Custom Robot Arm not reaching target while using RMP Flow | Imprecise control of robotic arm
I want to integrate a UR3 (Universal Robot) arm on a movable Clearpath Husky base to create a custom mobile manipulator and I would like to use the RMP flow algorithm of Nvidia to make the robot arm reach a target position, I had previously posted on the forum regarding the issue I am facing, however I made some changes in the python script
Current situation, please check out the YouTube video in the given link.
Issue video-Read the description of the video as well
While using controlling the robotic arm using the RMP flow the Lula is considering a different kinematic object(structure) and not the robot while generating articulation actions.
This is the running Python script for the video given above.
from omni.isaac.kit import SimulationApp
simulation_app = SimulationApp({"headless": False})
from omni.isaac.franka.tasks import FollowTarget
from omni.isaac.motion_generation.lula import RmpFlow
from omni.isaac.motion_generation import ArticulationMotionPolicy
from omni.isaac.core import World
from omni.isaac.core.objects import sphere
from omni.isaac.core.utils.extensions import get_extension_path_from_name
from robot_utils.husky_controller import HuskyController
from follow_target_husky_ur3_rmpFlow import FollowTarget
from robot_utils.ur3_rmpF_controller import RMPFlowController
from customised_task import CustomTask
import numpy as np
import os
my_world = World(stage_units_in_meters=1.0)
my_task = CustomTask(name = "task",offset=None)
my_world.add_task(my_task)
my_world.reset()
task_params = my_world.get_task("task").get_params()
robot_name = task_params["robot_name"]["value"]
target_name = task_params["target_name"]["value"]
my_robot = my_world.scene.get_object(robot_name)
# RMPflow config files for supported robots are stored in the motion_generation extension under "/motion_policy_configs"
mg_extension_path = get_extension_path_from_name("omni.isaac.motion_generation")
rmp_config_dir = os.path.join(mg_extension_path, "motion_policy_configs")
#Initialize an RmpFlow object
my_robot.ur_initialize()
rmpflow = RmpFlow(
    robot_description_path = "./husky_ur3/rmpflow/config_2.yaml",
    urdf_path = "./husky_ur3/husky_ur3.urdf",
    rmpflow_config_path = "./husky_ur3/rmpflow/husky_ur3_rmpflow_config.yaml",
    end_effector_frame_name = "ur_arm_flange",
    maximum_substep_size = 0.00334
#Use the ArticulationMotionPolicy wrapper object to connect rmpflow to the Franka robot articulation.
physics_dt = 1/60.
articulation_rmpflow = ArticulationMotionPolicy(my_robot,rmpflow,physics_dt)
#create and add an obstacle from omni.isaac.core.objects
# sphere_obstacle = sphere.FixedSphere("/sphere_obstacle",radius=.03,position=np.array([0.1, 0.0, 0.5]),color=np.array([0.,0.,1.]))
# rmpflow.add_obstacle(sphere_obstacle)
# rmpflow.set_ignore_state_updates(True)
# rmpflow.visualize_collision_spheres()
articulation_controller = my_robot.get_articulation_controller()
rmpflow.visualize_end_effector_position()
# bad_proportional_gains = articulation_controller.get_gains()[0]/50
# articulation_controller.set_gains(kps = bad_proportional_gains)
while simulation_app.is_running():
    my_world.step(render=True)
    if my_world.is_playing():
        if my_world.current_time_step_index == 0:
            my_world.reset()
        observations = my_world.get_observations()
        #Set rmpflow target to be the current position of the target cube.
        y = -observations[target_name]["position"][1]
        rmpflow.set_end_effector_target(
            target_position=np.array([observations[target_name]["position"][0],y,observations[target_name]["position"][2]]),
            target_orientation=observations[target_name]["orientation"],
        rmpflow_end_effector_prim = rmpflow.get_end_effector_as_prim()
        x,y = rmpflow_end_effector_prim.get_world_pose()
        # print(x,y)
        # print(rmpflow.get_end_effector_as_prim())
        #print(my_robot.get_end_effector)
        #Track any movements of the sphere obstacle
        rmpflow.update_world()
        #Track any movements of the robot base
        robot_base_translation,robot_base_orientation = my_robot.base_ur.get_world_pose()
        rmpflow.set_robot_base_pose(robot_base_translation,robot_base_orientation)
        actions = articulation_rmpflow.get_next_articulation_action()
        articulation_controller.apply_action(actions)
        print(my_task.target_reached())
simulation_app.close()
You can check how I hard coded the cube y cordinate as -y to make the end effector move in the while loop. As you can see in the video while the actual end effector is moving towards +y direction the lula end effector is moving towards -y direction.
I would be obliged if you help me out in setting up the robot and use RMP flow to reach a target object.
If you require any other code you can check the topic here
Robot collision sphere moved from robot while using RMPflow
Thanks in advance.
I think the code structure is correct so far. I have a similar task implemented with RMPflow in the same structure. what happens if you simply pass the position and orientation of the observation to the method rmpflow.set_end_effector_target()?
Something like this:
            my_world.reset()
            target_position=observations[target_name]["position"],
Robin
The robotic arm moves towards +y if the target is moved towards -y, but the Lula end effector moves towards the direction of the target cube. Check the gray cuboid in the video.
Here is the link for the video.
video
What problem do you have with the implemented RMP flow algo ??
Regards,
T.
sorry it was poorly written. I had no problems with the implementation. I tried it with a UR10 and a UR5e.
Can you provide the files for the RMPFlow() object? (robot_description, urdf_path, rmpflow_config_path).
Sure, here you go.
husky_ur3_config_files.zip (12.0 KB)
robot_util_files.zip (9.3 KB)
These are the .py files and it also contains the USD of the scene.
I have looked at the files, I have not noticed anything out of the ordinary, could you try replacing the config_2.yaml with the following content?
