HiSir,
what is the maximum driving current of the MPIO on TX2?
If we use an external pull-down resistor of 100Ohm on 1.8V output high pin, the current will be 18mA, will it break the MPIO?
Eric
HiSir,
Eric
Hi, please check chapter of Pad Drive Strength in TX2 OEM DG. [url]https://developer.nvidia.com/embedded/dlc/jetson-tx2-oem-product-designguide[/url]
ok thanks.~
