Good morning,
I’m trying to connect a sensor board based on Sony IMX-678 on Jetson Orin Nano Developer Kit.I’m using JetPack Version : 5.1.1(L4T : 35.3.1)
I wrote the driver based on IMX-219 and following the RidgeRun guide here
Attached is the device dtsi file.
The I2C communication with sensor is OK ad the sensor is succesfully probed.
When I try to grab frame with
v4l2-ctl -d /dev/video0 --set-ctrl bypass_mode=0 --stream-mmap
I got the following errors on dmesg
[ 57.094456] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 16384
[ 57.134462] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 16384
[ 57.174514] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 16384
[ 57.214633] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 16384
and the following trace
tracer: nop
entries-in-buffer/entries-written: 295/295 #P:6
_-----=> irqs-off
/ _----=> need-resched
| / _---=> hardirq/softirq
|| / _--=> preempt-depth
||| / delay
TASK-PID CPU# |||| TIMESTAMP FUNCTION
v4l2-ctl-2380 [005] .... 56.934720: tegra_channel_open: vi-output, imx678 10-001a
v4l2-ctl-2380 [005] .... 56.953367: tegra_channel_set_power: imx678 10-001a : 0x1
v4l2-ctl-2380 [005] .... 56.953380: camera_common_s_power: status : 0x1
v4l2-ctl-2380 [005] .... 56.976521: tegra_channel_set_power: 13e40000.host1x:nvcsi@15a00000- : 0x1
v4l2-ctl-2380 [005] .... 56.976524: csi_s_power: enable : 0x1
v4l2-ctl-2380 [005] .... 56.977381: tegra_channel_capture_setup: vnc_id 0 W 3856 H 2180 fmt c4
v4l2-ctl-2380 [005] .... 56.979634: tegra_channel_set_stream: enable : 0x1
v4l2-ctl-2380 [005] .... 56.983740: tegra_channel_set_stream: 13e40000.host1x:nvcsi@15a00000- : 0x1
v4l2-ctl-2380 [005] .... 56.983744: csi_s_stream: enable : 0x1
v4l2-ctl-2380 [005] .... 56.984550: tegra_channel_set_stream: imx678 10-001a : 0x1
kworker/2:9-143 [002] .... 57.049376: rtcpu_vinotify_event: tstamp:2508100018 cch:0 vi:1 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:80244670112 data:0x719e300010000000
kworker/2:9-143 [002] .... 57.049378: rtcpu_vinotify_event: tstamp:2508100311 cch:0 vi:1 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:80244679872 data:0x0000000031000001
kworker/2:9-143 [002] .... 57.049378: rtcpu_vinotify_event: tstamp:2508100597 cch:0 vi:1 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:80244771520 data:0x719e2d0010000000
kworker/2:9-143 [002] .... 57.049379: rtcpu_vinotify_event: tstamp:2508100845 cch:0 vi:1 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:80244781408 data:0x0000000031000002
kworker/2:9-143 [002] .... 57.105347: rtcpu_vinotify_event: tstamp:2511354957 cch:0 vi:1 tag:FS channel:0x00 frame:1 vi_tstamp:80359312128 data:0x0000000100000012
kworker/2:9-143 [002] .... 57.105347: rtcpu_vinotify_event: tstamp:2511355227 cch:0 vi:1 tag:ATOMP_FS channel:0x00 frame:1 vi_tstamp:80359312224 data:0x0000000800000000
kworker/2:9-143 [002] .... 57.105348: rtcpu_vinotify_event: tstamp:2511355512 cch:0 vi:1 tag:CHANSEL_FAULT channel:0x23 frame:1 vi_tstamp:80359333056 data:0x0000000000004004
kworker/2:9-143 [002] .... 57.105348: rtcpu_vinotify_event: tstamp:2511355759 cch:0 vi:1 tag:VIFALC_ACTIONLST channel:0x23 frame:1 vi_tstamp:80359385504 data:0x0000000001020001
kworker/2:9-143 [002] .... 57.105348: rtcpu_vinotify_event: tstamp:2511356041 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:1 vi_tstamp:80359350944 data:0x00000000000006e9
kworker/2:9-143 [002] .... 57.105348: rtcpu_vinotify_event: tstamp:2511356289 cch:0 vi:1 tag:CHANSEL_FAULT channel:0x23 frame:1 vi_tstamp:80359706496 data:0x0000000000004001
kworker/2:9-143 [002] .... 57.161380: rtcpu_vinotify_event: tstamp:2512462083 cch:0 vi:1 tag:CHANSEL_FAULT channel:0x23 frame:1 vi_tstamp:80398456672 data:0x0000000008834002
kworker/2:9-143 [002] .... 57.161381: rtcpu_vinotify_event: tstamp:2512462337 cch:0 vi:1 tag:FE channel:0x00 frame:1 vi_tstamp:80398457088 data:0x0000000100000022
kworker/2:9-143 [002] .... 57.161382: rtcpu_vinotify_event: tstamp:2512462632 cch:0 vi:1 tag:CHANSEL_SHORT_FRAME channel:0x04 frame:1 vi_tstamp:80398457120 data:0x0001200000000000
kworker/2:9-143 [002] .... 57.161383: rtcpu_vinotify_event: tstamp:2512462888 cch:0 vi:1 tag:ATOMP_FE channel:0x00 frame:1 vi_tstamp:80398457216 data:0x0000000800000000
kworker/2:9-143 [002] .... 57.161384: rtcpu_vinotify_event: tstamp:2512463168 cch:0 vi:1 tag:ATOMP_FRAME_DONE channel:0x23 frame:1 vi_tstamp:80398457888 data:0x0000000000000000
kworker/2:9-143 [002] .... 57.161385: rtcpu_vinotify_event: tstamp:2512463414 cch:0 vi:1 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:80398694144 data:0x719e300010000000
kworker/2:9-143 [002] .... 57.161386: rtcpu_vinotify_event: tstamp:2512982586 cch:0 vi:1 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:80398850368 data:0x0000000031000003
kworker/2:9-143 [002] .... 57.161387: rtcpu_vinotify_event: tstamp:2512982837 cch:0 vi:1 tag:FS channel:0x00 frame:2 vi_tstamp:80399310720 data:0x0000000200000012
kworker/2:9-143 [002] .... 57.161388: rtcpu_vinotify_event: tstamp:2512983125 cch:0 vi:1 tag:ATOMP_FS channel:0x00 frame:2 vi_tstamp:80399310784 data:0x0000000800000000
kworker/2:9-143 [002] .... 57.161389: rtcpu_vinotify_event: tstamp:2512983370 cch:0 vi:1 tag:CHANSEL_FAULT channel:0x23 frame:2 vi_tstamp:80399332064 data:0x0000000000004004
kworker/2:9-143 [002] .... 57.161390: rtcpu_vinotify_event: tstamp:2512983650 cch:0 vi:1 tag:VIFALC_ACTIONLST channel:0x23 frame:2 vi_tstamp:80399384096 data:0x0000000001020002
kworker/2:9-143 [002] .... 57.161391: rtcpu_vinotify_event: tstamp:2512983895 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:2 vi_tstamp:80399349888 data:0x00000000000006e9
kworker/2:9-143 [002] .... 57.161391: rtcpu_vinotify_event: tstamp:2512984170 cch:0 vi:1 tag:CHANSEL_FAULT channel:0x23 frame:2 vi_tstamp:80399705472 data:0x0000000000004001
kworker/2:9-143 [002] .... 57.217378: rtcpu_vinotify_event: tstamp:2513740673 cch:0 vi:1 tag:CHANSEL_FAULT channel:0x23 frame:2 vi_tstamp:80438455616 data:0x0000000008834002
kworker/2:9-143 [002] .... 57.217380: rtcpu_vinotify_event: tstamp:2513740958 cch:0 vi:1 tag:FE channel:0x00 frame:2 vi_tstamp:80438456064 data:0x0000000200000022