# The robot description defines the generalized coordinates and how to map those
# to the underlying URDF dofs.
api_version: 1.0
# Defines the generalized coordinates. Each generalized coordinate is assumed
# to have an entry in the URDF.
# Lula will only use these joints to control the robot position.
cspace:
    - ur_arm_shoulder_pan_joint
    - ur_arm_shoulder_lift_joint
    - ur_arm_elbow_joint
    - ur_arm_wrist_1_joint
    - ur_arm_wrist_2_joint
    - ur_arm_wrist_3_joint
default_q: [0.0,-0.785,-1.5707,-2.356,-1.5707,-1.5707]
# Most dimensions of the cspace have a direct corresponding element
# in the URDF. This list of rules defines how unspecified coordinates
# should be extracted or how values in the URDF should be overwritten.
cspace_to_urdf_rules:
    - {name: front_left_wheel, rule: fixed, value: 0.0}
    - {name: front_right_wheel, rule: fixed, value: 0.0}
    - {name: rear_left_wheel, rule: fixed, value: 0.0}
    - {name: rear_right_wheel, rule: fixed, value: 0.0}
# Lula uses collision spheres to define the robot geometry in order to avoid
# collisions with external obstacles.  If no spheres are specified, Lula will
# not be able to avoid obstacles.
collision_spheres:
  - ur_arm_base_link_inertia:
    - "center": [0.0, 0.0, 0.0]
      "radius": 0.08
  - ur_arm_shoulder_link:
      "radius": 0.07
    - "center": [0.013, 0.014, -0.07]
      "radius": 0.04
  - ur_arm_upper_arm_link:
    - "center": [-0.002, -0.003, 0.143]
      "radius": 0.07
    - "center": [-0.234, -0.0, 0.131]
      "radius": 0.06
    - "center": [-0.063, -0.002, 0.14]
      "radius": 0.067
    - "center": [-0.122, -0.001, 0.137]
      "radius": 0.065
    - "center": [-0.179, -0.001, 0.134]
      "radius": 0.062
  - ur_arm_forearm_link:
    - "center": [-0.0, -0.0, 0.045]
      "radius": 0.05
    - "center": [-0.201, -0.0, 0.03]
      "radius": 0.05
    - "center": [-0.04, -0.0, 0.042]
      "radius": 0.05
    - "center": [-0.08, -0.0, 0.039]
      "radius": 0.05
    - "center": [-0.12, -0.0, 0.036]
      "radius": 0.05
    - "center": [-0.161, -0.0, 0.033]
      "radius": 0.05
  - ur_arm_wrist_1_link:
      "radius": 0.05
  - ur_arm_wrist_2_link:
      "radius": 0.045
  - ur_arm_wrist_3_link:
      "radius": 0.04
  - base_link:
    - "center": [-0.32, 0.145, -0.0]
      "radius": 0.05
    - "center": [-0.333, -0.142, -0.0]
      "radius": 0.05
    - "center": [-0.322, 0.097, -0.0]
      "radius": 0.05
    - "center": [-0.324, 0.049, -0.0]
      "radius": 0.05
    - "center": [-0.326, 0.002, -0.0]
      "radius": 0.05
    - "center": [-0.329, -0.046, -0.0]
      "radius": 0.05
    - "center": [-0.331, -0.094, -0.0]
      "radius": 0.05
    - "center": [0.339, -0.165, 0.0]
      "radius": 0.05
    - "center": [-0.256, -0.144, -0.0]
      "radius": 0.05
    - "center": [-0.179, -0.147, -0.0]
      "radius": 0.05
    - "center": [-0.101, -0.149, -0.0]
      "radius": 0.05
    - "center": [-0.024, -0.152, -0.0]
      "radius": 0.05
    - "center": [0.053, -0.155, 0.0]
      "radius": 0.05
    - "center": [0.131, -0.157, 0.0]
      "radius": 0.05
    - "center": [0.208, -0.16, 0.0]
      "radius": 0.05
    - "center": [0.285, -0.163, 0.0]
      "radius": 0.05
    - "center": [0.332, 0.142, 0.0]
      "radius": 0.05
    - "center": [-0.247, 0.145, -0.0]
      "radius": 0.05
    - "center": [-0.175, 0.144, -0.0]
      "radius": 0.05
    - "center": [-0.102, 0.144, -0.0]
      "radius": 0.05
    - "center": [-0.03, 0.144, -0.0]
      "radius": 0.05
    - "center": [0.043, 0.143, 0.0]
      "radius": 0.05
    - "center": [0.115, 0.143, 0.0]
      "radius": 0.05
    - "center": [0.187, 0.143, 0.0]
      "radius": 0.05
    - "center": [0.26, 0.143, 0.0]
      "radius": 0.05
    - "center": [0.338, -0.114, 0.0]
      "radius": 0.05
    - "center": [0.337, -0.063, 0.0]
      "radius": 0.05
    - "center": [0.336, -0.011, 0.0]
      "radius": 0.05
    - "center": [0.335, 0.04, 0.0]
      "radius": 0.05
    - "center": [0.334, 0.091, 0.0]
      "radius": 0.05
    - "center": [0.264, -0.112, 0.0]
      "radius": 0.05
    - "center": [0.19, -0.109, 0.0]
      "radius": 0.05
    - "center": [0.115, -0.107, 0.0]
      "radius": 0.05
    - "center": [0.041, -0.105, 0.0]
      "radius": 0.05
    - "center": [-0.034, -0.103, -0.0]
      "radius": 0.05
    - "center": [-0.108, -0.101, -0.0]
      "radius": 0.05
    - "center": [-0.182, -0.098, -0.0]
      "radius": 0.05
    - "center": [-0.257, -0.096, -0.0]
      "radius": 0.05
    - "center": [0.263, -0.061, 0.0]
      "radius": 0.05
    - "center": [0.189, -0.059, 0.0]
      "radius": 0.05
    - "center": [0.115, -0.057, 0.0]
