I’m experiencing issues importing the RB-KAIROS holonomic mobile manipulator into Isaac Sim 4.5. After acquiring the URDF from the official GitHub repository, I imported it into Isaac Sim using the following settings: movable base, acceleration drive type, and self-collision enabled.
However, when I press play, the robot immediately becomes unstable and flies off. I’ve attached a video demonstrating this behavior along with the URDF file I’m using.
When I disable self-collision, it is more stable, but then the links pass through themselves. Any suggestions on how to improve this?
<?xml version="1.0" ?>
<!-- | This document was autogenerated by xacro from rbkairos_franka.urdf.xacro | -->
<!-- | EDITING THIS FILE BY HAND IS NOT RECOMMENDED | -->
<robot name="rbkairos">
<!-- Imported elements -->
<gazebo reference="base_footprint">
<material>Gazebo/Green</material>
</gazebo>
<!-- in kg-->
<!-- in kg-->
<!-- source en.wikipedia.org/wiki/List_of_moments_of_inertia-->
<!-- This file unifies all sensors that can be used on simulation, defined as xacro:macros -->
<!-- <xacro:macro name="sensor_ultrasonic_a21_gazebo">
<gazebo reference="${prefix}_link">
<xacro:if value="${gpu}">
<xacro:property name="ray_type" value="gpu_ray" />
<xacro:property name="plugin_lib" value="libgazebo_ros_gpu_laser.so" />
</xacro:if>
<xacro:unless value="${gpu}">
<xacro:property name="ray_type" value="ray" />
<xacro:property name="plugin_lib" value="libgazebo_ros_laser.so" />
</xacro:unless>
<sensor type="${ray_type}" name="${prefix}_sensor">
<pose>0 0 0 0 0 0</pose>
<visualize>false</visualize>
<update_rate>40</update_rate>
<ray>
<scan>
<horizontal>
<samples>1081</samples>
<resolution>1</resolution>
<min_angle>${min_angle}</min_angle>
<max_angle>${max_angle}</max_angle>
</horizontal>
</scan>
<range>
<min>0.06</min>
<max>20.0</max>
<! resolution>0.004363323</resolution >
<resolution>0.004359297</resolution>
<! resolution>0.001</resolution >
</range>
<noise>
<type>gaussian</type>
<mean>0.0</mean>
<stddev>0.01</stddev>
</noise>
</ray>
<plugin name="${prefix}_controller" filename="${plugin_lib}">
<topicName>${prefix_topic}/scan</topicName>
<frameName>/${prefix}_link</frameName>
</plugin>
</sensor>
</gazebo>
</xacro:macro>
<!-- Includes -->
<!-- Includes -->
<!-- Robots Elements -->
<link name="robotbase_footprint">
<visual>
<origin rpy="0 0 0" xyz="0 0 0"/>
<geometry>
<box size="0.001 0.001 0.001"/>
</geometry>
</visual>
</link>
<joint name="robotbase_footprint_joint" type="fixed">
<origin rpy="0 0 0" xyz="0 0 0.127"/>
<!-- ${wheel_radius} property must be defined inside wheel description -->
<parent link="robotbase_footprint"/>
<child link="robotbase_link"/>
</joint>
<!-- BASE_LINK -->
<link name="robotbase_link">
<inertial>
<mass value="125.0"/>
<origin xyz="0 0 0"/>
<inertia ixx="1.391" ixy="0.004" ixz="0.0" iyy="6.853" iyz="0.0" izz="6.125"/>
</inertial>
<visual>
<geometry>
<mesh filename="/home/sesem/rbkairos_common/summit_xl_description//meshes/bases/xls/summit_xlsk_plus.stl"/>
</geometry>
<material name="black">
<color rgba="0.0 0.0 0.0 1"/>
</material>
</visual>
<collision>
<origin rpy="0 0 0 " xyz="0 0 0"/>
<geometry>
<mesh filename="/home/sesem/rbkairos_common/summit_xl_description//meshes/bases/xls/summit_xlsk_plus.dae"/>
</geometry>
</collision>
</link>
<gazebo reference="robotbase_link">
<material>Gazebo/Black</material>
</gazebo>
<!-- CHAPAS INOX TAPAS -->
<link name="robotbase_chapa">
<visual>
<geometry>
<mesh filename="/home/sesem/rbkairos_common/summit_xl_description//meshes/bases/xls/summit_xls_chapas_inox_tapas.stl"/>
</geometry>
<material name="darkgrey">
<color rgba="0.5 0.5 0.5 1"/>
</material>
</visual>
</link>
<joint name="robotbase_tapa_joint" type="fixed">
