0 --align mem_rcm_1_aligned.bct
[   2.8643 ] tegrahost_v2 --chip 0x23 0 --magicid MEM1 --ratchet_blob ratchet_blob.bin --appendsigheader mem_rcm_1_aligned.bct zerosbk
[   2.8646 ] adding BCH for mem_rcm_1_aligned.bct
[   2.8678 ] tegrasign_v3.py --key None --list mem_rcm_1_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[   2.8679 ] Assuming zero filled SBK key
[   2.8690 ] Warning: pub_key.key is not found
[   2.8687 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mem_rcm_1_aligned_sigheader.bct.encrypt mem_rcm_1_aligned_sigheader.bct.hash zerosbk
[   2.8695 ] Disabled BPMP dtb trim, using default dtb
[   2.8695 ]
[   2.8700 ] tegrahost_v2 --chip 0x23 0 --align mem_rcm_2_aligned.bct
[   2.8706 ] tegrahost_v2 --chip 0x23 0 --magicid MEM2 --ratchet_blob ratchet_blob.bin --appendsigheader mem_rcm_2_aligned.bct zerosbk
[   2.8708 ] adding BCH for mem_rcm_2_aligned.bct
[   2.8732 ] tegrasign_v3.py --key None --list mem_rcm_2_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[   2.8733 ] Assuming zero filled SBK key
[   2.8743 ] Warning: pub_key.key is not found
[   2.8740 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mem_rcm_2_aligned_sigheader.bct.encrypt mem_rcm_2_aligned_sigheader.bct.hash zerosbk
[   2.8749 ] Disabled BPMP dtb trim, using default dtb
[   2.8750 ]
[   2.8754 ] tegrahost_v2 --chip 0x23 0 --align mem_rcm_3_aligned.bct
[   2.8761 ] tegrahost_v2 --chip 0x23 0 --magicid MEM3 --ratchet_blob ratchet_blob.bin --appendsigheader mem_rcm_3_aligned.bct zerosbk
[   2.8763 ] adding BCH for mem_rcm_3_aligned.bct
[   2.8790 ] tegrasign_v3.py --key None --list mem_rcm_3_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[   2.8792 ] Assuming zero filled SBK key
[   2.8804 ] Warning: pub_key.key is not found
[   2.8802 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mem_rcm_3_aligned_sigheader.bct.encrypt mem_rcm_3_aligned_sigheader.bct.hash zerosbk
[   2.8813 ] Copying signatures
[   2.8817 ] tegrahost_v2 --chip 0x23 0 --partitionlayout flash.xml.bin --updatesig images_list_signed.xml
[   2.9127 ] mb1_t234_prod_aligned_sigheader.bin.encrypt filename is from images_list
[   2.9132 ] psc_bl1_t234_prod_aligned_sigheader.bin.encrypt filename is from images_list
[   2.9132 ] Boot Rom communication
[   2.9137 ] tegrarcm_v2 --new_session --chip 0x23 0 --uid --download bct_br br_bct_BR.bct --download mb1 mb1_t234_prod_aligned_sigheader.bin.encrypt --download psc_bl1 psc_bl1_t234_prod_aligned_sigheader.bin.encrypt --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt
[   2.9140 ] BR_CID: 0x80012344705DE7801C00000007010040
[   2.9371 ] Sending bct_br
[   2.9667 ] Sending mb1
[   2.9678 ] Sending psc_bl1
[   2.9850 ] Sending bct_mb1
[   2.9940 ] Boot Rom communication completed
[   2.9940 ] Generating blob for T23x
[   2.9985 ] tegrahost_v2 --chip 0x23 0 --align blob_uefi_jetson_minimal_with_dtb_aligned.bin
[   3.0002 ] tegrahost_v2 --chip 0x23 0 --magicid CPBL --ratchet_blob ratchet_blob.bin --appendsigheader blob_uefi_jetson_minimal_with_dtb_aligned.bin zerosbk
[   3.0011 ] adding BCH for blob_uefi_jetson_minimal_with_dtb_aligned.bin