      "radius": 0.05
    - "center": [0.041, -0.055, 0.0]
      "radius": 0.05
    - "center": [-0.033, -0.053, -0.0]
      "radius": 0.05
    - "center": [-0.107, -0.052, -0.0]
      "radius": 0.05
    - "center": [-0.181, -0.05, -0.0]
      "radius": 0.05
    - "center": [-0.255, -0.048, -0.0]
      "radius": 0.05
    - "center": [0.262, -0.01, 0.0]
      "radius": 0.05
    - "center": [0.189, -0.009, 0.0]
      "radius": 0.05
    - "center": [0.115, -0.007, 0.0]
      "radius": 0.05
    - "center": [0.042, -0.006, 0.0]
      "radius": 0.05
    - "center": [-0.032, -0.004, -0.0]
      "radius": 0.05
    - "center": [-0.106, -0.003, -0.0]
      "radius": 0.05
    - "center": [-0.179, -0.001, -0.0]
      "radius": 0.05
    - "center": [-0.253, 0.0, -0.0]
      "radius": 0.05
    - "center": [0.262, 0.041, 0.0]
      "radius": 0.05
    - "center": [0.188, 0.042, 0.0]
      "radius": 0.05
    - "center": [0.115, 0.043, 0.0]
      "radius": 0.05
    - "center": [0.042, 0.044, 0.0]
      "radius": 0.05
    - "center": [-0.031, 0.045, -0.0]
      "radius": 0.05
    - "center": [-0.105, 0.046, -0.0]
      "radius": 0.05
    - "center": [-0.178, 0.047, -0.0]
      "radius": 0.05
    - "center": [-0.251, 0.048, -0.0]
      "radius": 0.05
    - "center": [0.261, 0.092, 0.0]
      "radius": 0.05
    - "center": [0.188, 0.092, 0.0]
      "radius": 0.05
    - "center": [0.115, 0.093, 0.0]
      "radius": 0.05
    - "center": [0.042, 0.094, 0.0]
      "radius": 0.05
    - "center": [-0.031, 0.094, -0.0]
      "radius": 0.05
    - "center": [-0.103, 0.095, -0.0]
      "radius": 0.05
    - "center": [-0.176, 0.096, -0.0]
      "radius": 0.05
    - "center": [-0.249, 0.096, -0.0]
      "radius": 0.05
  - rear_right_wheel_link:
      "radius": 0.16
  - rear_left_wheel_link:
      "radius": 0.16
  - front_left_wheel_link:
      "radius": 0.16
  - front_right_wheel_link:
      "radius": 0.16
  - top_plate_link:
    - "center": [-0.247, 0.156, 0.003]
      "radius": 0.023
    - "center": [-0.06, 0.065, 0.003]
      "radius": 0.023
    - "center": [0.056, 0.255, 0.003]
      "radius": 0.023
    - "center": [0.013, 0.126, 0.003]
      "radius": 0.023
    - "center": [-0.324, 0.168, 0.003]
      "radius": 0.023
    - "center": [-0.046, -0.286, 0.003]
      "radius": 0.023
    - "center": [0.352, 0.154, 0.003]
      "radius": 0.023
    - "center": [-0.132, 0.084, 0.003]
      "radius": 0.023
    - "center": [0.32, 0.008, 0.003]
      "radius": 0.023
    - "center": [-0.292, 0.109, 0.003]
      "radius": 0.023
    - "center": [0.026, -0.078, 0.003]
      "radius": 0.023
    - "center": [-0.134, -0.124, 0.003]
      "radius": 0.023
    - "center": [-0.292, -0.181, 0.003]
      "radius": 0.023
    - "center": [-0.104, 0.039, 0.003]
      "radius": 0.023
    - "center": [-0.22, 0.083, 0.003]
      "radius": 0.023
    - "center": [-0.091, -0.238, 0.003]
      "radius": 0.023
    - "center": [-0.058, -0.006, 0.003]
      "radius": 0.023
    - "center": [0.159, 0.079, 0.003]
      "radius": 0.023
    - "center": [-0.192, -0.195, 0.003]
      "radius": 0.023
    - "center": [0.128, 0.111, 0.003]
      "radius": 0.023
    - "center": [-0.281, -0.224, 0.003]
      "radius": 0.023
    - "center": [-0.249, 0.067, 0.003]
      "radius": 0.023
    - "center": [-0.337, 0.24, 0.003]
      "radius": 0.023
    - "center": [-0.017, -0.209, 0.003]
      "radius": 0.023
    - "center": [-0.062, -0.209, 0.003]
      "radius": 0.023
    - "center": [0.332, -0.139, 0.003]
      "radius": 0.023
    - "center": [0.158, 0.05, 0.003]
      "radius": 0.023
    - "center": [-0.295, 0.155, 0.003]
      "radius": 0.023
    - "center": [-0.001, 0.083, 0.003]
      "radius": 0.023
    - "center": [0.058, 0.082, 0.003]
      "radius": 0.023
    - "center": [0.218, 0.271, 0.003]
      "radius": 0.023
    - "center": [0.131, 0.274, 0.003]
      "radius": 0.023
    - "center": [0.129, -0.12, 0.003]
      "radius": 0.023
    - "center": [0.234, -0.095, 0.003]
      "radius": 0.023
    - "center": [-0.291, 0.023, 0.003]
      "radius": 0.023
    - "center": [-0.073, 0.285, 0.003]
      "radius": 0.023
    - "center": [0.088, 0.227, 0.003]
      "radius": 0.023
    - "center": [-0.191, -0.238, 0.003]
      "radius": 0.023
    - "center": [0.115, 0.052, 0.003]
      "radius": 0.023
    - "center": [-0.339, 0.109, 0.003]
      "radius": 0.023
    - "center": [0.1, -0.067, 0.003]
      "radius": 0.023
    - "center": [0.244, 0.083, 0.003]
      "radius": 0.023
    - "center": [-0.279, 0.24, 0.003]
      "radius": 0.023
    - "center": [-0.044, 0.172, 0.003]
      "radius": 0.023