<origin rpy="0 0 0" xyz="0.0 0 0.56162"/>
<parent link="robotbase_link"/>
<child link="robotbase_chapa"/>
</joint>
<!-- LOGO ROBOTNIK IZQUIERDO -->
<link name="robotbase_logo_left">
<visual>
<geometry>
<mesh filename="/home/sesem/rbkairos_common/summit_xl_description//meshes/bases/xls/robotnik_logo_chasis.stl"/>
</geometry>
</material>
</visual>
</link>
<joint name="robotbase_logo_left_joint" type="fixed">
<origin rpy="0 0 0" xyz="0.0 0.2894 0.35562"/>
<child link="robotbase_logo_left"/>
</joint>
<!-- LOGO ROBOTNIK DERECHO -->
<link name="robotbase_logo_right">
<visual>
<geometry>
</geometry>
</material>
</visual>
</link>
<joint name="robotbase_logo_right_joint" type="fixed">
<origin rpy="0 0 3.141592653589793" xyz="0.0 -0.28931 0.35562"/>
<child link="robotbase_logo_right"/>
</joint>
<!-- LOGO ROBOTNIK FRONTAL -->
<link name="robotbase_logo_front">
<visual>
<geometry>
</geometry>
</material>
</visual>
</link>
<joint name="robotbase_logo_front_joint" type="fixed">
<origin rpy="0 0 -1.5707963267948966" xyz="0.345 0.0 0.0"/>
<child link="robotbase_logo_front"/>
</joint>
<!-- LOGO ROBOTNIK TRASERO -->
<link name="robotbase_logo_rear">
<visual>
<geometry>
</geometry>
</material>
</visual>
</link>
<joint name="robotbase_logo_rear_joint" type="fixed">
<origin rpy="0 0 1.5707963267948966" xyz="-0.345 0.0 0.0"/>
<child link="robotbase_logo_rear"/>
</joint>
<!-- DOCKING CONTACT -->
<link name="robotbase_docking_contact">
</link>
<joint name="robotbase_docking_joint" type="fixed">
<origin rpy="0 0 0" xyz="0.35 0 0.09"/>
<child link="robotbase_docking_contact"/>
</joint>
<sick_microscan3_support parent="robotbase_link" prefix="robotfront_laser">
<origin rpy="0 0 -0.645772" xyz="0.28704 -0.22255 0.20212"/>
</sick_microscan3_support>
<sick_microscan3_support parent="robotbase_link" prefix="robotrear_laser">
<origin rpy="0 0 2.496" xyz="-0.28704 +0.22255 0.20212"/>
<joint name="robotfront_right_wheel_joint" type="continuous">
<child link="robotfront_right_wheel_link"/>
<origin rpy="0 0 0" xyz="0.21528 -0.269 0.0"/>
<axis rpy="0 0 0" xyz="0 1 0"/>
<limit effort="100" velocity="100"/>
<joint_properties damping="0.0" friction="0.0"/>
</joint>
<link name="robotfront_right_wheel_link">
<visual>
<geometry>
<mesh filename="/home/sesem/rbkairos_common/summit_xl_description//meshes/wheels/omni_wheel_2.dae"/>
</geometry>
<color rgba="0.2 0.2 0.2 1"/>
</material>
</visual>
<collision>
<origin rpy="1.5707963267948966 0 0" xyz="0 0 0"/>
<geometry>
<!--sphere radius="${omni_wheel_radius}" /-->
<xacro:if value="${reflect}">
<mesh filename="/home/sesem/rbkairos_common/summit_xl_description//meshes/wheels/omni_wheel_1.dae" />
</xacro:if>
<xacro:unless value="${reflect}">
<mesh filename="/home/sesem/rbkairos_common/summit_xl_description//meshes/wheels/omni_wheel_2.dae" />
</xacro:unless>
<cylinder length="0.087" radius="0.127"/>
<!-- sphere radius="${omni_wheel_radius}"/-->
</geometry>
</collision>
<inertial>
<mass value="6.5"/>
<inertia ixx="0.0303095" ixy="0" ixz="0" iyy="0.05241925" iyz="0" izz="0.0303095"/>
</inertial>
</link>
<!-- Transmission is important to link the joints and the controller (see summit_xl_control/config/summit_xl_control.yaml)-->
<transmission name="robotfront_right_wheel_joint_trans">
<type>transmission_interface/SimpleTransmission</type>
<joint name="robotfront_right_wheel_joint">
<hardwareInterface>hardware_interface/VelocityJointInterface</hardwareInterface>
</joint>
<actuator name="robotfront_right_wheel_joint_motor">
<mechanicalReduction>1</mechanicalReduction>
</actuator>
</transmission>
<gazebo reference="robotfront_right_wheel_link">
<mu1 value="0.0"/>
<mu2 value="0.0"/>
<kp value="10000000.0"/>
<kd value="1.0"/>
<fdir1 value="1 0 0"/>
<turnGravityOff>false</turnGravityOff>