[   3.0386 ] tegrasign_v3.py --key None --list blob_uefi_jetson_minimal_with_dtb_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key --sha sha512
[   3.0387 ] Assuming zero filled SBK key
[   3.0409 ] Warning: pub_key.key is not found
[   3.0407 ] tegrahost_v2 --chip 0x23 0 --updatesigheader blob_uefi_jetson_minimal_with_dtb_aligned_sigheader.bin.encrypt blob_uefi_jetson_minimal_with_dtb_aligned_sigheader.bin.hash zerosbk
[   3.0441 ] Get magic id
[   3.0446 ] tegraparser_v2 --get_magic psc_fw
[   3.0450 ] PFWP
[   3.0450 ] partition type psc_fw, magic id = PFWP
[   3.0454 ] tegrahost_v2 --chip 0x23 0 --align blob_pscfw_t234_prod_aligned.bin
[   3.0461 ] tegrahost_v2 --chip 0x23 0 --magicid PFWP --ratchet_blob ratchet_blob.bin --appendsigheader blob_pscfw_t234_prod_aligned.bin zerosbk
[   3.0463 ] Header already present for blob_pscfw_t234_prod_aligned.bin
[   3.0509 ] tegrasign_v3.py --key None --list blob_pscfw_t234_prod_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key --sha sha512
[   3.0510 ] Assuming zero filled SBK key
[   3.0524 ] Warning: pub_key.key is not found
[   3.0523 ] tegrahost_v2 --chip 0x23 0 --updatesigheader blob_pscfw_t234_prod_aligned_sigheader.bin.encrypt blob_pscfw_t234_prod_aligned_sigheader.bin.hash zerosbk
[   3.0537 ] Get magic id
[   3.0541 ] tegraparser_v2 --get_magic mts_mce
[   3.0544 ] MTSM
[   3.0545 ] partition type mts_mce, magic id = MTSM
[   3.0552 ] tegrahost_v2 --chip 0x23 0 --align blob_mce_flash_o10_cr_prod_aligned.bin
[   3.0559 ] tegrahost_v2 --chip 0x23 0 --magicid MTSM --ratchet_blob ratchet_blob.bin --appendsigheader blob_mce_flash_o10_cr_prod_aligned.bin zerosbk
[   3.0562 ] Header already present for blob_mce_flash_o10_cr_prod_aligned.bin
[   3.0595 ] tegrasign_v3.py --key None --list blob_mce_flash_o10_cr_prod_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key --sha sha512
[   3.0596 ] Assuming zero filled SBK key
[   3.0609 ] Warning: pub_key.key is not found
[   3.0606 ] tegrahost_v2 --chip 0x23 0 --updatesigheader blob_mce_flash_o10_cr_prod_aligned_sigheader.bin.encrypt blob_mce_flash_o10_cr_prod_aligned_sigheader.bin.hash zerosbk
[   3.0616 ] Get magic id
[   3.0619 ] tegraparser_v2 --get_magic tsec_fw
[   3.0622 ] TSEC
[   3.0625 ] partition type tsec_fw, magic id = TSEC
[   3.0632 ] tegrahost_v2 --chip 0x23 0 --align blob_tsec_t234_aligned.bin
[   3.0639 ] tegrahost_v2 --chip 0x23 0 --magicid TSEC --ratchet_blob ratchet_blob.bin --appendsigheader blob_tsec_t234_aligned.bin zerosbk
[   3.0642 ] Header already present for blob_tsec_t234_aligned.bin
[   3.0670 ] tegrasign_v3.py --key None --list blob_tsec_t234_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key --sha sha512
[   3.0672 ] Assuming zero filled SBK key
[   3.0687 ] Warning: pub_key.key is not found
[   3.0685 ] tegrahost_v2 --chip 0x23 0 --updatesigheader blob_tsec_t234_aligned_sigheader.bin.encrypt blob_tsec_t234_aligned_sigheader.bin.hash zerosbk
[   3.0701 ] Get magic id
[   3.0705 ] tegraparser_v2 --get_magic mb2_applet
[   3.0710 ] MB2A
[   3.0712 ] partition type mb2_applet, magic id = MB2A