    - "center": [-0.031, 0.228, 0.003]
      "radius": 0.023
    - "center": [0.132, 0.2, 0.003]
      "radius": 0.023
    - "center": [-0.076, 0.186, 0.003]
      "radius": 0.023
    - "center": [-0.031, -0.241, 0.003]
      "radius": 0.023
    - "center": [0.248, 0.242, 0.003]
      "radius": 0.023
    - "center": [0.071, 0.156, 0.003]
      "radius": 0.023
    - "center": [0.278, -0.24, 0.003]
      "radius": 0.023
    - "center": [0.278, -0.166, 0.003]
      "radius": 0.023
    - "center": [-0.014, -0.123, 0.003]
      "radius": 0.023
    - "center": [-0.148, 0.286, 0.003]
      "radius": 0.023
    - "center": [-0.104, -0.095, 0.003]
      "radius": 0.023
    - "center": [-0.119, -0.036, 0.003]
      "radius": 0.023
    - "center": [0.293, 0.156, 0.003]
      "radius": 0.023
    - "center": [-0.351, 0.215, 0.003]
      "radius": 0.023
    - "center": [0.04, 0.037, 0.003]
      "radius": 0.023
    - "center": [-0.176, -0.107, 0.003]
      "radius": 0.023
    - "center": [-0.032, 0.113, 0.003]
      "radius": 0.023
    - "center": [-0.059, 0.021, 0.003]
      "radius": 0.023
    - "center": [0.074, -0.255, 0.003]
      "radius": 0.023
    - "center": [0.026, 0.139, 0.003]
      "radius": 0.023
    - "center": [-0.003, -0.136, 0.003]
      "radius": 0.023
    - "center": [-0.294, 0.225, 0.003]
      "radius": 0.023
    - "center": [-0.238, 0.269, 0.003]
      "radius": 0.023
    - "center": [-0.305, 0.255, 0.003]
      "radius": 0.023
    - "center": [0.332, -0.033, 0.003]
      "radius": 0.023
    - "center": [0.351, 0.2, 0.003]
      "radius": 0.023
    - "center": [0.217, 0.167, 0.003]
      "radius": 0.023
    - "center": [-0.014, 0.157, 0.003]
      "radius": 0.023
    - "center": [-0.295, -0.004, 0.003]
      "radius": 0.023
    - "center": [-0.31, -0.081, 0.003]
      "radius": 0.023
    - "center": [-0.028, 0.006, 0.003]
      "radius": 0.023
    - "center": [-0.238, -0.138, 0.003]
      "radius": 0.023
    - "center": [-0.249, 0.23, 0.003]
      "radius": 0.023
    - "center": [0.011, 0.259, 0.003]
      "radius": 0.023
    - "center": [-0.076, -0.169, 0.003]
      "radius": 0.023
    - "center": [0.146, 0.271, 0.003]
      "radius": 0.023
    - "center": [0.144, 0.289, 0.003]
      "radius": 0.023
    - "center": [-0.251, 0.274, 0.003]
      "radius": 0.023
    - "center": [-0.306, 0.181, 0.003]
      "radius": 0.023
    - "center": [-0.145, 0.094, 0.003]
      "radius": 0.023
    - "center": [0.297, 0.007, 0.003]
      "radius": 0.023
    - "center": [-0.222, 0.234, 0.003]
      "radius": 0.023
    - "center": [0.322, -0.1, 0.003]
      "radius": 0.023
    - "center": [0.32, 0.209, 0.003]
      "radius": 0.023
    - "center": [-0.173, -0.151, 0.003]
      "radius": 0.023
    - "center": [0.147, 0.034, 0.003]
      "radius": 0.023
    - "center": [0.339, -0.242, 0.003]
      "radius": 0.023
    - "center": [0.133, -0.017, 0.003]
      "radius": 0.023
    - "center": [-0.041, 0.08, 0.003]
      "radius": 0.023
    - "center": [-0.201, -0.152, 0.003]
      "radius": 0.023
    - "center": [0.069, -0.096, 0.003]
      "radius": 0.023
    - "center": [-0.049, 0.226, 0.003]
      "radius": 0.023
    - "center": [0.141, -0.051, 0.003]
      "radius": 0.023
    - "center": [0.204, -0.084, 0.003]
      "radius": 0.023
    - "center": [-0.266, 0.116, 0.003]
      "radius": 0.023
    - "center": [0.062, 0.037, 0.003]
      "radius": 0.023
    - "center": [0.277, -0.262, 0.003]
      "radius": 0.023
    - "center": [0.014, 0.181, 0.003]
      "radius": 0.023
    - "center": [0.101, 0.188, 0.003]
      "radius": 0.023
    - "center": [-0.168, 0.255, 0.003]
      "radius": 0.023
    - "center": [-0.105, -0.06, 0.003]
      "radius": 0.023
    - "center": [-0.206, -0.043, 0.003]
      "radius": 0.023
    - "center": [0.027, -0.149, 0.003]
      "radius": 0.023
    - "center": [0.059, -0.029, 0.003]
      "radius": 0.023
    - "center": [0.159, -0.046, 0.003]
      "radius": 0.023
    - "center": [0.13, 0.175, 0.003]
      "radius": 0.023
    - "center": [-0.32, -0.159, 0.003]
      "radius": 0.023
    - "center": [-0.263, -0.142, 0.003]
      "radius": 0.023
    - "center": [0.205, -0.045, 0.003]
      "radius": 0.023
    - "center": [-0.198, 0.167, 0.003]
      "radius": 0.023
    - "center": [0.221, -0.195, 0.003]
      "radius": 0.023
    - "center": [0.158, 0.25, 0.003]
      "radius": 0.023
    - "center": [0.175, 0.013, 0.003]
      "radius": 0.023
    - "center": [-0.339, -0.278, 0.003]
      "radius": 0.023
    - "center": [0.142, -0.158, 0.003]
      "radius": 0.023
    - "center": [-0.175, -0.275, 0.003]
      "radius": 0.023