</gazebo>
<joint name="robotfront_left_wheel_joint" type="continuous">
<child link="robotfront_left_wheel_link"/>
<origin rpy="0 0 0" xyz="0.21528 0.269 0.0"/>
</joint>
<link name="robotfront_left_wheel_link">
<visual>
<geometry>
<mesh filename="/home/sesem/rbkairos_common/summit_xl_description//meshes/wheels/omni_wheel_1.dae"/>
</geometry>
</material>
</visual>
<collision>
<geometry>
</xacro:if>
</xacro:unless>
</geometry>
</collision>
<inertial>
<mass value="6.5"/>
</inertial>
</link>
<transmission name="robotfront_left_wheel_joint_trans">
<joint name="robotfront_left_wheel_joint">
</joint>
<actuator name="robotfront_left_wheel_joint_motor">
</actuator>
</transmission>
<gazebo reference="robotfront_left_wheel_link">
<mu1 value="0.0"/>
<mu2 value="0.0"/>
<kd value="1.0"/>
</gazebo>
<joint name="robotback_left_wheel_joint" type="continuous">
<child link="robotback_left_wheel_link"/>
<origin rpy="0 0 0" xyz="-0.21528 0.269 0.0"/>
</joint>
<link name="robotback_left_wheel_link">
<visual>
<geometry>
</geometry>
</material>
</visual>
<collision>
<geometry>
</xacro:if>
</xacro:unless>
</geometry>
</collision>
<inertial>
<mass value="6.5"/>
</inertial>
</link>
<transmission name="robotback_left_wheel_joint_trans">
<joint name="robotback_left_wheel_joint">
</joint>
<actuator name="robotback_left_wheel_joint_motor">
</actuator>
</transmission>
<gazebo reference="robotback_left_wheel_link">
<mu1 value="0.0"/>
<mu2 value="0.0"/>
<kd value="1.0"/>
</gazebo>
<joint name="robotback_right_wheel_joint" type="continuous">
<child link="robotback_right_wheel_link"/>
<origin rpy="0 0 0" xyz="-0.21528 -0.269 0.0"/>
</joint>
<link name="robotback_right_wheel_link">
<visual>
<geometry>
</geometry>
</material>
</visual>
<collision>
<geometry>
</xacro:if>
</xacro:unless>
</geometry>
</collision>
<inertial>
<mass value="6.5"/>
</inertial>
</link>
<transmission name="robotback_right_wheel_joint_trans">
<joint name="robotback_right_wheel_joint">
</joint>
<actuator name="robotback_right_wheel_joint_motor">
</actuator>
</transmission>
<gazebo reference="robotback_right_wheel_link">
<mu1 value="0.0"/>
<mu2 value="0.0"/>
<kd value="1.0"/>
</gazebo>
<joint name="robotimu_joint" type="fixed">
<axis xyz="1 0 0"/>
<!--origin xyz="0 0 0.2825"/-->
<origin rpy="0 0 0" xyz="0.127 -0.129 0.212"/>
<child link="robotimu_link"/>
</joint>
<link name="robotimu_link">
<inertial>
<origin rpy="0 0 0" xyz="0.0 0 0.01"/>
<mass value="0.05"/>
<inertia ixx="3.3333333333333337e-06" ixy="0" ixz="0" iyy="3.3333333333333337e-06" iyz="0" izz="3.3333333333333337e-06"/>
</inertial>
<visual>
<geometry>
</geometry>
</visual>
<collision>
<geometry>
<box size=".001 .001 .001"/>
</geometry>
</collision>
</link>
<gazebo>
<plugin filename="libhector_gazebo_ros_imu.so" name="robotimu_controller">
<alwaysOn>true</alwaysOn>
<topicName>imu/data</topicName>
<serviceName>robotimuimu/service</serviceName>
<bodyName>robotimu_link</bodyName>
<frameId>robotimu_link</frameId>
<updateRate>50.0</updateRate>
<gaussianNoise>0.00</gaussianNoise>
<yawOffset>0.0</yawOffset>
<yawDrift>0.0</yawDrift>
<yawGaussianNoise>0.0</yawGaussianNoise>
<!-- angular velocities parameters -->
<rateOffset>0.0 0.0 0.0</rateOffset>
<rateDrift>0.0 0.0 0.0</rateDrift>
<rateGaussianNoise>0.0 0.0 0.0</rateGaussianNoise>
<!-- linear accelerations parameters -->
<accelOffset>0.0 0.0 0.0</accelOffset>
<accelDrift>0.0 0.0 0.0</accelDrift>
<accelGaussianNoise>0.0 0.0 0.0</accelGaussianNoise>
</plugin>
</gazebo>
<joint name="robotfront_laser_base_joint" type="fixed">
<origin rpy="0 -3.141592653589793 2.356194490192345" xyz="0.29316 -0.22809 0.23162"/>
<child link="robotfront_laser_base_link"/>
</joint>
<link name="robotfront_laser_base_link">
<collision>
