I built a custom driver for my camera,
The image seems to be upside down.
The vertical-flip is set to 0;
the readout-orientation is also set to 0;
Is there anything else need to be done. ??
It seems to be an issue in sensor driver. Please check if you can flip it in source. It not, you can use nvvidconv plugin(or call NvBufferTransform() in jetson_multimedia_api) to flip the frames.