    - "center": [0.17, -0.003, 0.003]
      "radius": 0.023
    - "center": [-0.063, -0.139, 0.003]
      "radius": 0.023
    - "center": [0.15, -0.107, 0.003]
      "radius": 0.023
    - "center": [0.249, 0.059, 0.003]
      "radius": 0.023
    - "center": [0.173, -0.175, 0.003]
      "radius": 0.023
    - "center": [0.284, -0.006, 0.003]
      "radius": 0.023
    - "center": [0.048, -0.268, 0.003]
      "radius": 0.023
    - "center": [0.185, -0.108, 0.003]
      "radius": 0.023
    - "center": [0.083, -0.195, 0.003]
      "radius": 0.023
    - "center": [0.183, -0.282, 0.003]
      "radius": 0.023
    - "center": [0.104, -0.238, 0.003]
      "radius": 0.023
    - "center": [0.1, -0.112, 0.003]
      "radius": 0.023
    - "center": [0.121, -0.05, 0.003]
      "radius": 0.023
    - "center": [-0.013, -0.19, 0.003]
      "radius": 0.023
    - "center": [0.219, -0.26, 0.003]
      "radius": 0.023
    - "center": [-0.192, -0.176, 0.003]
      "radius": 0.023
    - "center": [-0.147, -0.177, 0.003]
      "radius": 0.023
    - "center": [-0.276, -0.26, 0.003]
      "radius": 0.023
    - "center": [0.319, 0.073, 0.003]
      "radius": 0.023
    - "center": [-0.312, -0.12, 0.003]
      "radius": 0.023
    - "center": [-0.216, -0.166, 0.003]
      "radius": 0.023
    - "center": [0.075, 0.083, 0.003]
      "radius": 0.023
    - "center": [0.205, -0.187, 0.003]
      "radius": 0.023
    - "center": [0.33, -0.18, 0.003]
      "radius": 0.023
    - "center": [0.219, -0.0, 0.003]
      "radius": 0.023
    - "center": [0.352, -0.017, 0.003]
      "radius": 0.023
    - "center": [0.33, -0.077, 0.003]
      "radius": 0.023
    - "center": [0.291, 0.188, 0.003]
      "radius": 0.023
    - "center": [0.286, 0.066, 0.003]
      "radius": 0.023
    - "center": [-0.068, 0.139, 0.003]
      "radius": 0.023
    - "center": [0.071, -0.279, 0.003]
      "radius": 0.023
    - "center": [-0.261, -0.077, 0.003]
      "radius": 0.023
    - "center": [0.015, -0.292, 0.003]
      "radius": 0.023
    - "center": [-0.237, -0.294, 0.003]
      "radius": 0.023
    - "center": [0.029, -0.245, 0.003]
      "radius": 0.023
    - "center": [0.236, -0.167, 0.003]
      "radius": 0.023
    - "center": [0.275, -0.188, 0.003]
      "radius": 0.023
    - "center": [0.133, 0.01, 0.003]
      "radius": 0.023
    - "center": [-0.018, -0.045, 0.003]
      "radius": 0.023
    - "center": [0.287, -0.093, 0.003]
      "radius": 0.023
    - "center": [-0.331, -0.18, 0.003]
      "radius": 0.023
    - "center": [-0.091, 0.014, 0.003]
      "radius": 0.023
    - "center": [-0.315, -0.282, 0.003]
      "radius": 0.023
    - "center": [-0.127, -0.006, 0.003]
      "radius": 0.023
    - "center": [0.086, -0.129, 0.003]
      "radius": 0.023
    - "center": [-0.208, 0.147, 0.003]
      "radius": 0.023
    - "center": [-0.322, -0.234, 0.003]
      "radius": 0.023
    - "center": [-0.102, -0.075, 0.003]
      "radius": 0.023
    - "center": [-0.264, 0.205, 0.003]
      "radius": 0.023
    - "center": [0.136, -0.268, 0.003]
      "radius": 0.023
    - "center": [-0.062, -0.235, 0.003]
      "radius": 0.023
    - "center": [0.232, -0.245, 0.003]
      "radius": 0.023
    - "center": [0.026, 0.279, 0.003]
      "radius": 0.023
    - "center": [-0.339, 0.136, 0.003]
      "radius": 0.023
    - "center": [-0.1, 0.138, 0.003]
      "radius": 0.023
    - "center": [-0.115, 0.167, 0.003]
      "radius": 0.023
    - "center": [-0.221, 0.045, 0.003]
      "radius": 0.023
    - "center": [0.267, 0.287, 0.003]
      "radius": 0.023
    - "center": [-0.306, -0.149, 0.003]
      "radius": 0.023
    - "center": [-0.192, 0.216, 0.003]
      "radius": 0.023
    - "center": [0.17, -0.282, 0.003]
      "radius": 0.023
    - "center": [-0.363, 0.156, 0.003]
      "radius": 0.023
    - "center": [-0.357, -0.05, 0.003]
      "radius": 0.023
    - "center": [-0.347, 0.04, 0.003]
      "radius": 0.023
    - "center": [-0.329, 0.269, 0.003]
      "radius": 0.023
    - "center": [-0.221, 0.116, 0.003]
      "radius": 0.023
    - "center": [-0.22, -0.087, 0.003]
      "radius": 0.023
    - "center": [-0.262, -0.039, 0.003]
      "radius": 0.023
    - "center": [-0.11, -0.197, 0.003]
      "radius": 0.023
    - "center": [-0.231, -0.241, 0.003]
      "radius": 0.023
    - "center": [0.238, -0.283, 0.003]
      "radius": 0.023
    - "center": [-0.237, 0.002, 0.003]
      "radius": 0.023
    - "center": [-0.288, -0.018, 0.003]
      "radius": 0.023
    - "center": [-0.28, 0.132, 0.003]
      "radius": 0.023
    - "center": [-0.335, -0.148, 0.003]
      "radius": 0.023
    - "center": [0.078, 0.182, 0.003]
      "radius": 0.023
