show an error …when we try to run this script python3 test.py --target db-context.pdf --context Get_Started_With_Smallpdf-output.pdf inside the container where we made venv for script …showing an error File “/root/data/pdf-to-podcast/tests/myenv/lib/python3.10/site-packages/requests/adapters.py”, line 667, in send
resp = conn.urlopen(
File “/root/data/pdf-to-podcast/tests/myenv/lib/python3.10/site-packages/urllib3/connectionpool.py”, line 841, in urlopen
retries = retries.increment(
File “/root/data/pdf-to-podcast/tests/myenv/lib/python3.10/site-packages/urllib3/util/retry.py”, line 519, in increment
raise MaxRetryError(_pool, url, reason) from reason # type: ignore[arg-type]
urllib3.exceptions.MaxRetryError: HTTPConnectionPool(host=‘localhost’, port=8002): Max retries exceeded with url: /process_pdf (Caused by NewConnectionError(‘<urllib3.connection.HTTPConnection object at 0x7160412a4340>: Failed to establish a new connection: [Errno 111] Connection refused’))
During handling of the above exception, another exception occurred:
File “/root/data/pdf-to-podcast/tests/test.py”, line 556, in
test_api(
File “/root/data/pdf-to-podcast/tests/test.py”, line 418, in test_api
response = requests.post(process_url, files=form_data)
File “/root/data/pdf-to-podcast/tests/myenv/lib/python3.10/site-packages/requests/api.py”, line 115, in post
return request(“post”, url, data=data, json=json, **kwargs)
File “/root/data/pdf-to-podcast/tests/myenv/lib/python3.10/site-packages/requests/api.py”, line 59, in request
return session.request(method=method, url=url, **kwargs)
File “/root/data/pdf-to-podcast/tests/myenv/lib/python3.10/site-packages/requests/sessions.py”, line 589, in request
resp = self.send(prep, **send_kwargs)
File “/root/data/pdf-to-podcast/tests/myenv/lib/python3.10/site-packages/requests/sessions.py”, line 703, in send
r = adapter.send(request, **kwargs)
File “/root/data/pdf-to-podcast/tests/myenv/lib/python3.10/site-packages/requests/adapters.py”, line 700, in send
raise ConnectionError(e, request=request)
requests.exceptions.ConnectionError: HTTPConnectionPool(host=‘localhost’, port=8002): Max retries exceeded with url: /process_pdf (Caused by NewConnectionError(‘<urllib3.connection.HTTPConnection object at 0x7160412a4340>: Failed to establish a new connection: [Errno 111] Connection refused’))
…provide solution for this script “”"Test module for PDF-to-Podcast API functionality.
This module provides comprehensive testing capabilities for the PDF-to-Podcast API service,
including WebSocket status monitoring, file processing, and endpoint verification.
import requests
import os
import json as json
import time
from datetime import datetime
from threading import Thread, Event
import websockets
import asyncio
from urllib.parse import urljoin
import argparse
from typing import List
import uuid
import random
from langchain_nvidia_ai_endpoints import ChatNVIDIA
from pathlib import Path
Add global TEST_USER_ID
TEST_USER_ID = “test-userid”
Add at top of file after imports
SPEAKER_NAMES = [“Bob”, “Kate”, “Alex”, “Sarah”, “Mike”]
class StatusMonitor:
“”"Monitor WebSocket status updates for PDF-to-Podcast jobs.
This class handles WebSocket connections to track the status of PDF processing,
agent processing, and text-to-speech conversion for a specific job.
Attributes:
base_url (str): Base URL of the API service
job_id (str): Unique identifier for the job being monitored
services (set): Set of services to monitor (pdf, agent, tts)
tts_completed (Event): Event that is set when TTS processing completes
def __init__(self, base_url, job_id):
"""Initialize the status monitor.
Args:
job_id (str): Unique identifier for the job to monitor
self.base_url = base_url
self.job_id = job_id
self.ws_url = self._get_ws_url(base_url)
self.stop_event = Event()
self.services = {"pdf", "agent", "tts"}
self.last_statuses = {service: None for service in self.services}
self.tts_completed = Event()
self.websocket = None
self.reconnect_delay = 1.0
self.max_reconnect_delay = 30.0
self.ready_event = asyncio.Event()
def _get_ws_url(self, base_url):
"""Convert HTTP URL to WebSocket URL"""
if base_url.startswith("https://"):
ws_base = "wss://" + base_url[8:]
else:
ws_base = "ws://" + base_url[7:]
return urljoin(ws_base, f"/ws/status/{self.job_id}")
def get_time(self):
"""Get current time formatted as string.