<origin rpy="0 0 0" xyz="0 0 0.0"/>
<geometry>
<box size="0.010 0.010 0.010"/>
</geometry>
</collision>
<visual>
<geometry>
<mesh filename="/home/sesem/rbkairos_common/robotnik_sensors//meshes/hokuyo_ust_20lx.dae"/>
</geometry>
</visual>
<inertial>
<origin rpy="0 0 0" xyz="0.0 0 0.035"/>
<mass value="0.130"/>
<inertia ixx="8.016666666666669e-05" ixy="0" ixz="0" iyy="8.016666666666669e-05" iyz="0" izz="5.4166666666666685e-05"/>
</inertial>
</link>
<link name="robotfront_laser_link">
</link>
<joint name="robotfront_laser_joint" type="fixed">
<parent link="robotfront_laser_base_link"/>
<child link="robotfront_laser_link"/>
<origin rpy="0 0 0" xyz="0.00 0.0 0.0474"/>
</joint>
<gazebo reference="robotfront_laser_link">
<sensor name="robotfront_laser_sensor" type="ray">
<ray>
<scan>
<horizontal>
<min_angle>-2.3562</min_angle>
<max_angle>2.3562</max_angle>
</horizontal>
</scan>
<range>
<min>0.06</min>
<max>20.0</max>
<!-- resolution>0.004363323</resolution -->
<!-- resolution>0.001</resolution -->
</range>
<noise>
<mean>0.0</mean>
</noise>
</ray>
<plugin filename="libgazebo_ros_laser.so" name="robotfront_laser_controller">
<topicName>front_laser/scan</topicName>
<frameName>/robotfront_laser_link</frameName>
</plugin>
</sensor>
</gazebo>
<joint name="robotrear_laser_base_joint" type="fixed">
<origin rpy="0 -3.141592653589793 -0.7853981633974483" xyz="-0.29316 0.22809 0.23162"/>
<child link="robotrear_laser_base_link"/>
</joint>
<link name="robotrear_laser_base_link">
<collision>
<geometry>
</geometry>
</collision>
<visual>
<geometry>
</geometry>
</visual>
<inertial>
</inertial>
</link>
<link name="robotrear_laser_link">
</link>
<joint name="robotrear_laser_joint" type="fixed">
<parent link="robotrear_laser_base_link"/>
<child link="robotrear_laser_link"/>
</joint>
<gazebo reference="robotrear_laser_link">
<sensor name="robotrear_laser_sensor" type="ray">
<ray>
<scan>
<horizontal>
</horizontal>
</scan>
<range>
<min>0.06</min>
<max>20.0</max>
</range>
<noise>
<mean>0.0</mean>
</noise>
</ray>
<plugin filename="libgazebo_ros_laser.so" name="robotrear_laser_controller">
<topicName>rear_laser/scan</topicName>
<frameName>/robotrear_laser_link</frameName>
</plugin>
</sensor>
</gazebo>
<joint name="robotfront_rgbd_camera_joint" type="fixed">
<origin rpy="0 0 0" xyz="0.3585 0.0 0.25062"/>
<child link="robotfront_rgbd_camera_link"/>
</joint>
<link name="robotfront_rgbd_camera_link">
<visual>
<geometry>
<mesh filename="/home/sesem/rbkairos_common/robotnik_sensors//meshes/orbbec_astra.dae"/>
</geometry>
</visual>
<collision>
<geometry>
</geometry>
</collision>
<inertial>
<mass value="0.001"/>
<origin xyz="0.0 0.0 0.0"/>
<inertia ixx="2.3437500000000006e-06" ixy="0" ixz="0" iyy="2.0833333333333336e-07" iyz="0" izz="2.4020833333333336e-06"/>
</inertial>
</link>
<joint name="robotfront_rgbd_camera_rgb_joint" type="fixed">
<origin rpy="0.0 0.0 0.0" xyz="0.0 0.0125 0.0150"/>
<parent link="robotfront_rgbd_camera_link"/>
<child link="robotfront_rgbd_camera_rgb_frame"/>
</joint>
<link name="robotfront_rgbd_camera_rgb_frame">
<inertial>
<mass value="0.297"/>
<origin xyz="-0.02 -0.0125 0.0"/>
<inertia ixx="0.0006960937500000001" ixy="0" ixz="0" iyy="6.1875e-05" iyz="0" izz="0.00071341875"/>
</inertial>
</link>
<joint name="robotfront_rgbd_camera_rgb_optical_joint" type="fixed">
<origin rpy="-1.5707963267948966 0 -1.5707963267948966" xyz="0.0 0.0 0.0"/>
<parent link="robotfront_rgbd_camera_rgb_frame"/>
<child link="robotfront_rgbd_camera_rgb_optical_frame"/>
</joint>
<link name="robotfront_rgbd_camera_rgb_optical_frame">
<inertial>
<origin rpy="1.5707963267948966 0 1.5707963267948966" xyz="0 0 0"/>
</inertial>
</link>
<joint name="robotfront_rgbd_camera_depth_joint" type="fixed">