    - "center": [-0.19, 0.016, 0.003]
      "radius": 0.023
    - "center": [-0.11, 0.241, 0.003]
      "radius": 0.023
    - "center": [0.055, -0.162, 0.003]
      "radius": 0.023
    - "center": [-0.176, 0.003, 0.003]
      "radius": 0.023
    - "center": [-0.176, 0.178, 0.003]
      "radius": 0.023
    - "center": [0.069, 0.118, 0.003]
      "radius": 0.023
    - "center": [0.262, -0.011, 0.003]
      "radius": 0.023
    - "center": [0.259, 0.208, 0.003]
      "radius": 0.023
    - "center": [-0.148, 0.032, 0.003]
      "radius": 0.023
    - "center": [0.274, -0.221, 0.003]
      "radius": 0.023
    - "center": [0.29, 0.208, 0.003]
      "radius": 0.023
    - "center": [-0.103, 0.203, 0.003]
      "radius": 0.023
    - "center": [-0.173, 0.082, 0.003]
      "radius": 0.023
    - "center": [0.175, -0.083, 0.003]
      "radius": 0.023
    - "center": [0.304, 0.131, 0.003]
      "radius": 0.023
    - "center": [-0.273, 0.17, 0.003]
      "radius": 0.023
    - "center": [-0.246, -0.169, 0.003]
      "radius": 0.023
    - "center": [0.157, 0.145, 0.003]
      "radius": 0.023
    - "center": [0.196, -0.11, 0.003]
      "radius": 0.023
    - "center": [0.094, 0.171, 0.003]
      "radius": 0.023
    - "center": [-0.209, 0.213, 0.003]
      "radius": 0.023
    - "center": [-0.011, 0.022, 0.003]
      "radius": 0.023
    - "center": [0.284, 0.258, 0.003]
      "radius": 0.023
    - "center": [-0.242, 0.035, 0.003]
      "radius": 0.023
    - "center": [-0.324, 0.0, 0.003]
      "radius": 0.023
    - "center": [0.12, 0.154, 0.003]
      "radius": 0.023
    - "center": [0.256, -0.137, 0.003]
      "radius": 0.023
    - "center": [0.023, -0.111, 0.003]
      "radius": 0.023
    - "center": [-0.028, 0.172, 0.003]
      "radius": 0.023
    - "center": [0.331, -0.152, 0.003]
      "radius": 0.023
    - "center": [0.35, -0.026, 0.003]
      "radius": 0.023
    - "center": [0.159, 0.276, 0.003]
      "radius": 0.023
    - "center": [0.008, 0.099, 0.003]
      "radius": 0.023
    - "center": [0.343, -0.124, 0.003]
      "radius": 0.023
    - "center": [0.305, 0.158, 0.003]
      "radius": 0.023
    - "center": [0.133, -0.139, 0.003]
      "radius": 0.023
    - "center": [0.067, -0.24, 0.003]
      "radius": 0.023
    - "center": [-0.227, -0.138, 0.003]
      "radius": 0.023
    - "center": [-0.187, -0.271, 0.003]
      "radius": 0.023
    - "center": [-0.16, -0.103, 0.003]
      "radius": 0.023
    - "center": [0.032, 0.026, 0.003]
      "radius": 0.023
    - "center": [0.051, 0.026, 0.003]
      "radius": 0.023
    - "center": [0.058, -0.105, 0.003]
      "radius": 0.023
    - "center": [-0.319, -0.063, 0.003]
      "radius": 0.023
    - "center": [-0.239, -0.282, 0.003]
      "radius": 0.023
    - "center": [0.053, 0.067, 0.003]
      "radius": 0.023
    - "center": [-0.018, -0.229, 0.003]
      "radius": 0.023
    - "center": [-0.139, -0.169, 0.003]
      "radius": 0.023
    - "center": [-0.121, -0.112, 0.003]
      "radius": 0.023
    - "center": [-0.163, -0.176, 0.003]
      "radius": 0.023
    - "center": [0.115, 0.278, 0.003]
      "radius": 0.023
    - "center": [-0.119, -0.133, 0.003]
      "radius": 0.023
    - "center": [-0.287, -0.164, 0.003]
      "radius": 0.023
    - "center": [-0.057, -0.239, 0.003]
      "radius": 0.023
    - "center": [-0.353, -0.055, 0.003]
      "radius": 0.023
    - "center": [-0.276, -0.149, 0.003]
      "radius": 0.023
    - "center": [-0.041, 0.065, 0.003]
      "radius": 0.023
    - "center": [-0.11, -0.022, 0.003]
      "radius": 0.023
    - "center": [-0.145, 0.1, 0.003]
      "radius": 0.023
    - "center": [0.288, 0.073, 0.003]
      "radius": 0.023
    - "center": [-0.15, -0.18, 0.003]
      "radius": 0.023
    - "center": [-0.147, -0.127, 0.003]
      "radius": 0.023
    - "center": [0.109, -0.256, 0.003]
      "radius": 0.023
    - "center": [0.188, -0.191, 0.003]
      "radius": 0.023
    - "center": [0.218, -0.104, 0.003]
      "radius": 0.023
    - "center": [0.17, 0.256, 0.003]
      "radius": 0.023
    - "center": [0.293, -0.25, 0.003]
      "radius": 0.023
    - "center": [-0.043, 0.017, 0.003]
      "radius": 0.023
    - "center": [-0.246, -0.008, 0.003]
      "radius": 0.023
    - "center": [0.147, 0.246, 0.003]
      "radius": 0.023
    - "center": [0.258, 0.227, 0.003]
      "radius": 0.023
    - "center": [-0.249, 0.209, 0.003]
      "radius": 0.023
    - "center": [-0.338, -0.185, 0.003]
      "radius": 0.023
    - "center": [-0.066, 0.268, 0.003]
      "radius": 0.023
    - "center": [0.252, -0.216, 0.003]
      "radius": 0.023
    - "center": [0.095, 0.106, 0.003]
      "radius": 0.023
