I am working on Xavier NX Devkit with I2S5 port on 40-pin Connector. I have configured the I2S5 to be master on Xavier, such that LRCLK is generated by Xavier. Everything works ok with 32-bit audio recording, but for 16-bit audio recording the I2S bit clock is not correct.
The audio hardware which I connected to the 40-pin header is Respeaker 2-Mic HAT board and we use the driver from this repository.
(1) What works fine:
When I try to record a 32K 32-bit stereo audio,
word clock is 32 KHz as expected.
bit clock is 2MHz as expected.
(2) What does not work fine:
When I try to record a 32K 16-bit stereo audio,
bit clock is still 2MHz, though we would expect it to be 1 MHz.
Since bit clock is incorrect the audio codec has problem sending the Right channel data correctly. As a consequence the right channel data in the recording gets messed up - its all noise. Left channel data gets recorded correctly.
I have attached the clock summary, and amixer contents dump while making 16-bit recording.
32khz_16_bits_clk_summary.txt (34.1 KB)
32khz_16_bits_amixer_contents.txt (293.7 KB)
Is there anything which looks obviously wrong in our alsa settings?
Thanks and Regards,
KS