<origin rpy="0 0 0" xyz="0.0 0.0375 0.0150"/>
<child link="robotfront_rgbd_camera_depth_frame"/>
</joint>
<link name="robotfront_rgbd_camera_depth_frame">
<inertial>
</inertial>
</link>
<joint name="robotfront_rgbd_camera_depth_optical_joint" type="fixed">
<origin rpy="-1.5707963267948966 0 -1.5707963267948966" xyz="0 0 0"/>
<parent link="robotfront_rgbd_camera_depth_frame"/>
<child link="robotfront_rgbd_camera_depth_optical_frame"/>
</joint>
<link name="robotfront_rgbd_camera_depth_optical_frame">
<inertial>
</inertial>
</link>
<gazebo reference="robotfront_rgbd_camera_link">
<sensor name="robotfront_rgbd_camera_depth_sensor" type="depth">
<always_on>true</always_on>
<update_rate>20.0</update_rate>
<camera>
<horizontal_fov>1.0471975511965976</horizontal_fov>
<image>
<format>R8G8B8</format>
<width>640</width>
<height>480</height>
</image>
<clip>
<near>0.05</near>
<far>3.5</far>
</clip>
</camera>
<plugin filename="libgazebo_ros_openni_kinect.so" name="robotfront_rgbd_camera_controller">
<cameraName>front_rgbd_camera</cameraName>
<updateRate>10</updateRate>
<imageTopicName>rgb/image_raw</imageTopicName>
<depthImageTopicName>depth/image_raw</depthImageTopicName>
<pointCloudTopicName>depth/points</pointCloudTopicName>
<cameraInfoTopicName>rgb/camera_info</cameraInfoTopicName>
<depthImageCameraInfoTopicName>depth/camera_info</depthImageCameraInfoTopicName>
<frameName>/robotfront_rgbd_camera_depth_optical_frame</frameName>
<baseline>0.1</baseline>
<distortion_k1>0.0</distortion_k1>
<distortion_k2>0.0</distortion_k2>
<distortion_k3>0.0</distortion_k3>
<distortion_t1>0.0</distortion_t1>
<distortion_t2>0.0</distortion_t2>
<pointCloudCutoff>0.4</pointCloudCutoff>
</plugin>
</sensor>
</gazebo>
<joint name="fr3_joint_robotbase_link" type="fixed">
<child link="fr3_link0"/>
<origin rpy="0 0 -3.141592653589793" xyz="-0.2731 0 0.56162"/>
</joint>
<!-- sub-link defining detailed meshes for collision with environment -->
<link name="fr3_link0">
<visual>
<geometry>
<mesh filename="/home/sesem/rbkairos_common/franka_description//meshes/visual/link0.dae"/>
</geometry>
</visual>
<collision>
<geometry>
<mesh filename="/home/sesem/rbkairos_common/franka_description//meshes/collision/link0.stl"/>
</geometry>
</collision>
</link>
<!-- sub-link defining coarse geometries of real robot's internal self-collision -->
<link name="fr3_link0_sc">
<collision>
<origin rpy="0 1.5707963267948966 0" xyz="-0.075 0 0.06"/>
<geometry>
<cylinder length="0.03" radius="0.09"/>
</geometry>
</collision>
<collision>
<origin xyz="-0.06 0 0.06"/>
<geometry>
<sphere radius="0.09"/>
</geometry>
</collision>
<collision>
<origin xyz="-0.09 0 0.06"/>
<geometry>
</geometry>
</collision>
</link>
<!-- fixed joint between both sub-links -->
<joint name="fr3_link0_sc_joint" type="fixed">
<origin rpy="0 0 0"/>
<parent link="fr3_link0"/>
<child link="fr3_link0_sc"/>
</joint>
<link name="fr3_link1">
<visual>
<geometry>
<mesh filename="/home/sesem/rbkairos_common/franka_description//meshes/visual/link1.dae"/>
</geometry>
</visual>
<collision>
<geometry>
<mesh filename="/home/sesem/rbkairos_common/franka_description//meshes/collision/link1.stl"/>
</geometry>
</collision>
</link>
<link name="fr3_link1_sc">
<collision>
<origin rpy="0 0 0" xyz="0 0 -0.1915"/>
<geometry>
<cylinder length="0.283" radius="0.09"/>
</geometry>
</collision>
<collision>
<origin xyz="0 0 -0.05000000000000002"/>
<geometry>
</geometry>
</collision>
<collision>
<origin xyz="0 0 -0.33299999999999996"/>
<geometry>
</geometry>
</collision>
</link>
<joint name="fr3_link1_sc_joint" type="fixed">
<parent link="fr3_link1"/>
<child link="fr3_link1_sc"/>
</joint>
<joint name="fr3_joint1" type="revolute">
<origin rpy="0 0 0" xyz="0 0 0.333"/>
<child link="fr3_link1"/>
