How to visualize a pointcloud in realtime from a camera
I want to visualize the pointcloud from my camera and import it into my isaac sim scene. I have found way to import a precomputed pointcloud but nothing realtime.
Is there any way to do this ?
Hi @09ubberboy90 - This document will you regarding that: 12. Publish RTX Lidar Point Cloud β€” Omniverse IsaacSim latest documentation
Sorry but this not what I want. This is Isaac β†’ ROS and I want ROS β†’ Isaac
Hi @09ubberboy90 - We do not support that currently in Isaac Sim.
Hi! Do you still not support it or it is possible now?
Hi @rthaker ! Do you still not support it or it is possible now?
Hi there,
you can use debug draw to visualize the pointclouds:
Let me know if you need further assitance.
Cheers
Thanks! I find it previously but how can i connect it with a ros2 (generic) subscriber (PointCloud2) which output data can not be connected with just a wire. :( What should i do?
How can I integrate a Python script like this into the graph to connect it to a ROS2 subscriber? Because the example provided here Debug Drawing [omni.isaac.debug_draw] β€” isaac_sim 4.2.0-rc.17 documentation for points doesn’t work for me. Or should I write the script together with the ROS2 subscriber in one piece and not integrate it into the graph at all? If so, how can I do that? How do I add the β€œon playback tick” and the ROS2 context? Should that also be written directly into the script?
How can i connect a ros2 subscriber (wich subscribed to a pointcloud2 data format) whoch output data is uint and the isaac debug draw point cloud input data ptr is uint64 !!!
Maybe this is helpful: RTX Lidar Sensors β€” Omniverse IsaacSim
