I’m not entirely sure on how to interpret the following part of a datasheet of a motor driver:
LOGIC-LEVEL INPUTS AND OUTPUTS
VIL Low-level input voltage Max: 0.8 V
VIH High-level input voltage Min: 1.5 Max: 5.5 V
IIL Low-level input current Min: –50 Max: 50 µA
IIH High-level input current(VIN = 3.3 V, DIR, BRAKE, PWM) Min: 20 Max: 100 µA
(VIN = 3.3 V, ENABLEn) Min: 6 Max: 9 µA
RPD Input pulldown resistance (DIR, BRAKE, PWM) Min: 50 Max: 150 kΩ
(ENABLEn) Min: 350 Max: 550 kΩ
OPEN DRAIN OUTPUTS
VOL Low-level output voltage (IOUT = 2.0 mA) 0.5 V
IOH Output leakage current (VOUT = 3.3V): 1 µA
Does this mean that I can’t directly connect these pins to the majority of GPIO pins on the J21 header of the Jetson Tx1 since the maximum drive current capability of those pins are -20/20 µA? If so, what would be the simplest solution to make the motor driver compliant?