<axis xyz="0 0 1"/>
<limit effort="87.0" lower="-2.3093" upper="2.3093" velocity="2.0"/>
<safety_controller k_position="100.0" k_velocity="40.0" soft_lower_limit="-2.3093" soft_upper_limit="2.3093"/>
<dynamics D="1" K="7000" damping="0.003" friction="0.0" mu_coulomb="0" mu_viscous="16"/>
</joint>
<link name="fr3_link2">
<visual>
<geometry>
<mesh filename="/home/sesem/rbkairos_common/franka_description//meshes/visual/link2.dae"/>
</geometry>
</visual>
<collision>
<geometry>
<mesh filename="/home/sesem/rbkairos_common/franka_description//meshes/collision/link2.stl"/>
</geometry>
</collision>
</link>
<link name="fr3_link2_sc">
<collision>
<geometry>
<cylinder length="0.12" radius="0.09"/>
</geometry>
</collision>
<collision>
<origin xyz="0 0 0.06"/>
<geometry>
</geometry>
</collision>
<collision>
<origin xyz="0 0 -0.06"/>
<geometry>
</geometry>
</collision>
</link>
<joint name="fr3_link2_sc_joint" type="fixed">
<parent link="fr3_link2"/>
<child link="fr3_link2_sc"/>
</joint>
<joint name="fr3_joint2" type="revolute">
<origin rpy="-1.5707963267948966 0 0" xyz="0 0 0"/>
<child link="fr3_link2"/>
<axis xyz="0 0 1"/>
<limit effort="87.0" lower="-1.5133" upper="1.5133" velocity="1.0"/>
<safety_controller k_position="100.0" k_velocity="40.0" soft_lower_limit="-1.5133" soft_upper_limit="1.5133"/>
</joint>
<link name="fr3_link3">
<visual>
<geometry>
<mesh filename="/home/sesem/rbkairos_common/franka_description//meshes/visual/link3.dae"/>
</geometry>
</visual>
<collision>
<geometry>
<mesh filename="/home/sesem/rbkairos_common/franka_description//meshes/collision/link3.stl"/>
</geometry>
</collision>
</link>
<link name="fr3_link3_sc">
<collision>
<origin rpy="0 0 0" xyz="0 0 -0.145"/>
<geometry>
<cylinder length="0.15" radius="0.09"/>
</geometry>
</collision>
<collision>
<origin xyz="0 0 -0.06999999999999999"/>
<geometry>
</geometry>
</collision>
<collision>
<origin xyz="0 0 -0.21999999999999997"/>
<geometry>
</geometry>
</collision>
</link>
<joint name="fr3_link3_sc_joint" type="fixed">
<parent link="fr3_link3"/>
<child link="fr3_link3_sc"/>
</joint>
<joint name="fr3_joint3" type="revolute">
<origin rpy="1.5707963267948966 0 0" xyz="0 -0.316 0"/>
<child link="fr3_link3"/>
<axis xyz="0 0 1"/>
<limit effort="87.0" lower="-2.4937" upper="2.4937" velocity="1.5"/>
<safety_controller k_position="100.0" k_velocity="40.0" soft_lower_limit="-2.4937" soft_upper_limit="2.4937"/>
</joint>
<link name="fr3_link4">
<visual>
<geometry>
<mesh filename="/home/sesem/rbkairos_common/franka_description//meshes/visual/link4.dae"/>
</geometry>
</visual>
<collision>
<geometry>
<mesh filename="/home/sesem/rbkairos_common/franka_description//meshes/collision/link4.stl"/>
</geometry>
</collision>
</link>
<link name="fr3_link4_sc">
<collision>
<geometry>
</geometry>
</collision>
<collision>
<geometry>
</geometry>
</collision>
<collision>
<geometry>
</geometry>
</collision>
</link>
<joint name="fr3_link4_sc_joint" type="fixed">
<parent link="fr3_link4"/>
<child link="fr3_link4_sc"/>
</joint>
<joint name="fr3_joint4" type="revolute">
<origin rpy="1.5707963267948966 0 0" xyz="0.0825 0 0"/>
<child link="fr3_link4"/>
<axis xyz="0 0 1"/>
<limit effort="87.0" lower="-2.7478" upper="-0.4461" velocity="1.25"/>
<safety_controller k_position="100.0" k_velocity="40.0" soft_lower_limit="-2.7478" soft_upper_limit="-0.4461"/>
</joint>
<link name="fr3_link5">
<visual>
<geometry>
<mesh filename="/home/sesem/rbkairos_common/franka_description//meshes/visual/link5.dae"/>
</geometry>
</visual>
<collision>
<geometry>
<mesh filename="/home/sesem/rbkairos_common/franka_description//meshes/collision/link5.stl"/>
</geometry>
</collision>
</link>
<link name="fr3_link5_sc">
<collision>
<origin rpy="0 0 0" xyz="0 0 -0.26"/>