kworker/2:9-143 [002] .... 57.217381: rtcpu_vinotify_event: tstamp:2513741211 cch:0 vi:1 tag:CHANSEL_SHORT_FRAME channel:0x04 frame:2 vi_tstamp:80438456064 data:0x0001200000000000
kworker/2:9-143 [002] .... 57.217382: rtcpu_vinotify_event: tstamp:2513741495 cch:0 vi:1 tag:ATOMP_FE channel:0x00 frame:2 vi_tstamp:80438456128 data:0x0000000800000000
kworker/2:9-143 [002] .... 57.217382: rtcpu_vinotify_event: tstamp:2513741740 cch:0 vi:1 tag:ATOMP_FRAME_DONE channel:0x23 frame:2 vi_tstamp:80438456800 data:0x0000000000000000
kworker/2:9-143 [002] .... 57.217383: rtcpu_vinotify_event: tstamp:2513742018 cch:0 vi:1 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:80438692640 data:0x719e2d0010000000
kworker/2:9-143 [002] .... 57.217384: rtcpu_vinotify_event: tstamp:2513742269 cch:0 vi:1 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:80438738816 data:0x0000000031000004
kworker/2:9-143 [002] .... 57.217385: rtcpu_vinotify_event: tstamp:2513742548 cch:0 vi:1 tag:FS channel:0x00 frame:3 vi_tstamp:80439309696 data:0x0000000300000012
kworker/2:9-143 [002] .... 57.217386: rtcpu_vinotify_event: tstamp:2513742801 cch:0 vi:1 tag:ATOMP_FS channel:0x00 frame:3 vi_tstamp:80439309824 data:0x0000000800000000
kworker/2:9-143 [002] .... 57.217387: rtcpu_vinotify_event: tstamp:2514230726 cch:0 vi:1 tag:CHANSEL_FAULT channel:0x23 frame:3 vi_tstamp:80439331072 data:0x0000000000004004
kworker/2:9-143 [002] .... 57.217388: rtcpu_vinotify_event: tstamp:2514230975 cch:0 vi:1 tag:VIFALC_ACTIONLST channel:0x23 frame:3 vi_tstamp:80439397120 data:0x0000000001020003
kworker/2:9-143 [002] .... 57.217389: rtcpu_vinotify_event: tstamp:2514231259 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:3 vi_tstamp:80439348832 data:0x00000000000006e9
kworker/2:9-143 [002] .... 57.217390: rtcpu_vinotify_event: tstamp:2514231507 cch:0 vi:1 tag:CHANSEL_FAULT channel:0x23 frame:3 vi_tstamp:80439704448 data:0x0000000000004001
kworker/2:9-143 [002] .... 57.273364: rtcpu_vinotify_event: tstamp:2515315083 cch:0 vi:1 tag:CHANSEL_FAULT channel:0x23 frame:3 vi_tstamp:80478454560 data:0x0000000008834002
kworker/2:9-143 [002] .... 57.273366: rtcpu_vinotify_event: tstamp:2515315338 cch:0 vi:1 tag:FE channel:0x00 frame:3 vi_tstamp:80478455008 data:0x0000000300000022
kworker/2:9-143 [002] .... 57.273367: rtcpu_vinotify_event: tstamp:2515315628 cch:0 vi:1 tag:CHANSEL_SHORT_FRAME channel:0x04 frame:3 vi_tstamp:80478455008 data:0x0001200000000000
kworker/2:9-143 [002] .... 57.273368: rtcpu_vinotify_event: tstamp:2515315882 cch:0 vi:1 tag:ATOMP_FE channel:0x00 frame:3 vi_tstamp:80478455104 data:0x0000000800000000
kworker/2:9-143 [002] .... 57.273369: rtcpu_vinotify_event: tstamp:2515316164 cch:0 vi:1 tag:ATOMP_FRAME_DONE channel:0x23 frame:3 vi_tstamp:80478455776 data:0x0000000000000000
kworker/2:9-143 [002] .... 57.273370: rtcpu_vinotify_event: tstamp:2515316407 cch:0 vi:1 tag:FS channel:0x00 frame:4 vi_tstamp:80479308704 data:0x0000000400000012
kworker/2:9-143 [002] .... 57.273371: rtcpu_vinotify_event: tstamp:2515316692 cch:0 vi:1 tag:ATOMP_FS channel:0x00 frame:4 vi_tstamp:80479308800 data:0x0000000800000000
kworker/2:9-143 [002] .... 57.273372: rtcpu_vinotify_event: tstamp:2515316940 cch:0 vi:1 tag:CHANSEL_FAULT channel:0x23 frame:4 vi_tstamp:80479330048 data:0x0000000000004004
kworker/2:9-143 [002] .... 57.273373: rtcpu_vinotify_event: tstamp:2515317220 cch:0 vi:1 tag:VIFALC_ACTIONLST channel:0x23 frame:4 vi_tstamp:80479382080 data:0x0000000001020004
kworker/2:9-143 [002] .... 57.273373: rtcpu_vinotify_event: tstamp:2515317468 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:4 vi_tstamp:80479347840 data:0x00000000000006e9
kworker/2:9-143 [002] .... 57.273374: rtcpu_vinotify_event: tstamp:2515317745 cch:0 vi:1 tag:CHANSEL_FAULT channel:0x23 frame:4 vi_tstamp:80479703392 data:0x0000000000004001
kworker/2:9-143 [002] .... 57.273375: rtcpu_vinotify_event: tstamp:2516208552 cch:0 vi:1 tag:CHANSEL_FAULT channel:0x23 frame:4 vi_tstamp:80518453600 data:0x0000000008834002
kworker/2:9-143 [002] .... 57.273378: rtcpu_vinotify_error: tstamp:2516233195 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:5 vi_tstamp:80519328992 data:0x0000000000000249
kworker/2:9-143 [002] .... 57.273379: rtcpu_vinotify_event: tstamp:2516726347 cch:0 vi:1 tag:FE channel:0x00 frame:4 vi_tstamp:80518454016 data:0x0000000400000022
kworker/2:9-143 [002] .... 57.273380: rtcpu_vinotify_event: tstamp:2516726609 cch:0 vi:1 tag:CHANSEL_SHORT_FRAME channel:0x04 frame:4 vi_tstamp:80518454016 data:0x0001200000000000
kworker/2:9-143 [002] .... 57.273381: rtcpu_vinotify_event: tstamp:2516726902 cch:0 vi:1 tag:ATOMP_FE channel:0x00 frame:4 vi_tstamp:80518454112 data:0x0000000800000000
kworker/2:9-143 [002] .... 57.273382: rtcpu_vinotify_event: tstamp:2516727147 cch:0 vi:1 tag:ATOMP_FRAME_DONE channel:0x23 frame:4 vi_tstamp:80518454784 data:0x0000000000000000
kworker/2:9-143 [002] .... 57.273382: rtcpu_vinotify_event: tstamp:2516727427 cch:0 vi:1 tag:FS channel:0x00 frame:5 vi_tstamp:80519307712 data:0x0000000500000012
kworker/2:9-143 [002] .... 57.273383: rtcpu_vinotify_event: tstamp:2516727671 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:5 vi_tstamp:80519328992 data:0x0000000000000249
kworker/2:9-143 [002] .... 57.329552: rtcpu_vinotify_error: tstamp:2517483211 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:6 vi_tstamp:80559327968 data:0x0000000000000249
kworker/2:9-143 [002] .... 57.329557: rtcpu_vinotify_event: tstamp:2517811534 cch:0 vi:1 tag:FE channel:0x00 frame:5 vi_tstamp:80558453024 data:0x0000000500000022
kworker/2:9-143 [002] .... 57.329557: rtcpu_vinotify_event: tstamp:2517811782 cch:0 vi:1 tag:FS channel:0x00 frame:6 vi_tstamp:80559306656 data:0x0000000600000012
kworker/2:9-143 [002] .... 57.329558: rtcpu_vinotify_event: tstamp:2517812067 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:6 vi_tstamp:80559327968 data:0x0000000000000249
kworker/2:9-143 [002] .... 57.385371: rtcpu_vinotify_error: tstamp:2518733133 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:7 vi_tstamp:80599326976 data:0x0000000000000249
kworker/2:9-143 [002] .... 57.385375: rtcpu_vinotify_event: tstamp:2518895609 cch:0 vi:1 tag:FE channel:0x00 frame:6 vi_tstamp:80598452000 data:0x0000000600000022