[   3.0720 ] tegrahost_v2 --chip 0x23 0 --align blob_applet_t234_aligned.bin
[   3.0731 ] tegrahost_v2 --chip 0x23 0 --magicid MB2A --ratchet_blob ratchet_blob.bin --appendsigheader blob_applet_t234_aligned.bin zerosbk
[   3.0734 ] adding BCH for blob_applet_t234_aligned.bin
[   3.0808 ] tegrasign_v3.py --key None --list blob_applet_t234_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key --sha sha512
[   3.0810 ] Assuming zero filled SBK key
[   3.0824 ] Warning: pub_key.key is not found
[   3.0822 ] tegrahost_v2 --chip 0x23 0 --updatesigheader blob_applet_t234_aligned_sigheader.bin.encrypt blob_applet_t234_aligned_sigheader.bin.hash zerosbk
[   3.0842 ] Generating recovery mb2-bct
[   3.0842 ] tegrabct_v2 --chip 0x23 0 --mb2bct mb2_bct.cfg --recov --mb2bctcfg tegra234-mb2-bct-misc-p3767-0000_cpp.dtb --scr tegra234-mb2-bct-scr-p3767-0000_cpp.dtb
[   3.0845 ] ERROR: value 0x31 is out of range
[   3.0855 ] ERROR: value 0x31 is out of range
[   3.0857 ] ERROR: value 0x31 is out of range
[   3.0859 ] ERROR: value 0x31 is out of range
[   3.0860 ] WARNING: unknown property ‘tfc_version’
[   3.0862 ] WARNING: unknown property ‘addr_header_version’
[   3.0966 ] Updating mb2-bct with storage information
[   3.0969 ] tegrabct_v2 --chip 0x23 0 --mb2bct mb2_bct_MB2.bct --updatestorageinfo flash.xml.bin
[   3.0976 ] Concatenating mb2-bct to mb2 binary
[   3.0976 ] mb2_bin_file = mb2_t234.bin
[   3.0976 ] mb2_bct_file = mb2_bct_MB2.bct
[   3.0980 ] Get magic id
[   3.0983 ] tegraparser_v2 --get_magic mb2_bootloader
[   3.0985 ] MB2B
[   3.0987 ] partition type mb2_bootloader, magic id = MB2B
[   3.0995 ] tegrahost_v2 --chip 0x23 0 --align blob_mb2_t234_with_mb2_bct_MB2_aligned.bin
[   3.1002 ] tegrahost_v2 --chip 0x23 0 --magicid MB2B --ratchet_blob ratchet_blob.bin --appendsigheader blob_mb2_t234_with_mb2_bct_MB2_aligned.bin zerosbk
[   3.1004 ] adding BCH for blob_mb2_t234_with_mb2_bct_MB2_aligned.bin
[   3.1103 ] tegrasign_v3.py --key None --list blob_mb2_t234_with_mb2_bct_MB2_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key --sha sha512
[   3.1104 ] Assuming zero filled SBK key
[   3.1119 ] Warning: pub_key.key is not found
[   3.1115 ] tegrahost_v2 --chip 0x23 0 --updatesigheader blob_mb2_t234_with_mb2_bct_MB2_aligned_sigheader.bin.encrypt blob_mb2_t234_with_mb2_bct_MB2_aligned_sigheader.bin.hash zerosbk
[   3.1131 ] Get magic id
[   3.1135 ] tegraparser_v2 --get_magic xusb_fw
[   3.1137 ] XUSB
[   3.1139 ] partition type xusb_fw, magic id = XUSB
[   3.1144 ] tegrahost_v2 --chip 0x23 0 --align blob_xusb_t234_prod_aligned.bin
[   3.1150 ] tegrahost_v2 --chip 0x23 0 --magicid XUSB --ratchet_blob ratchet_blob.bin --appendsigheader blob_xusb_t234_prod_aligned.bin zerosbk
[   3.1153 ] adding BCH for blob_xusb_t234_prod_aligned.bin
[   3.1218 ] tegrasign_v3.py --key None --list blob_xusb_t234_prod_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key --sha sha512
[   3.1219 ] Assuming zero filled SBK key
[   3.1231 ] Warning: pub_key.key is not found