<geometry>
<cylinder length="0.1" radius="0.09"/>
</geometry>
</collision>
<collision>
<origin xyz="0 0 -0.21000000000000002"/>
<geometry>
</geometry>
</collision>
<collision>
<origin xyz="0 0 -0.31"/>
<geometry>
</geometry>
</collision>
<collision>
<origin rpy="0 0 0.08" xyz="0 0.08 -0.13"/>
<geometry>
<cylinder length="0.14" radius="0.055"/>
</geometry>
</collision>
<collision>
<origin xyz="0 0.08 -0.06"/>
<geometry>
<sphere radius="0.055"/>
</geometry>
</collision>
<collision>
<origin xyz="0 0.08 -0.2"/>
<geometry>
</geometry>
</collision>
</link>
<joint name="fr3_link5_sc_joint" type="fixed">
<parent link="fr3_link5"/>
<child link="fr3_link5_sc"/>
</joint>
<joint name="fr3_joint5" type="revolute">
<origin rpy="-1.5707963267948966 0 0" xyz="-0.0825 0.384 0"/>
<child link="fr3_link5"/>
<axis xyz="0 0 1"/>
<limit effort="12.0" lower="-2.48" upper="2.48" velocity="3.0"/>
<safety_controller k_position="100.0" k_velocity="40.0" soft_lower_limit="-2.48" soft_upper_limit="2.48"/>
</joint>
<link name="fr3_link6">
<visual>
<geometry>
<mesh filename="/home/sesem/rbkairos_common/franka_description//meshes/visual/link6.dae"/>
</geometry>
</visual>
<collision>
<geometry>
<mesh filename="/home/sesem/rbkairos_common/franka_description//meshes/collision/link6.stl"/>
</geometry>
</collision>
</link>
<link name="fr3_link6_sc">
<collision>
<origin rpy="0 0 0" xyz="0 0 -0.03"/>
<geometry>
<cylinder length="0.08" radius="0.08"/>
</geometry>
</collision>
<collision>
<origin xyz="0 0 0.010000000000000002"/>
<geometry>
<sphere radius="0.08"/>
</geometry>
</collision>
<collision>
<origin xyz="0 0 -0.07"/>
<geometry>
</geometry>
</collision>
</link>
<joint name="fr3_link6_sc_joint" type="fixed">
<parent link="fr3_link6"/>
<child link="fr3_link6_sc"/>
</joint>
<joint name="fr3_joint6" type="revolute">
<child link="fr3_link6"/>
<axis xyz="0 0 1"/>
<limit effort="12.0" lower="0.8521" upper="4.2094" velocity="1.5"/>
<safety_controller k_position="100.0" k_velocity="40.0" soft_lower_limit="0.8521" soft_upper_limit="4.2094"/>
</joint>
<link name="fr3_link7">
<visual>
<geometry>
<mesh filename="/home/sesem/rbkairos_common/franka_description//meshes/visual/link7.dae"/>
</geometry>
</visual>
<collision>
<geometry>
<mesh filename="/home/sesem/rbkairos_common/franka_description//meshes/collision/link7.stl"/>
</geometry>
</collision>
</link>
<link name="fr3_link7_sc">
<collision>
<origin rpy="0 0 0" xyz="0 0 0.01"/>
<geometry>
<cylinder length="0.14" radius="0.07"/>
</geometry>
</collision>
<collision>
<origin xyz="0 0 0.08"/>
<geometry>
<sphere radius="0.07"/>
</geometry>
</collision>
<collision>
<origin xyz="0 0 -0.060000000000000005"/>
<geometry>
</geometry>
</collision>
<collision>
<origin rpy="0 1.5707963267948966 0" xyz="0.06 0 0.082"/>
<geometry>
<cylinder length="0.01" radius="0.06"/>
</geometry>
</collision>
<collision>
<origin xyz="0.065 0 0.082"/>
<geometry>
<sphere radius="0.06"/>
</geometry>
</collision>
<collision>
<origin xyz="0.055 0 0.082"/>
<geometry>
</geometry>
</collision>
</link>
<joint name="fr3_link7_sc_joint" type="fixed">
<origin rpy="0 0 0.7853981633974483"/>
<parent link="fr3_link7"/>
<child link="fr3_link7_sc"/>
</joint>
<joint name="fr3_joint7" type="revolute">
<origin rpy="1.5707963267948966 0 0" xyz="0.088 0 0"/>
<child link="fr3_link7"/>
<axis xyz="0 0 1"/>
<limit effort="12.0" lower="-2.6895" upper="2.6895" velocity="3.0"/>
<safety_controller k_position="100.0" k_velocity="40.0" soft_lower_limit="-2.6895" soft_upper_limit="2.6895"/>
</joint>
<link name="fr3_link8"/>
<joint name="fr3_joint8" type="fixed">
<origin rpy="0 0 0" xyz="0 0 0.107"/>
<child link="fr3_link8"/>
</joint>
<joint name="fr3_hand_joint" type="fixed">
<parent link="fr3_link8"/>
<child link="fr3_hand"/>