kworker/2:9-143 [002] .... 57.385376: rtcpu_vinotify_event: tstamp:2518895914 cch:0 vi:1 tag:FS channel:0x00 frame:7 vi_tstamp:80599305632 data:0x0000000700000012
kworker/2:9-143 [002] .... 57.385376: rtcpu_vinotify_event: tstamp:2518896157 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:7 vi_tstamp:80599326976 data:0x0000000000000249
kworker/2:9-143 [002] .... 57.385376: rtcpu_vinotify_error: tstamp:2519984883 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:8 vi_tstamp:80639325984 data:0x0000000000000249
kworker/2:9-143 [002] .... 57.385377: rtcpu_vinotify_event: tstamp:2519985877 cch:0 vi:1 tag:FE channel:0x00 frame:7 vi_tstamp:80638450944 data:0x0000000700000022
kworker/2:9-143 [002] .... 57.441554: rtcpu_vinotify_event: tstamp:2520524214 cch:0 vi:1 tag:FS channel:0x00 frame:8 vi_tstamp:80639304608 data:0x0000000800000012
kworker/2:9-143 [002] .... 57.441556: rtcpu_vinotify_event: tstamp:2520524498 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:8 vi_tstamp:80639325984 data:0x0000000000000249
kworker/2:9-143 [002] .... 57.441557: rtcpu_vinotify_event: tstamp:2521204550 cch:0 vi:1 tag:FE channel:0x00 frame:8 vi_tstamp:80678449920 data:0x0000000800000022
kworker/2:9-143 [002] .... 57.441559: rtcpu_vinotify_error: tstamp:2521233065 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:9 vi_tstamp:80679324928 data:0x0000000000000249
kworker/2:9-143 [002] .... 57.441559: rtcpu_vinotify_event: tstamp:2521717330 cch:0 vi:1 tag:FS channel:0x00 frame:9 vi_tstamp:80679303616 data:0x0000000900000012
kworker/2:9-143 [002] .... 57.441560: rtcpu_vinotify_event: tstamp:2521717579 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:9 vi_tstamp:80679324928 data:0x0000000000000249
kworker/2:9-143 [002] .... 57.497371: rtcpu_vinotify_error: tstamp:2522483033 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:10 vi_tstamp:80719323904 data:0x0000000000000249
kworker/2:9-143 [002] .... 57.497373: rtcpu_vinotify_event: tstamp:2522802522 cch:0 vi:1 tag:FE channel:0x00 frame:9 vi_tstamp:80718448928 data:0x0000000900000022
kworker/2:9-143 [002] .... 57.497374: rtcpu_vinotify_event: tstamp:2522802770 cch:0 vi:1 tag:FS channel:0x00 frame:10 vi_tstamp:80719302592 data:0x0000000a00000012
kworker/2:9-143 [002] .... 57.497374: rtcpu_vinotify_event: tstamp:2522803060 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:10 vi_tstamp:80719323904 data:0x0000000000000249
kworker/2:9-143 [002] .... 57.497375: rtcpu_vinotify_error: tstamp:2523733006 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:11 vi_tstamp:80759322880 data:0x0000000000000249
kworker/2:9-143 [002] .... 57.553552: rtcpu_vinotify_event: tstamp:2523887706 cch:0 vi:1 tag:FE channel:0x00 frame:10 vi_tstamp:80758447936 data:0x0000000a00000022
kworker/2:9-143 [002] .... 57.553554: rtcpu_vinotify_event: tstamp:2523887990 cch:0 vi:1 tag:FS channel:0x00 frame:11 vi_tstamp:80759301568 data:0x0000000b00000012
kworker/2:9-143 [002] .... 57.553556: rtcpu_vinotify_event: tstamp:2523888235 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:11 vi_tstamp:80759322880 data:0x0000000000000249
kworker/2:9-143 [002] .... 57.553557: rtcpu_vinotify_event: tstamp:2524973078 cch:0 vi:1 tag:FE channel:0x00 frame:11 vi_tstamp:80798446880 data:0x0000000b00000022
kworker/2:9-143 [002] .... 57.553559: rtcpu_vinotify_error: tstamp:2524982964 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:12 vi_tstamp:80799321888 data:0x0000000000000249
kworker/2:9-143 [002] .... 57.553560: rtcpu_vinotify_event: tstamp:2525515436 cch:0 vi:1 tag:FS channel:0x00 frame:12 vi_tstamp:80799300544 data:0x0000000c00000012
kworker/2:9-143 [002] .... 57.553561: rtcpu_vinotify_event: tstamp:2525515718 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:12 vi_tstamp:80799321888 data:0x0000000000000249
kworker/2:9-143 [002] .... 57.609557: rtcpu_vinotify_error: tstamp:2526232938 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:13 vi_tstamp:80839320896 data:0x0000000000000249
kworker/2:9-143 [002] .... 57.609561: rtcpu_vinotify_event: tstamp:2526600622 cch:0 vi:1 tag:FE channel:0x00 frame:12 vi_tstamp:80838445888 data:0x0000000c00000022
kworker/2:9-143 [002] .... 57.609562: rtcpu_vinotify_event: tstamp:2526600905 cch:0 vi:1 tag:FS channel:0x00 frame:13 vi_tstamp:80839299520 data:0x0000000d00000012
kworker/2:9-143 [002] .... 57.609563: rtcpu_vinotify_event: tstamp:2526601150 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:13 vi_tstamp:80839320896 data:0x0000000000000249
kworker/2:9-143 [002] .... 57.665554: rtcpu_vinotify_error: tstamp:2527484166 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:14 vi_tstamp:80879319872 data:0x0000000000000249
kworker/2:9-143 [002] .... 57.665558: rtcpu_vinotify_event: tstamp:2527485173 cch:0 vi:1 tag:FE channel:0x00 frame:13 vi_tstamp:80878444832 data:0x0000000d00000022
kworker/2:9-143 [002] .... 57.665558: rtcpu_vinotify_event: tstamp:2527485425 cch:0 vi:1 tag:FS channel:0x00 frame:14 vi_tstamp:80879298528 data:0x0000000e00000012
kworker/2:9-143 [002] .... 57.665559: rtcpu_vinotify_event: tstamp:2528010477 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:14 vi_tstamp:80879319872 data:0x0000000000000249
kworker/2:9-143 [002] .... 57.665560: rtcpu_vinotify_error: tstamp:2528732876 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:15 vi_tstamp:80919318816 data:0x0000000000000249
kworker/2:9-143 [002] .... 57.721554: rtcpu_vinotify_event: tstamp:2529095661 cch:0 vi:1 tag:FE channel:0x00 frame:14 vi_tstamp:80918443840 data:0x0000000e00000022
kworker/2:9-143 [002] .... 57.721556: rtcpu_vinotify_event: tstamp:2529095952 cch:0 vi:1 tag:FS channel:0x00 frame:15 vi_tstamp:80919297536 data:0x0000000f00000012
kworker/2:9-143 [002] .... 57.721557: rtcpu_vinotify_event: tstamp:2529096196 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:15 vi_tstamp:80919318816 data:0x0000000000000249
kworker/2:9-143 [002] .... 57.721559: rtcpu_vinotify_error: tstamp:2529982845 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:16 vi_tstamp:80959317824 data:0x0000000000000249
kworker/2:9-143 [002] .... 57.721560: rtcpu_vinotify_event: tstamp:2530180834 cch:0 vi:1 tag:FE channel:0x00 frame:15 vi_tstamp:80958442848 data:0x0000000f00000022
kworker/2:9-143 [002] .... 57.721561: rtcpu_vinotify_event: tstamp:2530181083 cch:0 vi:1 tag:FS channel:0x00 frame:16 vi_tstamp:80959296480 data:0x0000001000000012