[   3.1228 ] tegrahost_v2 --chip 0x23 0 --updatesigheader blob_xusb_t234_prod_aligned_sigheader.bin.encrypt blob_xusb_t234_prod_aligned_sigheader.bin.hash zerosbk
[   3.1243 ] Get magic id
[   3.1246 ] tegraparser_v2 --get_magic pva_fw
[   3.1250 ] PVAF
[   3.1252 ] partition type pva_fw, magic id = PVAF
[   3.1274 ] tegrahost_v2 --chip 0x23 0 --align blob_nvpva_020_aligned.fw
[   3.1285 ] tegrahost_v2 --chip 0x23 0 --magicid PVAF --ratchet_blob ratchet_blob.bin --appendsigheader blob_nvpva_020_aligned.fw zerosbk
[   3.1290 ] adding BCH for blob_nvpva_020_aligned.fw
[   3.1670 ] tegrasign_v3.py --key None --list blob_nvpva_020_aligned_sigheader.fw_list.xml --pubkeyhash pub_key.key --sha sha512
[   3.1671 ] Assuming zero filled SBK key
[   3.1701 ] Warning: pub_key.key is not found
[   3.1700 ] tegrahost_v2 --chip 0x23 0 --updatesigheader blob_nvpva_020_aligned_sigheader.fw.encrypt blob_nvpva_020_aligned_sigheader.fw.hash zerosbk
[   3.1735 ] Kernel DTB used: kernel_tegra234-p3768-0000+p3767-0003-nv.dtb
[   3.1735 ] Concatenating kernel-dtb to dce-fw binary
[   3.1735 ] dce_bin = display-t234-dce.bin
[   3.1735 ] kernel_dtb = kernel_tegra234-p3768-0000+p3767-0003-nv.dtb
[   3.1735 ] dce_with_dtb = display-t234-dce_with_kernel_tegra234-p3768-0000+p3767-0003-nv.bin
[   3.1795 ] Get magic id
[   3.1801 ] tegraparser_v2 --get_magic dce_fw
[   3.1804 ] DCEF
[   3.1806 ] partition type dce_fw, magic id = DCEF
[   3.1860 ] tegrahost_v2 --chip 0x23 0 --align blob_display-t234-dce_with_kernel_tegra234-p3768-0000+p3767-0003-nv_aligned.bin
[   3.1866 ] tegrahost_v2 --chip 0x23 0 --magicid DCEF --ratchet_blob ratchet_blob.bin --appendsigheader blob_display-t234-dce_with_kernel_tegra234-p3768-0000+p3767-0003-nv_aligned.bin zerosbk
[   3.1868 ] adding BCH for blob_display-t234-dce_with_kernel_tegra234-p3768-0000+p3767-0003-nv_aligned.bin
[   3.3751 ] tegrasign_v3.py --key None --list blob_display-t234-dce_with_kernel_tegra234-p3768-0000+p3767-0003-nv_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key --sha sha512
[   3.3752 ] Assuming zero filled SBK key
[   3.3914 ] Warning: pub_key.key is not found
[   3.3912 ] tegrahost_v2 --chip 0x23 0 --updatesigheader blob_display-t234-dce_with_kernel_tegra234-p3768-0000+p3767-0003-nv_aligned_sigheader.bin.encrypt blob_display-t234-dce_with_kernel_tegra234-p3768-0000+p3767-0003-nv_aligned_sigheader.bin.hash zerosbk
[   3.4070 ] Get magic id
[   3.4074 ] tegraparser_v2 --get_magic nvdec
[   3.4077 ] NDEC
[   3.4079 ] partition type nvdec, magic id = NDEC
[   3.4084 ] tegrahost_v2 --chip 0x23 0 --align blob_nvdec_t234_prod_aligned.fw
[   3.4092 ] tegrahost_v2 --chip 0x23 0 --magicid NDEC --ratchet_blob ratchet_blob.bin --appendsigheader blob_nvdec_t234_prod_aligned.fw zerosbk
[   3.4094 ] Header already present for blob_nvdec_t234_prod_aligned.fw
[   3.4143 ] tegrasign_v3.py --key None --list blob_nvdec_t234_prod_aligned_sigheader.fw_list.xml --pubkeyhash pub_key.key --sha sha512
[   3.4144 ] Assuming zero filled SBK key
[   3.4162 ] Warning: pub_key.key is not found
[   3.4161 ] tegrahost_v2 --chip 0x23 0 --updatesigheader blob_nvdec_t234_prod_aligned_sigheader.fw.encrypt blob_nvdec_t234_prod_aligned_sigheader.fw.hash zerosbk