Returns:
str: Current time in HH:MM:SS format
return datetime.now().strftime("%H:%M:%S")
def start(self):
"""Start the WebSocket monitoring in a separate thread"""
self.thread = Thread(target=self._run_async_loop)
self.thread.start()
def stop(self):
"""Stop the WebSocket monitoring"""
self.stop_event.set()
self.thread.join()
def _run_async_loop(self):
"""Run the asyncio event loop in a separate thread"""
loop = asyncio.new_event_loop()
asyncio.set_event_loop(loop)
loop.run_until_complete(self._monitor_status())
async def _monitor_status(self):
"""Monitor WebSocket status updates with automatic reconnection"""
while not self.stop_event.is_set():
try:
async with websockets.connect(self.ws_url) as websocket:
self.websocket = websocket
print(f"[{self.get_time()}] Connected to status WebSocket")
try:
message = await asyncio.wait_for(
websocket.recv(), timeout=30
# Handle ready check message
try:
data = json.loads(message)
if data.get("type") == "ready_check":
await websocket.send("ready")
print(
f"[{self.get_time()}] Sent ready acknowledgment"
continue
except json.JSONDecodeError:
pass
await self._handle_message(message)
except asyncio.TimeoutError:
try:
pong_waiter = await websocket.ping()
await pong_waiter
except Exception:
break
except websockets.exceptions.ConnectionClosed:
self.ready_event.clear()
if not self.stop_event.is_set():
print(
f"[{self.get_time()}] WebSocket connection closed, reconnecting..."
except Exception as e:
print(f"[{self.get_time()}] WebSocket error: {e}, reconnecting...")
await asyncio.sleep(self.reconnect_delay)
self.reconnect_delay = min(
self.reconnect_delay * 1.5, self.max_reconnect_delay
async def _handle_message(self, message):
"""Handle incoming WebSocket messages.
Args:
message (str): JSON message from WebSocket
try:
service = data.get("service")
status = data.get("status")
msg = data.get("message", "")
if service in self.services:
current_status = f"{service}: {status} - {msg}"
if current_status != self.last_statuses[service]:
print(f"[{self.get_time()}] {current_status}")
self.last_statuses[service] = current_status
if status == "failed":
print(f"[{self.get_time()}] Job failed in {service}: {msg}")
if service == "tts" and status == "completed":
self.tts_completed.set()
print(f"[{self.get_time()}] Received invalid JSON: {message}")
print(f"[{self.get_time()}] Error processing message: {e}")
def get_output_with_retry(base_url: str, job_id: str, max_retries=5, retry_delay=1):
“”"Retry getting output with exponential backoff.
Args:
job_id (str): Job ID to get output for
max_retries (int): Maximum number of retry attempts
retry_delay (int): Initial delay between retries in seconds
Returns:
bytes: Audio file content
Raises:
TimeoutError: If maximum retries exceeded
for attempt in range(max_retries):
try:
response = requests.get(
f"{base_url}/output/{job_id}", params={"userId": TEST_USER_ID}
if response.status_code == 200:
return response.content
elif response.status_code == 404:
wait_time = retry_delay * (2**attempt)
print(
f"[datetime.now().strftime('%H:%M:%S')] Output not ready yet, retrying in {wait_time:.1f}s..."
time.sleep(wait_time)
continue
else:
response.raise_for_status()
except requests.RequestException as e:
print(f"[datetime.now().strftime('%H:%M:%S')] Error getting output: {e}")
if attempt == max_retries - 1:
raise
time.sleep(retry_delay * (2**attempt))
raise TimeoutError("Failed to get output after maximum retries")
def test_saved_podcasts(base_url: str, job_id: str, max_retries=5, retry_delay=5):
“”"Test the saved podcasts endpoints with retry logic.
Args:
job_id (str): Job ID to test
Raises:
AssertionError: If any endpoint tests fail
print(
f"\n[{datetime.now().strftime('%H:%M:%S')}] Testing saved podcasts endpoints..."
