Into Jetson Nano Orin what is the max current that the single GPIO pin provides ? Where I can found this info?
It’s generally 1mA and can be up to 2mA for some pins. You can find that in carrier board specification doc in DLC.
Thank you for reply.
In the document Jetson Orin Nano Developer Kit Carrier Board section “40-Pin Expansion Header” is write Pin Max Current ±20uA for most pins (is “uA” microampere?). Where am I wrong?
Hey,
can anyone confirm the max output current for GPIO pins for Jetson Orin Nano
“20uA” is becasue the pins are routed to a level shift on devkit board.
