IGX Thor mini - CCPLEX GPIO Toggle Issue
Hi NVIDIA Team,
I am working with the NVIDIA IGX Thor Developer Kit Mini (T5000) and testing GPIO42 (F59 / PEE.00), which is directly connected to test point TP235.
I configured GPIO42 through the pinmux as GPIO-output and flashed the updated configuration.
I am using the following commands to toggle the GPIO:
nvidia@nvidia:~$ gpioinfo | grep PEE.00
    line 26:     "PEE.00"       unused   output  active-high
nvidia@nvidia:~$ sudo gpioset --mode=wait gpiochip0 26=1
[sudo] password for nvidia:
^C
nvidia@nvidia:~$ sudo gpioset --mode=wait gpiochip0 26=0
^C
nvidia@nvidia:~$
nvidia@nvidia:~$ sudo cat /sys/kernel/debug/gpio | grep PEE.00
 gpio-538 (PEE.00              |gpioset             ) out hi
 gpio-538 (PEE.00              |gpioset             ) out lo
nvidia@nvidia:~$
However, when measuring TP235 with a multimeter, I get approximately 3.3 V in both cases. The physical pin does not appear to toggle.
Could you please clarify:
  1. Is this the right way of toggling the ccplex gpio’s?
  2. Does the STRAP function (mentioned in devkit usage column in pinmux excel) of GPIO42 prevent it from being toggled at runtime?
  3. Is any additional pinmux/pad configuration required for the GPIO output to reach TP235?
  4. Why does debug report shows out hi and out lo while the physical pin remains at ~3.3 V?
Regards,
Bala Adithiya
Hi balaadithiya.s,
Please configure it as Drive 0 or Drive 1 instead of N/A for the Output pin in pinmux spreadsheet.