    - "center": [-0.152, 0.268, 0.003]
      "radius": 0.023
    - "center": [0.003, 0.223, 0.003]
      "radius": 0.023
    - "center": [0.362, -0.206, 0.003]
      "radius": 0.022
    - "center": [-0.256, -0.161, 0.003]
      "radius": 0.023
    - "center": [-0.332, -0.071, 0.003]
      "radius": 0.023
    - "center": [-0.143, 0.019, 0.003]
      "radius": 0.023
    - "center": [0.142, 0.231, 0.003]
      "radius": 0.023
    - "center": [0.05, 0.15, 0.003]
      "radius": 0.023
    - "center": [-0.356, 0.06, 0.003]
      "radius": 0.023
    - "center": [0.091, 0.03, 0.003]
      "radius": 0.023
    - "center": [0.045, 0.291, 0.005]
      "radius": 0.021
    - "center": [-0.024, 0.202, 0.003]
      "radius": 0.023
    - "center": [-0.111, 0.092, 0.003]
      "radius": 0.023
    - "center": [0.096, -0.275, 0.003]
      "radius": 0.023
    - "center": [0.151, 0.181, 0.003]
      "radius": 0.023
    - "center": [0.181, 0.209, 0.003]
      "radius": 0.023
    - "center": [-0.084, 0.027, 0.003]
      "radius": 0.023
    - "center": [-0.079, 0.263, 0.003]
      "radius": 0.023
    - "center": [0.023, 0.163, 0.003]
      "radius": 0.023
    - "center": [0.156, -0.023, 0.003]
      "radius": 0.023
    - "center": [0.051, -0.017, 0.003]
      "radius": 0.023
    - "center": [-0.009, -0.016, 0.003]
      "radius": 0.023
    - "center": [0.109, 0.164, 0.003]
      "radius": 0.023
    - "center": [-0.347, 0.013, 0.003]
      "radius": 0.023
    - "center": [0.016, -0.061, 0.003]
      "radius": 0.023
    - "center": [-0.342, -0.073, 0.003]
      "radius": 0.023
    - "center": [-0.083, 0.251, 0.003]
      "radius": 0.023
    - "center": [0.282, 0.282, 0.003]
      "radius": 0.023
    - "center": [-0.122, 0.103, 0.003]
      "radius": 0.023
    - "center": [0.067, 0.176, 0.003]
      "radius": 0.023
    - "center": [-0.187, -0.09, 0.003]
      "radius": 0.023
    - "center": [-0.267, 0.193, 0.003]
      "radius": 0.023
    - "center": [-0.038, 0.152, 0.003]
      "radius": 0.023
    - "center": [-0.098, -0.13, 0.003]
      "radius": 0.023
    - "center": [0.067, -0.288, 0.003]
      "radius": 0.023
    - "center": [-0.05, -0.176, 0.003]
      "radius": 0.023
    - "center": [-0.225, 0.158, 0.003]
      "radius": 0.023
    - "center": [-0.2, 0.203, 0.003]
      "radius": 0.023
    - "center": [-0.096, 0.234, 0.003]
      "radius": 0.023
    - "center": [0.067, 0.012, 0.003]
      "radius": 0.023
    - "center": [0.051, 0.003, 0.003]
      "radius": 0.023
    - "center": [0.294, 0.091, 0.003]
      "radius": 0.023
    - "center": [-0.171, 0.193, 0.003]
      "radius": 0.023
    - "center": [0.24, -0.017, 0.003]
      "radius": 0.023
    - "center": [0.266, 0.061, 0.003]
      "radius": 0.023
    - "center": [-0.245, 0.245, 0.003]
      "radius": 0.023
    - "center": [0.257, -0.032, 0.003]
      "radius": 0.023
    - "center": [-0.271, -0.011, 0.003]
      "radius": 0.023
    - "center": [-0.301, 0.207, 0.003]
      "radius": 0.023
    - "center": [-0.077, 0.203, 0.003]
      "radius": 0.023
    - "center": [0.207, 0.06, 0.003]
      "radius": 0.023
    - "center": [0.301, -0.057, 0.003]
      "radius": 0.023
    - "center": [0.297, -0.218, 0.003]
      "radius": 0.023
    - "center": [0.199, 0.145, 0.003]
      "radius": 0.023
    - "center": [0.09, -0.088, 0.003]
      "radius": 0.023
    - "center": [0.166, -0.214, 0.003]
      "radius": 0.023
    - "center": [-0.009, 0.117, 0.003]
      "radius": 0.023
    - "center": [0.27, 0.135, 0.003]
      "radius": 0.023
    - "center": [0.209, -0.118, 0.003]
      "radius": 0.023
    - "center": [0.122, -0.0, 0.003]
      "radius": 0.023
    - "center": [0.227, -0.162, 0.003]
      "radius": 0.023
    - "center": [-0.079, 0.224, 0.003]
      "radius": 0.023
    - "center": [-0.33, -0.06, 0.003]
      "radius": 0.023
    - "center": [-0.241, 0.193, 0.003]
      "radius": 0.023
    - "center": [-0.33, 0.016, 0.003]
      "radius": 0.023
    - "center": [-0.29, 0.187, 0.003]
      "radius": 0.023
    - "center": [0.069, -0.145, 0.003]
      "radius": 0.023
    - "center": [-0.1, -0.003, 0.003]
      "radius": 0.023
    - "center": [0.149, -0.191, 0.003]
      "radius": 0.023
    - "center": [-0.342, 0.062, 0.003]
      "radius": 0.023
    - "center": [0.097, -0.294, 0.003]
      "radius": 0.023
    - "center": [-0.301, -0.131, 0.003]
      "radius": 0.023
    - "center": [-0.314, 0.129, 0.003]
      "radius": 0.023
    - "center": [-0.157, -0.293, 0.003]
      "radius": 0.023
    - "center": [-0.246, 0.088, 0.003]
      "radius": 0.023
    - "center": [-0.124, -0.266, 0.003]
      "radius": 0.023
