From datasheet of JetsonAGXXavierSeriesDatasheet_DS09654001v1.1,in open drain pin, I2C output low voltage(Iol=3.3mA) is 0.3xVDD,but output low voltage(Iol=1mA) is 0.15xVDD.We use I2C2_CLK/Data as I2C communicate with a device,which is pulled up 2K to 1.8V,and which paramater we should choose as consideration of Vol(0.3xVDD or 0.15xVDD) ?
From datasheet of JetsonAGXXavierSeriesDatasheet_DS09654001v1.1,in open drain pin, I2C output low voltage(Iol=3.3mA) is 0.3xVDD,but others output low voltage(Iol=1mA) is 0.15xVDD.We use I2C2_CLK/Data as I2C communicate with a device,which is pulled up 2K to 1.8V,and which paramater we should choose as consideration of Vol(0.3xVDD or 0.15xVDD) ?
Look foward to your reply!
Hi
For i2c bus, the max of Vol is 0.3*VDD at 3.3mA sink current.
0.3 x VDD is better for that.
Got it!Thanks.