[   3.4173 ] Get magic id
[   3.4176 ] tegraparser_v2 --get_magic bpmp_fw
[   3.4179 ] BPMF
[   3.4180 ] partition type bpmp_fw, magic id = BPMF
[   3.4190 ] tegrahost_v2 --chip 0x23 0 --align blob_bpmp_t234-TE950M-A1_prod_aligned.bin
[   3.4196 ] tegrahost_v2 --chip 0x23 0 --magicid BPMF --ratchet_blob ratchet_blob.bin --appendsigheader blob_bpmp_t234-TE950M-A1_prod_aligned.bin zerosbk
[   3.4198 ] Header already present for blob_bpmp_t234-TE950M-A1_prod_aligned.bin
[   3.4314 ] tegrasign_v3.py --key None --list blob_bpmp_t234-TE950M-A1_prod_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key --sha sha512
[   3.4316 ] Assuming zero filled SBK key
[   3.4341 ] Warning: pub_key.key is not found
[   3.4340 ] tegrahost_v2 --chip 0x23 0 --updatesigheader blob_bpmp_t234-TE950M-A1_prod_aligned_sigheader.bin.encrypt blob_bpmp_t234-TE950M-A1_prod_aligned_sigheader.bin.hash zerosbk
[   3.4363 ] Using bpmp-dtb concatenated with odmdata in blob
[   3.4364 ] Get magic id
[   3.4367 ] tegraparser_v2 --get_magic bpmp_fw_dtb
[   3.4371 ] BPMD
[   3.4372 ] partition type bpmp_fw_dtb, magic id = BPMD
[   3.4377 ] tegrahost_v2 --chip 0x23 0 --align blob_tegra234-bpmp-3767-0003-3509-a02_with_odm_aligned.dtb
[   3.4384 ] tegrahost_v2 --chip 0x23 0 --magicid BPMD --ratchet_blob ratchet_blob.bin --appendsigheader blob_tegra234-bpmp-3767-0003-3509-a02_with_odm_aligned.dtb zerosbk
[   3.4387 ] adding BCH for blob_tegra234-bpmp-3767-0003-3509-a02_with_odm_aligned.dtb
[   3.4436 ] tegrasign_v3.py --key None --list blob_tegra234-bpmp-3767-0003-3509-a02_with_odm_aligned_sigheader.dtb_list.xml --pubkeyhash pub_key.key --sha sha512
[   3.4437 ] Assuming zero filled SBK key
[   3.4450 ] Warning: pub_key.key is not found
[   3.4448 ] tegrahost_v2 --chip 0x23 0 --updatesigheader blob_tegra234-bpmp-3767-0003-3509-a02_with_odm_aligned_sigheader.dtb.encrypt blob_tegra234-bpmp-3767-0003-3509-a02_with_odm_aligned_sigheader.dtb.hash zerosbk
[   3.4461 ] Get magic id
[   3.4464 ] tegraparser_v2 --get_magic rce_fw
[   3.4467 ] RCEF
[   3.4468 ] partition type rce_fw, magic id = RCEF
[   3.4474 ] tegrahost_v2 --chip 0x23 0 --align blob_camera-rtcpu-t234-rce_aligned.img
[   3.4481 ] tegrahost_v2 --chip 0x23 0 --magicid RCEF --ratchet_blob ratchet_blob.bin --appendsigheader blob_camera-rtcpu-t234-rce_aligned.img zerosbk
[   3.4483 ] adding BCH for blob_camera-rtcpu-t234-rce_aligned.img
[   3.4595 ] tegrasign_v3.py --key None --list blob_camera-rtcpu-t234-rce_aligned_sigheader.img_list.xml --pubkeyhash pub_key.key --sha sha512
[   3.4596 ] Assuming zero filled SBK key
[   3.4607 ] Warning: pub_key.key is not found
[   3.4604 ] tegrahost_v2 --chip 0x23 0 --updatesigheader blob_camera-rtcpu-t234-rce_aligned_sigheader.img.encrypt blob_camera-rtcpu-t234-rce_aligned_sigheader.img.hash zerosbk
[   3.4617 ] Get magic id
[   3.4621 ] tegraparser_v2 --get_magic ape_fw
[   3.4624 ] APEF
[   3.4626 ] partition type ape_fw, magic id = APEF
[   3.4632 ] tegrahost_v2 --chip 0x23 0 --align blob_adsp-fw_aligned.bin
