Improper movement of joints during UR arm articulation on a mobile base
Hello everyone,
I wanted to move a UR3 arm attached to a mobile robot base from one set of joint positions to another set of joint positions. But the arm movement is happening in a weird way. Can anyone check the demo given in the video here. Video here !
The script running is given here :
from omni.isaac.kit import SimulationApp
simulation_app = SimulationApp({"headless": False})
from omni.isaac.core import World
from omni.isaac.core.utils.stage import add_reference_to_stage
from omni.isaac.core.robots import Robot
from omni.isaac.core.utils.types import ArticulationAction
from omni.isaac.core.utils.transformations import tf_matrix_from_pose,pose_from_tf_matrix
from husky_ur3_whole_body_handler import Husky_UR3_Whole_Body_Handler
from tiago_dual_WB_handler import TiagoDualWBHandler
from husky_ur3_robot_2 import Husky_UR3_Robot
from husky_wheel_controller import HuskyController
import numpy as np
# husky_ur_handler = Husky_UR3_Whole_Body_Handler()
# robot = husky_ur_handler.get_robot()
my_world = World(stage_units_in_meters=1.0)
initial_posture = np.array([-3.4930844,-1.7593288, -1.2764046, -1.676637, 1.5707291, -1.9221054])
vel = np.array([0.5,-0.5,-0.5,-0.5,0.5,0.5])
final_posture = np.array([1.0528518, -1.8536792, -0.02006058, -0.7816168, 1.2877516, 1.8681929])
delta = (final_posture-initial_posture)/100
my_robot = my_world.scene.add(
      Husky_UR3_Robot(prim_path="/World/Husky_UR3",
                      usd_path="/home/bikram/husky_ur3.usd",
                      name = "Husky_UR3")
my_world.scene.add_default_ground_plane()
#my_controller = HuskyController(name="simple_control", wheel_radius=0.03, wheel_base=0.1125)
my_world.reset()
my_robot.initialize()
while simulation_app.is_running():
    if my_world.is_playing():
      if my_world.current_time_step_index == 0:             # in this line if we add "simulation_context.current_time_step_index == 0:" it would still work because Simulation Context() has the same function as World() has...
            my_world.reset()
            #my_controller.reset()
      my_robot.set_joint_positions(positions = initial_posture, joint_indices = my_robot.ur_arm_dof_indices)
      for i in range(10000):
          my_world.step(render=True)
          my_robot.apply_arm_actions(ArticulationAction(joint_positions = initial_posture + i*delta, joint_velocities = vel, joint_efforts = vel))
      print("ok")
simulation_app.close()
The Robot class that I used is :
This is another trial of writing the Husky_UR3_robot class.
import carb
from typing import Optional
import numpy as np
from omni.isaac.core.robots.robot import Robot
from omni.isaac.core.utils.prims import get_prim_at_path, define_prim
class Husky_UR3_Robot(Robot):
    def __init__(self,
                 prim_path : str,
                 usd_path: str,
                 position: Optional[np.ndarray] = None,
                 orientation: Optional[np.ndarray] = None,
    ) -> None:
      #   prim = get_prim_at_path(prim_path)
      #   if not prim.IsValid():
      #       prim = define_prim(prim_path, "Xform")
      #       prim.GetReferences().AddReference(usd_path)
        add_reference_to_stage(usd_path, prim_path)
        super().__init__(prim_path=prim_path, name=name, position=position, orientation=orientation, articulation_controller=None)
        self._husky_base_joint_names = ["front_left_wheel",
                                      "front_right_wheel",
                                      "rear_left_wheel",
                                      "rear_right_wheel"]
        self._husky_dof_idxs = []
        self._ur_joint_names = ["ur_arm_shoulder_pan_joint",
                                    "ur_arm_shoulder_lift_joint",
                                    "ur_arm_elbow_joint",
                                    "ur_arm_wrist_1_joint",
                                    "ur_arm_wrist_2_joint",
