What is the default image encoding when i export images out of Isaac SIM using ROS1? Is it bgr8
I am using the images further in my project in a deep learning application and apparently, the image encoding is an issue. I have tried cv2.cvtColor()
to convert the image to RGB but still getting wrong results. Can someone explain what is the format or encoding of the images are so that I can address the issue accordingly.
@a.imrantw i am not as experienced, but wonder if these are relevant:
https://docs.omniverse.nvidia.com/isaacsim/latest/ros_tutorials/tutorial_ros_camera_publishing.html
https://docs.omniverse.nvidia.com/isaacsim/latest/ros_tutorials/tutorial_ros_camera.html