[   3.4641 ] tegrahost_v2 --chip 0x23 0 --magicid APEF --ratchet_blob ratchet_blob.bin --appendsigheader blob_adsp-fw_aligned.bin zerosbk
[   3.4644 ] adding BCH for blob_adsp-fw_aligned.bin
[   3.4745 ] tegrasign_v3.py --key None --list blob_adsp-fw_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key --sha sha512
[   3.4748 ] Assuming zero filled SBK key
[   3.4763 ] Warning: pub_key.key is not found
[   3.4760 ] tegrahost_v2 --chip 0x23 0 --updatesigheader blob_adsp-fw_aligned_sigheader.bin.encrypt blob_adsp-fw_aligned_sigheader.bin.hash zerosbk
[   3.4773 ] Get magic id
[   3.4776 ] tegraparser_v2 --get_magic spe_fw
[   3.4778 ] SPEF
[   3.4781 ] partition type spe_fw, magic id = SPEF
[   3.4788 ] tegrahost_v2 --chip 0x23 0 --align blob_spe_t234_aligned.bin
[   3.4796 ] tegrahost_v2 --chip 0x23 0 --magicid SPEF --ratchet_blob ratchet_blob.bin --appendsigheader blob_spe_t234_aligned.bin zerosbk
[   3.4800 ] adding BCH for blob_spe_t234_aligned.bin
[   3.4900 ] tegrasign_v3.py --key None --list blob_spe_t234_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key --sha sha512
[   3.4901 ] Assuming zero filled SBK key
[   3.4914 ] Warning: pub_key.key is not found
[   3.4912 ] tegrahost_v2 --chip 0x23 0 --updatesigheader blob_spe_t234_aligned_sigheader.bin.encrypt blob_spe_t234_aligned_sigheader.bin.hash zerosbk
[   3.4927 ] Get magic id
[   3.4931 ] tegraparser_v2 --get_magic tos
[   3.4934 ] TOSB
[   3.4935 ] partition type tos, magic id = TOSB
[   3.4953 ] tegrahost_v2 --chip 0x23 0 --align blob_tos-optee_t234_aligned.img
[   3.4963 ] tegrahost_v2 --chip 0x23 0 --magicid TOSB --ratchet_blob ratchet_blob.bin --appendsigheader blob_tos-optee_t234_aligned.img zerosbk
[   3.4966 ] adding BCH for blob_tos-optee_t234_aligned.img
[   3.5279 ] tegrasign_v3.py --key None --list blob_tos-optee_t234_aligned_sigheader.img_list.xml --pubkeyhash pub_key.key --sha sha512
[   3.5280 ] Assuming zero filled SBK key
[   3.5314 ] Warning: pub_key.key is not found
[   3.5313 ] tegrahost_v2 --chip 0x23 0 --updatesigheader blob_tos-optee_t234_aligned_sigheader.img.encrypt blob_tos-optee_t234_aligned_sigheader.img.hash zerosbk
[   3.5351 ] Get magic id
[   3.5355 ] tegraparser_v2 --get_magic eks
[   3.5357 ] EKSB
[   3.5359 ] partition type eks, magic id = EKSB
[   3.5363 ] tegrahost_v2 --chip 0x23 0 --align blob_eks_t234_aligned.img
[   3.5369 ] tegrahost_v2 --chip 0x23 0 --magicid EKSB --ratchet_blob ratchet_blob.bin --appendsigheader blob_eks_t234_aligned.img zerosbk
[   3.5371 ] adding BCH for blob_eks_t234_aligned.img
[   3.5382 ] tegrasign_v3.py --key None --list blob_eks_t234_aligned_sigheader.img_list.xml --pubkeyhash pub_key.key --sha sha512
[   3.5383 ] Assuming zero filled SBK key
[   3.5394 ] Warning: pub_key.key is not found
[   3.5391 ] tegrahost_v2 --chip 0x23 0 --updatesigheader blob_eks_t234_aligned_sigheader.img.encrypt blob_eks_t234_aligned_sigheader.img.hash zerosbk
[   3.5402 ] tegrahost_v2 --chip 0x23 0 --generateblob blob.xml blob.bin
[   3.5405 ] The number of images in blob is 17
[   3.5408 ] blobsize is 22423344
