I2C-8 bus missing in Xavier NX devkit board
Hi, everyone, I used Xavier NX devkit with R35.3.1. But I met a boot kernel ops while using, it looks like the same situation in
So I did the same change in dtb file and the problem didn’t show again. But there is another question is that the disabled node dpaux@155F0000 seems controls I2C-8(i2c@31e0000) pinmux. After disable it, I can detect I2C-8 using i2cdetect. But I want to use it to test my i2c device.
In this topic, it shows that i2c-8 pin can not be controlled by pinmux.cfg
Do you konw how to fix it? Can I modify the dtb file to make i2c enable but not enable node dpaux@155F0000?
nvidia@nvidia:~/test$ sudo i2cdetect -l
i2c-3   i2c             3190000.i2c                             I2C adapter
i2c-10  i2c             i2c-2-mux (chan_id 1)                   I2C adapter
i2c-1   i2c             c240000.i2c                             I2C adapter
i2c-101 i2c             15210000.display                        I2C adapter
i2c-6   i2c             31c0000.i2c                             I2C adapter
i2c-4   i2c             Tegra BPMP I2C adapter                  I2C adapter
i2c-2   i2c             3180000.i2c                             I2C adapter
i2c-0   i2c             3160000.i2c                             I2C adapter
i2c-9   i2c             i2c-2-mux (chan_id 0)                   I2C adapter
i2c-7   i2c             c250000.i2c                             I2C adapter
i2c-5   i2c             31b0000.i2c                             I2C adapter
What did you do?
remove this node from device tree
dpaux@155F0000 {
            status = "disabled";
Doesn’t looks like remove that was the solution for that.
Please using the J5.0.2 UEFI for the kernel oops.
please refer to this patch.
Thank you for help, I apply this patch and use the original device tree. There is no such kernel ops in 10 times reboot flow. I think this patch can solve the kernel ops problem and I can use the I2C-8 as well.
And do you know why this problem happens using the original kernel source? Is it due to the powergate from your patch?
Yes, it is a known issue from xavier display driver.
So when we use the Jetson_Linux_R35.3.1_aarch64.tbz2 downloaded from NVIDIA and don’t change anything, this issue will come out in some time?
Because I flash the R35.3.1 to Xavier NX devkit and use for about two days before the issue occur。
Yes, this is intermittent issue.
ok, and thank you again for explanation.