kworker/2:9-143 [002] .... 57.721561: rtcpu_vinotify_event: tstamp:2530181373 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:16 vi_tstamp:80959317824 data:0x0000000000000249
kworker/2:9-143 [002] .... 57.777359: rtcpu_vinotify_error: tstamp:2531232815 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:17 vi_tstamp:80999316832 data:0x0000000000000249
kworker/2:9-143 [002] .... 57.777362: rtcpu_vinotify_event: tstamp:2531266021 cch:0 vi:1 tag:FE channel:0x00 frame:16 vi_tstamp:80998441824 data:0x0000001000000022
kworker/2:9-143 [002] .... 57.777364: rtcpu_vinotify_event: tstamp:2531266299 cch:0 vi:1 tag:FS channel:0x00 frame:17 vi_tstamp:80999295456 data:0x0000001100000012
kworker/2:9-143 [002] .... 57.777364: rtcpu_vinotify_event: tstamp:2531266542 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:17 vi_tstamp:80999316832 data:0x0000000000000249
kworker/2:9-143 [002] .... 57.777365: rtcpu_vinotify_error: tstamp:2532482784 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:18 vi_tstamp:81039315808 data:0x0000000000000249
kworker/2:9-143 [002] .... 57.833365: rtcpu_vinotify_event: tstamp:2532893745 cch:0 vi:1 tag:FE channel:0x00 frame:17 vi_tstamp:81038440768 data:0x0000001100000022
kworker/2:9-143 [002] .... 57.833367: rtcpu_vinotify_event: tstamp:2532893998 cch:0 vi:1 tag:FS channel:0x00 frame:18 vi_tstamp:81039294432 data:0x0000001200000012
kworker/2:9-143 [002] .... 57.833368: rtcpu_vinotify_event: tstamp:2532894280 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:18 vi_tstamp:81039315808 data:0x0000000000000249
kworker/2:9-143 [002] .... 57.833371: rtcpu_vinotify_error: tstamp:2533732990 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:19 vi_tstamp:81079314784 data:0x0000000000000249
kworker/2:9-143 [002] .... 57.833372: rtcpu_vinotify_event: tstamp:2533734056 cch:0 vi:1 tag:FE channel:0x00 frame:18 vi_tstamp:81078439744 data:0x0000001200000022
kworker/2:9-143 [002] .... 57.833373: rtcpu_vinotify_event: tstamp:2533734349 cch:0 vi:1 tag:FS channel:0x00 frame:19 vi_tstamp:81079293440 data:0x0000001300000012
kworker/2:9-143 [002] .... 57.833374: rtcpu_vinotify_event: tstamp:2533734603 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:19 vi_tstamp:81079314784 data:0x0000000000000249
kworker/2:9-143 [002] .... 57.889552: rtcpu_vinotify_event: tstamp:2534955508 cch:0 vi:1 tag:FE channel:0x00 frame:19 vi_tstamp:81118438752 data:0x0000001300000022
kworker/2:9-143 [002] .... 57.889555: rtcpu_vinotify_error: tstamp:2534982719 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:20 vi_tstamp:81119313728 data:0x0000000000000249
kworker/2:9-143 [002] .... 57.889556: rtcpu_vinotify_event: tstamp:2535497859 cch:0 vi:1 tag:FS channel:0x00 frame:20 vi_tstamp:81119292416 data:0x0000001400000012
kworker/2:9-143 [002] .... 57.889557: rtcpu_vinotify_event: tstamp:2535498143 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:20 vi_tstamp:81119313728 data:0x0000000000000249
kworker/2:9-143 [002] .... 57.945357: rtcpu_vinotify_error: tstamp:2536232689 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:21 vi_tstamp:81159312736 data:0x0000000000000249
kworker/2:9-143 [002] .... 57.945357: rtcpu_vinotify_event: tstamp:2536583042 cch:0 vi:1 tag:FE channel:0x00 frame:20 vi_tstamp:81158437760 data:0x0000001400000022
kworker/2:9-143 [002] .... 57.945358: rtcpu_vinotify_event: tstamp:2536583331 cch:0 vi:1 tag:FS channel:0x00 frame:21 vi_tstamp:81159291392 data:0x0000001500000012
kworker/2:9-143 [002] .... 57.945358: rtcpu_vinotify_event: tstamp:2536583576 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:21 vi_tstamp:81159312736 data:0x0000000000000249
kworker/2:9-143 [002] .... 57.945359: rtcpu_vinotify_error: tstamp:2537482657 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:22 vi_tstamp:81199311744 data:0x0000000000000249
kworker/2:9-143 [002] .... 57.945359: rtcpu_vinotify_event: tstamp:2537668221 cch:0 vi:1 tag:FE channel:0x00 frame:21 vi_tstamp:81198436704 data:0x0000001500000022
kworker/2:9-143 [002] .... 57.945360: rtcpu_vinotify_event: tstamp:2537668471 cch:0 vi:1 tag:FS channel:0x00 frame:22 vi_tstamp:81199290368 data:0x0000001600000012
kworker/2:9-143 [002] .... 57.945360: rtcpu_vinotify_event: tstamp:2537668760 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:22 vi_tstamp:81199311744 data:0x0000000000000249
kworker/2:9-143 [002] .... 58.001366: rtcpu_vinotify_error: tstamp:2538732627 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:23 vi_tstamp:81239310720 data:0x0000000000000249
kworker/2:9-143 [002] .... 58.001367: rtcpu_vinotify_event: tstamp:2538753392 cch:0 vi:1 tag:FE channel:0x00 frame:22 vi_tstamp:81238435680 data:0x0000001600000022
kworker/2:9-143 [002] .... 58.001368: rtcpu_vinotify_event: tstamp:2538753683 cch:0 vi:1 tag:FS channel:0x00 frame:23 vi_tstamp:81239289408 data:0x0000001700000012
kworker/2:9-143 [002] .... 58.001369: rtcpu_vinotify_event: tstamp:2538753928 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:23 vi_tstamp:81239310720 data:0x0000000000000249
kworker/2:9-143 [002] .... 58.057551: rtcpu_vinotify_error: tstamp:2539982597 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:24 vi_tstamp:81279309664 data:0x0000000000000249
kworker/2:9-143 [002] .... 58.057555: rtcpu_vinotify_event: tstamp:2540381132 cch:0 vi:1 tag:FE channel:0x00 frame:23 vi_tstamp:81278434688 data:0x0000001700000022
kworker/2:9-143 [002] .... 58.057556: rtcpu_vinotify_event: tstamp:2540381380 cch:0 vi:1 tag:FS channel:0x00 frame:24 vi_tstamp:81279288384 data:0x0000001800000012
kworker/2:9-143 [002] .... 58.057557: rtcpu_vinotify_event: tstamp:2540381670 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:24 vi_tstamp:81279309664 data:0x0000000000000249
kworker/2:9-143 [002] .... 58.057557: rtcpu_vinotify_event: tstamp:2541204051 cch:0 vi:1 tag:FE channel:0x00 frame:24 vi_tstamp:81318433664 data:0x0000001800000022
kworker/2:9-143 [002] .... 58.057558: rtcpu_vinotify_error: tstamp:2541232558 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:25 vi_tstamp:81319308640 data:0x0000000000000249
kworker/2:9-143 [002] .... 58.113551: rtcpu_vinotify_event: tstamp:2541737234 cch:0 vi:1 tag:FS channel:0x00 frame:25 vi_tstamp:81319287328 data:0x0000001900000012
