thank you for fixing the ROS Camera Pointcloud Publisher in the latest release!
How i see it, it’s only possible to publish a mono Pointcloud while i need a RGB Pointcloud.
There is a workaround with http://wiki.ros.org/image_proc or probably PCL, too. This works, however it is quite resource-intensive.
Therefore my question: Is it possible to publish a RGB Pointcloud natively from Isaac Sim?
Otherwise i would appreciate it if it would be added in a future release.