# Test 1: Get all saved podcasts with retry
print("\nTesting list all podcasts endpoint...")
f"{base_url}/saved_podcasts", params={"userId": TEST_USER_ID}
assert (
), f"Failed to get saved podcasts: {response.text}"
podcasts = response.json()["podcasts"]
print(f"Found {len(podcasts)} saved podcasts")
# Check if our job_id is in the list
job_ids = [podcast["job_id"] for podcast in podcasts]
if job_id in job_ids:
print(f"Successfully found job_id {job_id} in saved podcasts list")
break
elif attempt < max_retries - 1:
print(
f"Job ID not found yet, retrying in {wait_time:.1f}s... (attempt {attempt + 1}/{max_retries})"
continue
else:
assert False, f"Recently created job_id {job_id} not found in saved podcasts after {max_retries} attempts"
# Test 2: Get specific podcast metadata
print("\nTesting individual podcast metadata endpoint...")
f"{base_url}/saved_podcast/{job_id}/metadata", params={"userId": TEST_USER_ID}
assert (
), f"Failed to get podcast metadata: {response.text}"
metadata = response.json()
print(f"Retrieved metadata for podcast: {metadata.get('filename', 'unknown')}")
print(f"Metadata: {json.dumps(metadata, indent=2)}")
# Test 3: Get specific podcast audio
print("\nTesting individual podcast audio endpoint...")
f"{base_url}/saved_podcast/{job_id}/audio", params={"userId": TEST_USER_ID}
assert response.status_code == 200, f"Failed to get podcast audio: {response.text}"
audio_data = response.content
print(f"Successfully retrieved audio data, size: {len(audio_data)} bytes")
def test_nvidia_api_key():
api_key = os.getenv(“NVIDIA_API_KEY”)
if not api_key:
raise ValueError(“NVIDIA_API_KEY needs to be set”)
config_path = Path(“./models.json”)
if config_path.exists():
with config_path.open() as f:
configs = json.load(f)
else:
raise ValueError(f"model config at path {config_path} does not exist")
for model_type in ["reasoning", "json", "iteration"]:
model = configs[model_type]
llm = ChatNVIDIA(
model=model["name"],
base_url=model["api_base"],
nvidia_api_key="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",
max_tokens=100,
response = llm.invoke(
"role": "user",
"content": "What is the capital of France? Be brief",
if "paris" not in response.content.lower():
print(f"Response {response.content} did not contain expected answer Paris")
print("Successfully validated all models with NVIDIA_API_KEY")
def test_api(
base_url: str,
target_files: List[str],
context_files: List[str],
speaker_1_name: str = None,
speaker_2_name: str = None,
monologue: bool = False,
vdb: bool = False,
“”"Test the PDF-to-Podcast API functionality.
Args:
target_files (List[str]): List of target PDF files to process
context_files (List[str]): List of context PDF files
monologue (bool): Whether to generate monologue instead of dialogue
vdb (bool): Whether to enable vector database processing
Raises:
AssertionError: If any API tests fail
Exception: For other errors during testing
voice_mapping = {
"speaker-1": "iP95p4xoKVk53GoZ742B",
if not monologue:
voice_mapping["speaker-2"] = "9BWtsMINqrJLrRacOk9x"
# Get random names if not provided
if speaker_1_name is None:
speaker_1_name = random.choice(SPEAKER_NAMES)
if speaker_2_name is None and not monologue:
# Ensure second speaker is different from first
available_names = [name for name in SPEAKER_NAMES if name != speaker_1_name]
speaker_2_name = random.choice(available_names)
# Update transcription params
transcription_params = {
"name": name,
"duration": 5,
"speaker_1_name": speaker_1_name,
"voice_mapping": voice_mapping,
"guide": None,
"monologue": monologue,
"userId": TEST_USER_ID,
"vdb_task": vdb,
if not monologue:
transcription_params["speaker_2_name"] = speaker_2_name
process_url = f"{base_url}/process_pdf"
# Update path resolution
current_dir = os.path.dirname(os.path.abspath(__file__))
project_root = os.path.dirname(current_dir)
samples_dir = os.path.join(project_root, "samples")
print(
f"\n[{datetime.now().strftime('%H:%M:%S')}] Submitting PDFs for processing..."