kworker/2:9-143 [002] .... 58.113553: rtcpu_vinotify_event: tstamp:2541737482 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:25 vi_tstamp:81319308640 data:0x0000000000000249
kworker/2:9-143 [002] .... 58.113555: rtcpu_vinotify_error: tstamp:2542482527 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:26 vi_tstamp:81359307616 data:0x0000000000000249
kworker/2:9-143 [002] .... 58.113556: rtcpu_vinotify_event: tstamp:2542822414 cch:0 vi:1 tag:FE channel:0x00 frame:25 vi_tstamp:81358432672 data:0x0000001900000022
kworker/2:9-143 [002] .... 58.113557: rtcpu_vinotify_event: tstamp:2542822724 cch:0 vi:1 tag:FS channel:0x00 frame:26 vi_tstamp:81359286304 data:0x0000001a00000012
kworker/2:9-143 [002] .... 58.113557: rtcpu_vinotify_event: tstamp:2542823012 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:26 vi_tstamp:81359307616 data:0x0000000000000249
kworker/2:9-143 [002] .... 58.169373: rtcpu_vinotify_error: tstamp:2543732500 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:27 vi_tstamp:81399306656 data:0x0000000000000249
kworker/2:9-143 [002] .... 58.169374: rtcpu_vinotify_event: tstamp:2543907600 cch:0 vi:1 tag:FE channel:0x00 frame:26 vi_tstamp:81398431648 data:0x0000001a00000022
kworker/2:9-143 [002] .... 58.169375: rtcpu_vinotify_event: tstamp:2543907884 cch:0 vi:1 tag:FS channel:0x00 frame:27 vi_tstamp:81399285280 data:0x0000001b00000012
kworker/2:9-143 [002] .... 58.169376: rtcpu_vinotify_event: tstamp:2543908130 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:27 vi_tstamp:81399306656 data:0x0000000000000249
kworker/2:9-143 [002] .... 58.225367: rtcpu_vinotify_error: tstamp:2544982457 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:28 vi_tstamp:81439305632 data:0x0000000000000249
kworker/2:9-143 [002] .... 58.225371: rtcpu_vinotify_event: tstamp:2544992780 cch:0 vi:1 tag:FE channel:0x00 frame:27 vi_tstamp:81438430592 data:0x0000001b00000022
kworker/2:9-143 [002] .... 58.225372: rtcpu_vinotify_event: tstamp:2544993029 cch:0 vi:1 tag:FS channel:0x00 frame:28 vi_tstamp:81439284288 data:0x0000001c00000012
kworker/2:9-143 [002] .... 58.225373: rtcpu_vinotify_event: tstamp:2544993318 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:28 vi_tstamp:81439305632 data:0x0000000000000249
kworker/2:9-143 [002] .... 58.225374: rtcpu_vinotify_error: tstamp:2546232435 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:29 vi_tstamp:81479304608 data:0x0000000000000249
kworker/2:9-143 [002] .... 58.281357: rtcpu_vinotify_event: tstamp:2546619413 cch:0 vi:1 tag:FE channel:0x00 frame:28 vi_tstamp:81478429600 data:0x0000001c00000022
kworker/2:9-143 [002] .... 58.281359: rtcpu_vinotify_event: tstamp:2546619702 cch:0 vi:1 tag:FS channel:0x00 frame:29 vi_tstamp:81479283296 data:0x0000001d00000012
kworker/2:9-143 [002] .... 58.281360: rtcpu_vinotify_event: tstamp:2546619948 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:29 vi_tstamp:81479304608 data:0x0000000000000249
kworker/2:9-143 [002] .... 58.281363: rtcpu_vinotify_error: tstamp:2547483654 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:30 vi_tstamp:81519303552 data:0x0000000000000249
kworker/2:9-143 [002] .... 58.281363: rtcpu_vinotify_event: tstamp:2547484651 cch:0 vi:1 tag:FE channel:0x00 frame:29 vi_tstamp:81518428608 data:0x0000001d00000022
kworker/2:9-143 [002] .... 58.281364: rtcpu_vinotify_event: tstamp:2547484903 cch:0 vi:1 tag:FS channel:0x00 frame:30 vi_tstamp:81519282240 data:0x0000001e00000012
kworker/2:9-143 [002] .... 58.281365: rtcpu_vinotify_event: tstamp:2547975986 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:30 vi_tstamp:81519303552 data:0x0000000000000249
kworker/2:9-143 [002] .... 58.337555: rtcpu_vinotify_error: tstamp:2548732369 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:31 vi_tstamp:81559302560 data:0x0000000000000249
kworker/2:9-143 [002] .... 58.337560: rtcpu_vinotify_event: tstamp:2549061172 cch:0 vi:1 tag:FE channel:0x00 frame:30 vi_tstamp:81558427584 data:0x0000001e00000022
kworker/2:9-143 [002] .... 58.337561: rtcpu_vinotify_event: tstamp:2549061463 cch:0 vi:1 tag:FS channel:0x00 frame:31 vi_tstamp:81559281216 data:0x0000001f00000012
kworker/2:9-143 [002] .... 58.337561: rtcpu_vinotify_event: tstamp:2549061708 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:31 vi_tstamp:81559302560 data:0x0000000000000249
kworker/2:9-143 [002] .... 58.337562: rtcpu_vinotify_error: tstamp:2549982474 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:32 vi_tstamp:81599301568 data:0x0000000000000249
kworker/2:9-143 [002] .... 58.393556: rtcpu_vinotify_event: tstamp:2550146355 cch:0 vi:1 tag:FE channel:0x00 frame:31 vi_tstamp:81598426528 data:0x0000001f00000022
kworker/2:9-143 [002] .... 58.393558: rtcpu_vinotify_event: tstamp:2550146603 cch:0 vi:1 tag:FS channel:0x00 frame:32 vi_tstamp:81599280160 data:0x0000002000000012
kworker/2:9-143 [002] .... 58.393558: rtcpu_vinotify_event: tstamp:2550146893 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:32 vi_tstamp:81599301568 data:0x0000000000000249
kworker/2:9-143 [002] .... 58.393560: rtcpu_vinotify_error: tstamp:2551232307 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:33 vi_tstamp:81639300544 data:0x0000000000000249
kworker/2:9-143 [002] .... 58.393561: rtcpu_vinotify_event: tstamp:2551235953 cch:0 vi:1 tag:FE channel:0x00 frame:32 vi_tstamp:81638425504 data:0x0000002000000022
kworker/2:9-143 [002] .... 58.393562: rtcpu_vinotify_event: tstamp:2551236231 cch:0 vi:1 tag:FS channel:0x00 frame:33 vi_tstamp:81639279200 data:0x0000002100000012
kworker/2:9-143 [002] .... 58.393562: rtcpu_vinotify_event: tstamp:2551236478 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:33 vi_tstamp:81639300544 data:0x0000000000000249
kworker/2:9-143 [002] .... 58.449555: rtcpu_vinotify_error: tstamp:2552482272 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:34 vi_tstamp:81679299488 data:0x0000000000000249
kworker/2:9-143 [002] .... 58.449559: rtcpu_vinotify_event: tstamp:2552859266 cch:0 vi:1 tag:FE channel:0x00 frame:33 vi_tstamp:81678424512 data:0x0000002100000022
kworker/2:9-143 [002] .... 58.449560: rtcpu_vinotify_event: tstamp:2552859515 cch:0 vi:1 tag:FS channel:0x00 frame:34 vi_tstamp:81679278208 data:0x0000002200000012