                                    "ur_arm_wrist_3_joint"]
        self._ur_arm_dof_idxs = []
        self._num_dof = len(self._husky_base_joint_names) + len(self._ur_joint_names)
    @property
    def husky_wheel_dof_indices(self):
        return self._husky_dof_idxs
    @property
    def ur_arm_dof_indices(self):
        return self._ur_arm_dof_idxs
    def apply_wheel_actions(self, actions : ArticulationAction) -> None:
        actions_length = actions.get_length()
        if actions_length is not None and actions_length != self._num_wheel_dof:
            raise Exception("ArticulationAction passed should be the same length as the number of wheels")
        joint_actions = ArticulationAction()
        if actions.joint_positions is not None:
            joint_actions.joint_positions = np.zeros(self._num_dof)
            for i in range(self._num_wheel_dof):
                joint_actions.joint_positions[self._husky_dof_idxs[i]] = actions.joint_postions[i]
        if actions.joint_velocities is not None:
            joint_actions.joint_velocities = np.zeros(self._num_dof)
                joint_actions.joint_velocities[self._husky_dof_idxs[i]] = actions.joint_velocities[i]
        if actions.joint_efforts is not None:
            joint_actions.joint_efforts = np.zeros(self._num_dof)
                joint_actions.joint_efforts[self._husky_dof_idxs[i]] = actions.joint_efforts[i]
        self.apply_action(control_actions = joint_actions)
        return
    def apply_arm_actions(self, actions:ArticulationAction) -> None:
        if actions_length is not None and actions_length != self._num_dof_ur:
            raise Exception("ArticulationAction passed should be the same length as the number of UR joints")
            for i in range(self._num_dof_ur):
                joint_actions.joint_positions[self._ur_arm_dof_idxs[i]] = actions.joint_positions[i]
                joint_actions.joint_velocities[self._ur_arm_dof_idxs[i]] = actions.joint_velocities[i]
                joint_actions.joint_efforts[self._ur_arm_dof_idxs[i]] = actions.joint_efforts[i]
        return
    def initialize(self, physics_sim_view=None) -> None:
        super().initialize(physics_sim_view=physics_sim_view)
        if self._ur_joint_names is not None:
                self.get_dof_index(self._ur_joint_names[i]) for i in range(len(self._ur_joint_names))
        elif self._ur_arm_dof_idxs is None:
            carb.log_error("need to have either arm joint names or joint indices")
        if self._husky_base_joint_names is not None:
                self.get_dof_index(self._husky_base_joint_names[i]) for i in range(len(self._husky_base_joint_names))
        elif self._husky_dof_idxs is None:
            carb.log_error("need to have either wheel names or wheel indices")
        self._num_dof_ur = len(self._ur_arm_dof_idxs)
        self._num_wheel_dof = len(self._husky_dof_idxs)
        return
    def post_reset(self) -> None:
        Robot.post_reset(self)
        #if self._articulation_controller is not None:
        self._articulation_controller.switch_control_mode(mode="position")
        return
Please can anyone tell me, how can I make a good movement of the robot arm.
I have solved this issue by myself. The articulation controller is not tuned properly in this example. I studied the UR10 pick_pick_place_using_ik_solver in the standalone examples and checked out the kps and kds value and I set the kps and kds value of the UR10 to my Robot UR3.
 my_robot.get_articulation_controller().set_gains(kps = np.array([5.729578e+08, 5.729578e+08, 5.729578e+08, 5.729578e+08, 5.729578e+08, 5.729578e+08, 0, 0, 0, 0]), kds = np.array([5729578., 5729578., 5729578., 5729578., 5729578., 5729578., 5.729578e+08, 5.729578e+08, 5.729578e+08, 5.729578e+08]))
and now it works fine. BTW the last 4 values of the kps and kds are the parameters for the 4 wheel joints.
Thanks and Regards,
Tribikram.
If anyone faces this similar issue feel free to ping me in the forum.