print(f"Using voices: {voice_mapping}")
# Prepare multipart form data
form_data = []
# Process target files
for pdf_file in target_files:
if not os.path.isabs(pdf_file):
pdf_file = os.path.join(samples_dir, pdf_file)
with open(pdf_file, "rb") as f:
content = f.read()
form_data.append(
"target_files",
(os.path.basename(pdf_file), content, "application/pdf"),
# Process context files
for pdf_file in context_files:
content = f.read()
form_data.append(
"context_files",
# Add transcription parameters
form_data.append(("transcription_params", (None, json.dumps(transcription_params))))
try:
assert (
response.status_code == 202
), f"Expected status code 202, but got {response.status_code}. Response: {response.text}"
job_data = response.json()
assert "job_id" in job_data, "Response missing job_id"
job_id = job_data["job_id"]
print(f"[{datetime.now().strftime('%H:%M:%S')}] Job ID received: {job_id}")
# Step 2: Start monitoring status via WebSocket
monitor = StatusMonitor(base_url, job_id)
monitor.start()
try:
# Wait for TTS completion or timeout
max_wait = 40 * 60
if not monitor.tts_completed.wait(timeout=max_wait):
raise TimeoutError(f"Test timed out after {max_wait} seconds")
# If we get here, TTS completed successfully
print(
f"\n[{datetime.now().strftime('%H:%M:%S')}] TTS processing completed, retrieving audio file..."
# Get the final output with retry logic
audio_content = get_output_with_retry(base_url, job_id)
# Save the audio file
output_path = os.path.join(current_dir, f"{name}.mp3")
with open(output_path, "wb") as f:
f.write(audio_content)
print(
f"[{datetime.now().strftime('%H:%M:%S')}] Audio file saved as '{output_path}'"
# Test saved podcasts endpoints with the newly created job_id
test_saved_podcasts(base_url, job_id)
# Test RAG endpoint if vdb flag is enabled
if vdb:
print("\nTesting RAG endpoint...")
test_query = "What is the main topic of this document?"
rag_response = requests.post(
f"{base_url}/query_vector_db",
json={"query": test_query, "k": 3, "job_id": job_id},
assert (
rag_response.status_code == 200
), f"RAG endpoint failed: {rag_response.text}"
rag_results = rag_response.json()
print(f"RAG Query: '{test_query}'")
print(f"RAG Results: {json.dumps(rag_results, indent=2)}")
finally:
monitor.stop()
print(f"Error during PDF submission: {e}")
raise
if name == “main”:
parser = argparse.ArgumentParser(
description=“Process PDF files for audio conversion”,
formatter_class=argparse.RawDescriptionHelpFormatter,
epilog=“”"
Examples:
# Process with target and context files
python test.py --target main.pdf --context context1.pdf context2.pdf
# Process with only context files
python test.py --context file1.pdf file2.pdf file3.pdf
# Process with multiple target files
python test.py --target target1.pdf target2.pdf --context context1.pdf
parser.add_argument(
"--name",
default=str(uuid.uuid4()),
help="Name of the generated podcast",
"--target",
nargs="+",
default=[],
help="PDF files to use as targets",
metavar="PDF",
"--context",
nargs="+",
default=[],
help="PDF files to use as context",
metavar="PDF",
"--api-url",
default=os.getenv("API_SERVICE_URL", "http://localhost:8002"),
help="API service URL (default: from API_SERVICE_URL env var or http://localhost:8002)",
"--monologue",
action="store_true",
help="Generate a monologue instead of a dialogue",
"--vdb",
help="Enable Vector Database processing",
"--speaker1",
help=f"Name for speaker 1 (default: random from {SPEAKER_NAMES})",
"--speaker2",
help=f"Name for speaker 2 (default: random from {SPEAKER_NAMES})",
args = parser.parse_args()
# Validate that at least one file was provided
if not args.target and not args.context:
parser.error(
"At least one PDF file must be provided (either target or context)"
print(f"API URL: {args.api_url}")
print(f"Target PDF files: {args.target}")
print(f"Context PDF files: {args.context}")
print(f"Monologue mode: {args.monologue}")
print(f"VDB mode: {args.vdb}")
print(f"Using test user ID: {TEST_USER_ID}")
test_api(
args.api_url,
args.name,
args.target,
args.context,
speaker_1_name=args.speaker1,
speaker_2_name=args.speaker2,
monologue=args.monologue,
vdb=args.vdb,