kworker/2:9-143 [002] .... 58.449561: rtcpu_vinotify_event: tstamp:2552859796 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:34 vi_tstamp:81679299488 data:0x0000000000000249
kworker/2:9-143 [002] .... 58.505373: rtcpu_vinotify_error: tstamp:2553732446 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:35 vi_tstamp:81719298464 data:0x0000000000000249
kworker/2:9-143 [002] .... 58.505375: rtcpu_vinotify_event: tstamp:2553733514 cch:0 vi:1 tag:FE channel:0x00 frame:34 vi_tstamp:81718423520 data:0x0000002200000022
kworker/2:9-143 [002] .... 58.505375: rtcpu_vinotify_event: tstamp:2553733807 cch:0 vi:1 tag:FS channel:0x00 frame:35 vi_tstamp:81719277152 data:0x0000002300000012
kworker/2:9-143 [002] .... 58.505376: rtcpu_vinotify_event: tstamp:2553734052 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:35 vi_tstamp:81719298464 data:0x0000000000000249
kworker/2:9-143 [002] .... 58.505377: rtcpu_vinotify_event: tstamp:2554975398 cch:0 vi:1 tag:FE channel:0x00 frame:35 vi_tstamp:81758422496 data:0x0000002300000022
kworker/2:9-143 [002] .... 58.505378: rtcpu_vinotify_error: tstamp:2554982212 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:36 vi_tstamp:81759297472 data:0x0000000000000249
kworker/2:9-143 [002] .... 58.561554: rtcpu_vinotify_event: tstamp:2555517754 cch:0 vi:1 tag:FS channel:0x00 frame:36 vi_tstamp:81759276096 data:0x0000002400000012
kworker/2:9-143 [002] .... 58.561556: rtcpu_vinotify_event: tstamp:2555518034 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:36 vi_tstamp:81759297472 data:0x0000000000000249
kworker/2:9-143 [002] .... 58.561557: rtcpu_vinotify_error: tstamp:2556232180 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:37 vi_tstamp:81799296448 data:0x0000000000000249
kworker/2:9-143 [002] .... 58.561558: rtcpu_vinotify_event: tstamp:2556602929 cch:0 vi:1 tag:FE channel:0x00 frame:36 vi_tstamp:81798421440 data:0x0000002400000022
kworker/2:9-143 [002] .... 58.561559: rtcpu_vinotify_event: tstamp:2556603217 cch:0 vi:1 tag:FS channel:0x00 frame:37 vi_tstamp:81799275104 data:0x0000002500000012
kworker/2:9-143 [002] .... 58.561560: rtcpu_vinotify_event: tstamp:2556603463 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:37 vi_tstamp:81799296448 data:0x0000000000000249
kworker/2:9-143 [002] .... 58.617553: rtcpu_vinotify_error: tstamp:2557482147 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:38 vi_tstamp:81839295424 data:0x0000000000000249
kworker/2:9-143 [002] .... 58.617557: rtcpu_vinotify_event: tstamp:2557688121 cch:0 vi:1 tag:FE channel:0x00 frame:37 vi_tstamp:81838420416 data:0x0000002500000022
kworker/2:9-143 [002] .... 58.617558: rtcpu_vinotify_event: tstamp:2557688370 cch:0 vi:1 tag:FS channel:0x00 frame:38 vi_tstamp:81839274112 data:0x0000002600000012
kworker/2:9-143 [002] .... 58.617558: rtcpu_vinotify_event: tstamp:2557688662 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:38 vi_tstamp:81839295424 data:0x0000000000000249
kworker/2:9-143 [002] .... 58.617559: rtcpu_vinotify_error: tstamp:2558732111 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:39 vi_tstamp:81879294400 data:0x0000000000000249
kworker/2:9-143 [002] .... 58.617560: rtcpu_vinotify_event: tstamp:2558773305 cch:0 vi:1 tag:FE channel:0x00 frame:38 vi_tstamp:81878419424 data:0x0000002600000022
kworker/2:9-143 [002] .... 58.617561: rtcpu_vinotify_event: tstamp:2558773613 cch:0 vi:1 tag:FS channel:0x00 frame:39 vi_tstamp:81879273120 data:0x0000002700000012
kworker/2:9-143 [002] .... 58.617561: rtcpu_vinotify_event: tstamp:2558773860 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:39 vi_tstamp:81879294400 data:0x0000000000000249
kworker/2:9-143 [002] .... 58.673554: rtcpu_vinotify_error: tstamp:2559982081 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:40 vi_tstamp:81919293376 data:0x0000000000000249
kworker/2:9-143 [002] .... 58.673558: rtcpu_vinotify_event: tstamp:2560399931 cch:0 vi:1 tag:FE channel:0x00 frame:39 vi_tstamp:81918418432 data:0x0000002700000022
kworker/2:9-143 [002] .... 58.673559: rtcpu_vinotify_event: tstamp:2560400184 cch:0 vi:1 tag:FS channel:0x00 frame:40 vi_tstamp:81919272064 data:0x0000002800000012
kworker/2:9-143 [002] .... 58.673560: rtcpu_vinotify_event: tstamp:2560400477 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:40 vi_tstamp:81919293376 data:0x0000000000000249
kworker/2:9-143 [002] .... 58.729378: rtcpu_vinotify_event: tstamp:2561203543 cch:0 vi:1 tag:FE channel:0x00 frame:40 vi_tstamp:81958417376 data:0x0000002800000022
kworker/2:9-143 [002] .... 58.729382: rtcpu_vinotify_error: tstamp:2561232075 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:41 vi_tstamp:81959292384 data:0x0000000000000249
kworker/2:9-143 [002] .... 58.729383: rtcpu_vinotify_event: tstamp:2561702801 cch:0 vi:1 tag:FS channel:0x00 frame:41 vi_tstamp:81959271008 data:0x0000002900000012
kworker/2:9-143 [002] .... 58.729383: rtcpu_vinotify_event: tstamp:2561703055 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:41 vi_tstamp:81959292384 data:0x0000000000000249
kworker/2:9-143 [002] .... 58.785552: rtcpu_vinotify_error: tstamp:2562482076 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:42 vi_tstamp:81999291360 data:0x0000000000000249
kworker/2:9-143 [002] .... 58.785557: rtcpu_vinotify_event: tstamp:2562787981 cch:0 vi:1 tag:FE channel:0x00 frame:41 vi_tstamp:81998416352 data:0x0000002900000022
kworker/2:9-143 [002] .... 58.785558: rtcpu_vinotify_event: tstamp:2562788233 cch:0 vi:1 tag:FS channel:0x00 frame:42 vi_tstamp:81999270016 data:0x0000002a00000012
kworker/2:9-143 [002] .... 58.785558: rtcpu_vinotify_event: tstamp:2562788524 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:42 vi_tstamp:81999291360 data:0x0000000000000249
kworker/2:9-143 [002] .... 58.785559: rtcpu_vinotify_error: tstamp:2563731988 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:43 vi_tstamp:82039290368 data:0x0000000000000249
kworker/2:9-143 [002] .... 58.785560: rtcpu_vinotify_event: tstamp:2563873156 cch:0 vi:1 tag:FE channel:0x00 frame:42 vi_tstamp:82038415328 data:0x0000002a00000022
kworker/2:9-143 [002] .... 58.785561: rtcpu_vinotify_event: tstamp:2563873444 cch:0 vi:1 tag:FS channel:0x00 frame:43 vi_tstamp:82039269024 data:0x0000002b00000012