<origin rpy="0 0 -0.7853981633974483" xyz="0 0 0"/>
</joint>
<link name="fr3_hand">
<visual>
<geometry>
<mesh filename="/home/sesem/rbkairos_common/franka_description//meshes/visual/hand.dae"/>
</geometry>
</visual>
<collision>
<geometry>
<mesh filename="/home/sesem/rbkairos_common/franka_description//meshes/collision/hand.stl"/>
</geometry>
</collision>
</link>
<link name="fr3_hand_sc">
<collision>
<origin rpy="1.5707963267948966 0 0" xyz="0 0 0.04"/>
<geometry>
<cylinder length="0.1" radius="0.07"/>
</geometry>
</collision>
<collision>
<origin xyz="0 0.05 0.04"/>
<geometry>
</geometry>
</collision>
<collision>
<origin xyz="0 -0.05 0.04"/>
<geometry>
</geometry>
</collision>
<collision>
<origin rpy="1.5707963267948966 0 0" xyz="0 0 0.1"/>
<geometry>
<cylinder length="0.1" radius="0.05"/>
</geometry>
</collision>
<collision>
<origin xyz="0 0.05 0.1"/>
<geometry>
<sphere radius="0.05"/>
</geometry>
</collision>
<collision>
<origin xyz="0 -0.05 0.1"/>
<geometry>
</geometry>
</collision>
</link>
<joint name="fr3_hand_sc_joint" type="fixed">
<parent link="fr3_hand"/>
<child link="fr3_hand_sc"/>
</joint>
<!-- Define the hand_tcp frame -->
<link name="fr3_hand_tcp"/>
<joint name="fr3_hand_tcp_joint" type="fixed">
<origin rpy="0 0 0" xyz="0 0 0.1034"/>
<child link="fr3_hand_tcp"/>
</joint>
<link name="fr3_leftfinger">
<visual>
<geometry>
<mesh filename="/home/sesem/rbkairos_common/franka_description//meshes/visual/finger.dae"/>
</geometry>
</visual>
<!-- screw mount -->
<collision>
<origin rpy="0 0 0" xyz="0 18.5e-3 11e-3"/>
<geometry>
<box size="22e-3 15e-3 20e-3"/>
</geometry>
</collision>
<!-- cartriage sledge -->
<collision>
<origin rpy="0 0 0" xyz="0 6.8e-3 2.2e-3"/>
<geometry>
<box size="22e-3 8.8e-3 3.8e-3"/>
</geometry>
</collision>
<!-- diagonal finger -->
<collision>
<origin rpy="0.5235987755982988 0 0" xyz="0 15.9e-3 28.35e-3"/>
<geometry>
<box size="17.5e-3 7e-3 23.5e-3"/>
</geometry>
</collision>
<!-- rubber tip with which to grasp -->
<collision>
<origin rpy="0 0 0" xyz="0 7.58e-3 45.25e-3"/>
<geometry>
<box size="17.5e-3 15.2e-3 18.5e-3"/>
</geometry>
</collision>
</link>
<link name="fr3_rightfinger">
<visual>
<origin rpy="0 0 3.141592653589793" xyz="0 0 0"/>
<geometry>
</geometry>
</visual>
<collision>
<origin rpy="0 0 0" xyz="0 -18.5e-3 11e-3"/>
<geometry>
</geometry>
</collision>
<collision>
<origin rpy="0 0 0" xyz="0 -6.8e-3 2.2e-3"/>
<geometry>
</geometry>
</collision>
<collision>
<origin rpy="-0.5235987755982988 0 0" xyz="0 -15.9e-3 28.35e-3"/>
<geometry>
</geometry>
</collision>
<collision>
<origin rpy="0 0 0" xyz="0 -7.58e-3 45.25e-3"/>
<geometry>
</geometry>
</collision>
</link>
<joint name="fr3_finger_joint1" type="prismatic">
<child link="fr3_leftfinger"/>
<origin rpy="0 0 0" xyz="0 0 0.0584"/>
<axis xyz="0 1 0"/>
<limit effort="100" lower="0.0" upper="0.04" velocity="0.2"/>
<dynamics damping="0.3"/>
</joint>
<joint name="fr3_finger_joint2" type="prismatic">
<child link="fr3_rightfinger"/>
<axis xyz="0 -1 0"/>
<mimic joint="fr3_finger_joint1"/>
</joint>
<gazebo>
<plugin filename="libgazebo_ros_control.so" name="ros_control">
<robotParam>robot_description</robotParam>
<controlPeriod>0.001</controlPeriod>
<robotSimType>gazebo_ros_control/DefaultRobotHWSim</robotSimType>
<legacyModeNS>true</legacyModeNS>
</plugin>
</gazebo>
<gazebo>
<plugin filename="libgazebo_ros_planar_move.so" name="omni_steering">
<commandTopic>robotnik_base_control/cmd_vel</commandTopic>
<odometryTopic>robotnik_base_control/odom</odometryTopic>
<odometryFrame>robotodom</odometryFrame>
<odometryRate>50.0</odometryRate>
<robotBaseFrame>robotbase_footprint</robotBaseFrame>
<publishTF>True</publishTF>
<enableYAxis>true</enableYAxis>
</plugin>
</gazebo>
</robot>