[   3.5409 ] Added binary blob_uefi_jetson_minimal_with_dtb_sigheader.bin.encrypt of size 2060352
[   3.5485 ] Added binary blob_pscfw_t234_prod_sigheader.bin.encrypt of size 310768
[   3.5488 ] Added binary blob_mce_flash_o10_cr_prod_sigheader.bin.encrypt of size 187120
[   3.5490 ] Added binary blob_tsec_t234_sigheader.bin.encrypt of size 176128
[   3.5493 ] Added binary blob_applet_t234_sigheader.bin.encrypt of size 279808
[   3.5494 ] Not supported type: mb2_applet
[   3.5495 ] Added binary blob_mb2_t234_with_mb2_bct_MB2_sigheader.bin.encrypt of size 440944
[   3.5496 ] Added binary blob_xusb_t234_prod_sigheader.bin.encrypt of size 164864
[   3.5497 ] Added binary blob_nvpva_020_sigheader.fw.encrypt of size 2164640
[   3.5505 ] Added binary blob_display-t234-dce_with_kernel_tegra234-p3768-0000+p3767-0003-nv_sigheader.bin.encrypt of size 12070672
[   3.5553 ] Added binary blob_nvdec_t234_prod_sigheader.fw.encrypt of size 294912
[   3.5571 ] Added binary blob_bpmp_t234-TE950M-A1_prod_sigheader.bin.encrypt of size 1027008
[   3.5575 ] Added binary blob_tegra234-bpmp-3767-0003-3509-a02_with_odm_sigheader.dtb.encrypt of size 204736
[   3.5577 ] Added binary blob_camera-rtcpu-t234-rce_sigheader.img.encrypt of size 458096
[   3.5579 ] Added binary blob_adsp-fw_sigheader.bin.encrypt of size 415312
[   3.5580 ] Added binary blob_spe_t234_sigheader.bin.encrypt of size 270336
[   3.5581 ] Added binary blob_tos-optee_t234_sigheader.img.encrypt of size 1887312
[   3.5589 ] Added binary blob_eks_t234_sigheader.img.encrypt of size 9232
[   3.5675 ] Sending membct and RCM blob
[   3.5681 ] tegrarcm_v2 --chip 0x23 0 --pollbl --download bct_mem mem_rcm_sigheader.bct.encrypt --download blob blob.bin
[   3.5684 ] BL: version 1.4.0.4-t234-54845784-e89ea9bc last_boot_error: 0
[   3.5909 ] Sending bct_mem
[   3.6201 ] Sending blob
[   3.6634 ] ERROR: might be timeout in USB write.
Error: Return value 3
Command tegrarcm_v2 --chip 0x23 0 --pollbl --download bct_mem mem_rcm_sigheader.bct.encrypt --download blob blob.bin
Failed flashing generic.
for your information, hope that this can be another hint of the issue
Hi @phanycen01,
I hope you are doing well.
From your logs your Jetson is definitely in recovery mode, but this error:
means the USB connection is dropping during flashing. This is almost always caused by one of these:
  1. USB-C cable does not fully support data.
  2. Using the wrong USB-C port on the Jetson
Please try these in order:
• Use a different high-quality data-transfer USB-C cable.
• Make sure the cable is plugged into the USB-C port next to the 40-pin header
Let me know if it helps!
Best regards,
Nico
hi, i have buy and using the USB-C 3.0, but it doesn’t make it, and the error still the same one
Want to clarify. Is this your first time flashing this board?
Nope, this board already flashing before, but idk why there’s suddenly the board stop booting the nvme, so i check that the nvme is corrupt, so i format it and flashing again
~1217
please follow above link to check the serial console log during flash. This will tell what is happened on the board.