kworker/2:9-143 [002] .... 58.785561: rtcpu_vinotify_event: tstamp:2563873685 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:43 vi_tstamp:82039290368 data:0x0000000000000249
kworker/2:9-143 [002] .... 58.841373: rtcpu_vinotify_event: tstamp:2564957430 cch:0 vi:1 tag:FE channel:0x00 frame:43 vi_tstamp:82078414336 data:0x0000002b00000022
kworker/2:9-143 [002] .... 58.841374: rtcpu_vinotify_error: tstamp:2564981952 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:44 vi_tstamp:82079289312 data:0x0000000000000249
kworker/2:9-143 [002] .... 58.841375: rtcpu_vinotify_event: tstamp:2565499782 cch:0 vi:1 tag:FS channel:0x00 frame:44 vi_tstamp:82079268000 data:0x0000002c00000012
kworker/2:9-143 [002] .... 58.841376: rtcpu_vinotify_event: tstamp:2565500062 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:44 vi_tstamp:82079289312 data:0x0000000000000249
kworker/2:9-143 [002] .... 58.897556: rtcpu_vinotify_error: tstamp:2566232028 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:45 vi_tstamp:82119288288 data:0x0000000000000249
kworker/2:9-143 [002] .... 58.897559: rtcpu_vinotify_event: tstamp:2566584949 cch:0 vi:1 tag:FE channel:0x00 frame:44 vi_tstamp:82118413312 data:0x0000002c00000022
kworker/2:9-143 [002] .... 58.897560: rtcpu_vinotify_event: tstamp:2566585228 cch:0 vi:1 tag:FS channel:0x00 frame:45 vi_tstamp:82119266976 data:0x0000002d00000012
kworker/2:9-143 [002] .... 58.897560: rtcpu_vinotify_event: tstamp:2566585471 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:45 vi_tstamp:82119288288 data:0x0000000000000249
kworker/2:9-143 [002] .... 58.897561: rtcpu_vinotify_error: tstamp:2567483145 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:46 vi_tstamp:82159287296 data:0x0000000000000249
kworker/2:9-143 [002] .... 58.897562: rtcpu_vinotify_event: tstamp:2567484147 cch:0 vi:1 tag:FE channel:0x00 frame:45 vi_tstamp:82158412320 data:0x0000002d00000022
kworker/2:9-143 [002] .... 58.897563: rtcpu_vinotify_event: tstamp:2567484397 cch:0 vi:1 tag:FS channel:0x00 frame:46 vi_tstamp:82159265920 data:0x0000002e00000012
kworker/2:9-143 [002] .... 58.953357: rtcpu_vinotify_event: tstamp:2567995857 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:46 vi_tstamp:82159287296 data:0x0000000000000249
kworker/2:9-143 [002] .... 58.953358: rtcpu_vinotify_error: tstamp:2568731863 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:47 vi_tstamp:82199286304 data:0x0000000000000249
kworker/2:9-143 [002] .... 58.953358: rtcpu_vinotify_event: tstamp:2569081032 cch:0 vi:1 tag:FE channel:0x00 frame:46 vi_tstamp:82198411232 data:0x0000002e00000022
kworker/2:9-143 [002] .... 58.953359: rtcpu_vinotify_event: tstamp:2569081315 cch:0 vi:1 tag:FS channel:0x00 frame:47 vi_tstamp:82199264928 data:0x0000002f00000012
kworker/2:9-143 [002] .... 58.953359: rtcpu_vinotify_event: tstamp:2569081563 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:47 vi_tstamp:82199286304 data:0x0000000000000249
kworker/2:9-143 [002] .... 59.009360: rtcpu_vinotify_error: tstamp:2569981832 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:48 vi_tstamp:82239285216 data:0x0000000000000249
kworker/2:9-143 [002] .... 59.009361: rtcpu_vinotify_event: tstamp:2570166199 cch:0 vi:1 tag:FE channel:0x00 frame:47 vi_tstamp:82238410240 data:0x0000002f00000022
kworker/2:9-143 [002] .... 59.009362: rtcpu_vinotify_event: tstamp:2570166509 cch:0 vi:1 tag:FS channel:0x00 frame:48 vi_tstamp:82239263936 data:0x0000003000000012
kworker/2:9-143 [002] .... 59.009363: rtcpu_vinotify_event: tstamp:2570166797 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:48 vi_tstamp:82239285216 data:0x0000000000000249
kworker/2:9-143 [002] .... 59.065550: rtcpu_vinotify_error: tstamp:2571231799 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:49 vi_tstamp:82279284224 data:0x0000000000000249
kworker/2:9-143 [002] .... 59.065554: rtcpu_vinotify_event: tstamp:2571251380 cch:0 vi:1 tag:FE channel:0x00 frame:48 vi_tstamp:82278409248 data:0x0000003000000022
kworker/2:9-143 [002] .... 59.065555: rtcpu_vinotify_event: tstamp:2571251666 cch:0 vi:1 tag:FS channel:0x00 frame:49 vi_tstamp:82279262912 data:0x0000003100000012
kworker/2:9-143 [002] .... 59.065556: rtcpu_vinotify_event: tstamp:2571251911 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:49 vi_tstamp:82279284224 data:0x0000000000000249
kworker/2:9-143 [002] .... 59.065556: rtcpu_vinotify_error: tstamp:2572481766 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:50 vi_tstamp:82319283232 data:0x0000000000000249
kworker/2:9-143 [002] .... 59.121555: rtcpu_vinotify_event: tstamp:2572879129 cch:0 vi:1 tag:FE channel:0x00 frame:49 vi_tstamp:82318408256 data:0x0000003100000022
kworker/2:9-143 [002] .... 59.121557: rtcpu_vinotify_event: tstamp:2572879384 cch:0 vi:1 tag:FS channel:0x00 frame:50 vi_tstamp:82319261856 data:0x0000003200000012
kworker/2:9-143 [002] .... 59.121559: rtcpu_vinotify_event: tstamp:2572879677 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:50 vi_tstamp:82319283232 data:0x0000000000000249
kworker/2:9-143 [002] .... 59.121561: rtcpu_vinotify_error: tstamp:2573731941 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:51 vi_tstamp:82359282240 data:0x0000000000000249
kworker/2:9-143 [002] .... 59.121562: rtcpu_vinotify_event: tstamp:2573733016 cch:0 vi:1 tag:FE channel:0x00 frame:50 vi_tstamp:82358407168 data:0x0000003200000022
kworker/2:9-143 [002] .... 59.121562: rtcpu_vinotify_event: tstamp:2573733305 cch:0 vi:1 tag:FS channel:0x00 frame:51 vi_tstamp:82359260832 data:0x0000003300000012
kworker/2:9-143 [002] .... 59.121563: rtcpu_vinotify_event: tstamp:2573733546 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:51 vi_tstamp:82359282240 data:0x0000000000000249
kworker/2:9-143 [002] .... 59.177376: rtcpu_vinotify_error: tstamp:2574981704 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:52 vi_tstamp:82399281184 data:0x0000000000000249
kworker/2:9-143 [002] .... 59.177380: rtcpu_vinotify_event: tstamp:2574995066 cch:0 vi:1 tag:FE channel:0x00 frame:51 vi_tstamp:82398406144 data:0x0000003300000022
kworker/2:9-143 [002] .... 59.177381: rtcpu_vinotify_event: tstamp:2574995310 cch:0 vi:1 tag:FS channel:0x00 frame:52 vi_tstamp:82399259840 data:0x0000003400000012