    - "center": [-0.17, -0.247, 0.003]
      "radius": 0.023
    - "center": [-0.282, -0.273, 0.003]
      "radius": 0.023
    - "center": [-0.142, -0.1, 0.003]
      "radius": 0.023
    - "center": [-0.201, -0.113, 0.003]
      "radius": 0.023
    - "center": [-0.304, 0.086, 0.003]
      "radius": 0.023
    - "center": [-0.1, -0.149, 0.003]
      "radius": 0.023
    - "center": [-0.112, 0.017, 0.003]
      "radius": 0.023
    - "center": [-0.196, 0.085, 0.003]
      "radius": 0.023
    - "center": [0.037, -0.232, 0.003]
      "radius": 0.023
    - "center": [-0.155, -0.046, 0.003]
      "radius": 0.023
    - "center": [-0.184, -0.071, 0.003]
      "radius": 0.023
    - "center": [0.225, 0.146, 0.003]
      "radius": 0.023
    - "center": [-0.214, -0.259, 0.003]
      "radius": 0.023
    - "center": [0.207, 0.129, 0.003]
      "radius": 0.023
    - "center": [-0.005, -0.025, 0.003]
      "radius": 0.023
    - "center": [0.279, -0.145, 0.003]
      "radius": 0.023
    - "center": [0.022, -0.027, 0.003]
      "radius": 0.023
    - "center": [0.06, 0.063, 0.003]
      "radius": 0.023
    - "center": [0.315, -0.042, 0.003]
      "radius": 0.023
    - "center": [0.327, 0.121, 0.003]
      "radius": 0.023
    - "center": [0.257, -0.175, 0.003]
      "radius": 0.023
    - "center": [0.151, 0.108, 0.003]
      "radius": 0.023
    - "center": [-0.007, 0.004, 0.003]
      "radius": 0.023
    - "center": [0.108, 0.086, 0.003]
      "radius": 0.023
    - "center": [0.272, -0.128, 0.003]
      "radius": 0.023
    - "center": [-0.063, -0.243, 0.003]
      "radius": 0.023
    - "center": [0.065, -0.202, 0.003]
      "radius": 0.023
    - "center": [-0.038, -0.114, 0.003]
      "radius": 0.023
    - "center": [0.194, -0.16, 0.003]
      "radius": 0.023
    - "center": [0.251, 0.004, 0.003]
      "radius": 0.023
    - "center": [-0.042, -0.101, 0.003]
      "radius": 0.023
    - "center": [0.285, 0.1, 0.003]
      "radius": 0.023
    - "center": [-0.126, 0.133, 0.003]
      "radius": 0.023
    - "center": [0.314, 0.101, 0.003]
      "radius": 0.023
    - "center": [0.177, 0.131, 0.003]
      "radius": 0.023
    - "center": [0.346, -0.185, 0.003]
      "radius": 0.023
    - "center": [0.2, 0.275, 0.003]
      "radius": 0.023
    - "center": [-0.101, 0.176, 0.003]
      "radius": 0.023
    - "center": [0.023, 0.254, 0.003]
      "radius": 0.023
    - "center": [0.17, -0.128, 0.003]
      "radius": 0.023
    - "center": [0.297, -0.162, 0.003]
      "radius": 0.023
    - "center": [-0.155, 0.173, 0.003]
      "radius": 0.023
    - "center": [0.33, 0.174, 0.003]
      "radius": 0.023
    - "center": [0.308, -0.206, 0.003]
      "radius": 0.023
    - "center": [0.346, -0.102, 0.003]
      "radius": 0.023
    - "center": [0.344, -0.218, 0.003]
      "radius": 0.023
    - "center": [-0.213, 0.291, 0.005]
      "radius": 0.021
    - "center": [-0.12, 0.291, 0.001]
      "radius": 0.021
    - "center": [0.353, 0.237, 0.003]
      "radius": 0.023
    - "center": [0.286, 0.12, 0.003]
      "radius": 0.023
    - "center": [0.36, -0.06, 0.003]
      "radius": 0.023
    - "center": [0.352, 0.116, 0.003]
      "radius": 0.023
Thanks for your reply.
I did what you asked I replaced the config_2.yaml with your code and now I dont need to hardcode the +y -y direction change as I mentioned above, but now a change in direction in x has been occurring. If the target moves +x the end effector moves -x.
Check out the video here.
video
I guess I have to change the positive negative values of the default_q vector and check which one gives me the proper directional movement. But how do I make the arm reach precisely to the target position ? Is there any way to do that ?
Did you create the ur3_robot_description (or config_2.yaml) file yourself with the Lula Robot Description Editor (Lula Robot Description Editor — Omniverse IsaacSim latest documentation), including the Husky base platform?
Yes I did.
I checked out the tutorial and followed the tutorial to make the robot description file. I kept the mobile robot joints ( the 4 wheel joints ) as fixed joints and the ur3 arm joints as active joints and generated collision spheres for the arm, the base of the mobile robot and the 4 wheels.
However I didnt do it for the small links (rear bumper link, front bumper link …you can see in the photo above) that were attached to the mobile robot base. But I dont think that has to do with anything with how Lula behaves. Does it ?
UR5_Test.zip (2.7 MB)
Here you find the config files and a code snippet for a RMPflow application with an UR5e. Maybe this helps.
Thank you. I will check it and let you know.