kworker/2:9-143 [002] .... 59.177382: rtcpu_vinotify_event: tstamp:2574995595 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:52 vi_tstamp:82399281184 data:0x0000000000000249
kworker/2:9-143 [002] .... 59.177383: rtcpu_vinotify_error: tstamp:2576231661 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:53 vi_tstamp:82439280160 data:0x0000000000000249
kworker/2:9-143 [002] .... 59.233375: rtcpu_vinotify_event: tstamp:2576622798 cch:0 vi:1 tag:FE channel:0x00 frame:52 vi_tstamp:82438405152 data:0x0000003400000022
kworker/2:9-143 [002] .... 59.233377: rtcpu_vinotify_event: tstamp:2576623082 cch:0 vi:1 tag:FS channel:0x00 frame:53 vi_tstamp:82439258848 data:0x0000003500000012
kworker/2:9-143 [002] .... 59.233378: rtcpu_vinotify_event: tstamp:2576623323 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:53 vi_tstamp:82439280160 data:0x0000000000000249
kworker/2:9-143 [002] .... 59.233381: rtcpu_vinotify_error: tstamp:2577481636 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:54 vi_tstamp:82479279104 data:0x0000000000000249
kworker/2:9-143 [002] .... 59.233382: rtcpu_vinotify_event: tstamp:2577707973 cch:0 vi:1 tag:FE channel:0x00 frame:53 vi_tstamp:82478404160 data:0x0000003500000022
kworker/2:9-143 [002] .... 59.233383: rtcpu_vinotify_event: tstamp:2577708221 cch:0 vi:1 tag:FS channel:0x00 frame:54 vi_tstamp:82479257792 data:0x0000003600000012
kworker/2:9-143 [002] .... 59.233383: rtcpu_vinotify_event: tstamp:2577708510 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:54 vi_tstamp:82479279104 data:0x0000000000000249
kworker/2:9-143 [002] .... 59.289373: rtcpu_vinotify_error: tstamp:2578731607 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:55 vi_tstamp:82519278112 data:0x0000000000000249
kworker/2:9-143 [002] .... 59.289377: rtcpu_vinotify_event: tstamp:2578792110 cch:0 vi:1 tag:FE channel:0x00 frame:54 vi_tstamp:82518403136 data:0x0000003600000022
kworker/2:9-143 [002] .... 59.289378: rtcpu_vinotify_event: tstamp:2578792395 cch:0 vi:1 tag:FS channel:0x00 frame:55 vi_tstamp:82519256800 data:0x0000003700000012
kworker/2:9-143 [002] .... 59.289378: rtcpu_vinotify_event: tstamp:2578792640 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:55 vi_tstamp:82519278112 data:0x0000000000000249
kworker/2:9-143 [002] .... 59.345552: rtcpu_vinotify_error: tstamp:2579981577 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:56 vi_tstamp:82559277120 data:0x0000000000000249
kworker/2:9-143 [002] .... 59.345556: rtcpu_vinotify_event: tstamp:2580419781 cch:0 vi:1 tag:FE channel:0x00 frame:55 vi_tstamp:82558402112 data:0x0000003700000022
kworker/2:9-143 [002] .... 59.345557: rtcpu_vinotify_event: tstamp:2580420035 cch:0 vi:1 tag:FS channel:0x00 frame:56 vi_tstamp:82559255744 data:0x0000003800000012
kworker/2:9-143 [002] .... 59.345557: rtcpu_vinotify_event: tstamp:2580420353 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:56 vi_tstamp:82559277120 data:0x0000000000000249
kworker/2:9-143 [002] .... 59.345558: rtcpu_vinotify_event: tstamp:2581203091 cch:0 vi:1 tag:FE channel:0x00 frame:56 vi_tstamp:82598401088 data:0x0000003800000022
kworker/2:9-143 [002] .... 59.345559: rtcpu_vinotify_error: tstamp:2581231587 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:57 vi_tstamp:82599276096 data:0x0000000000000249
kworker/2:9-143 [002] .... 59.401561: rtcpu_vinotify_event: tstamp:2581722614 cch:0 vi:1 tag:FS channel:0x00 frame:57 vi_tstamp:82599254752 data:0x0000003900000012
kworker/2:9-143 [002] .... 59.401563: rtcpu_vinotify_event: tstamp:2581722867 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:57 vi_tstamp:82599276096 data:0x0000000000000249
kworker/2:9-143 [002] .... 59.401566: rtcpu_vinotify_error: tstamp:2582481552 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:58 vi_tstamp:82639275040 data:0x0000000000000249
kworker/2:9-143 [002] .... 59.401566: rtcpu_vinotify_event: tstamp:2582807805 cch:0 vi:1 tag:FE channel:0x00 frame:57 vi_tstamp:82638400064 data:0x0000003900000022
kworker/2:9-143 [002] .... 59.401567: rtcpu_vinotify_event: tstamp:2582808056 cch:0 vi:1 tag:FS channel:0x00 frame:58 vi_tstamp:82639253760 data:0x0000003a00000012
kworker/2:9-143 [002] .... 59.401568: rtcpu_vinotify_event: tstamp:2582808348 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:58 vi_tstamp:82639275040 data:0x0000000000000249
v4l2-ctl-2380 [005] .... 59.435754: tegra_channel_close: vi-output, imx678 10-001a
v4l2-ctl-2380 [005] .... 59.435808: tegra_channel_set_stream: enable : 0x0
v4l2-ctl-2380 [005] .... 59.435808: tegra_channel_set_stream: imx678 10-001a : 0x0
v4l2-ctl-2380 [005] .... 59.436243: tegra_channel_set_stream: 13e40000.host1x:nvcsi@15a00000- : 0x0
v4l2-ctl-2380 [005] .... 59.436245: csi_s_stream: enable : 0x0
v4l2-ctl-2380 [000] .... 59.441224: tegra_channel_set_power: imx678 10-001a : 0x0
v4l2-ctl-2380 [000] .... 59.441235: camera_common_s_power: status : 0x0
v4l2-ctl-2380 [005] .... 59.441287: tegra_channel_set_power: 13e40000.host1x:nvcsi@15a00000- : 0x0
v4l2-ctl-2380 [005] .... 59.441290: csi_s_power: enable : 0x0
kworker/2:9-143 [002] .... 59.457361: rtcpu_vinotify_error: tstamp:2583731478 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:59 vi_tstamp:82679274016 data:0x0000000000000249
kworker/2:9-143 [002] .... 59.457364: rtcpu_vinotify_event: tstamp:2583891880 cch:0 vi:1 tag:FE channel:0x00 frame:58 vi_tstamp:82678399072 data:0x0000003a00000022
kworker/2:9-143 [002] .... 59.457365: rtcpu_vinotify_event: tstamp:2583892173 cch:0 vi:1 tag:FS channel:0x00 frame:59 vi_tstamp:82679252736 data:0x0000003b00000012
kworker/2:9-143 [002] .... 59.457366: rtcpu_vinotify_event: tstamp:2583892414 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0x04 frame:59 vi_tstamp:82679274016 data:0x0000000000000249
kworker/2:9-143 [002] .... 59.457368: rtcpu_nvcsi_intr: tstamp:2584418921 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x00000001
kworker/2:9-143 [002] .... 59.457369: rtcpu_nvcsi_intr: tstamp:2584418921 class:GLOBAL type:PHY_INTR1 phy:1 cil:0 st:0 vc:0 status:0x00000125
kworker/2:9-143 [002] .... 59.457369: rtcpu_nvcsi_intr: tstamp:2584418921 class:GLOBAL type:PHY_INTR1 phy:1 cil:1 st:0 vc:0 status:0x00000125
kworker/2:9-143 [002] .... 59.457370: rtcpu_vinotify_event: tstamp:2584434699 cch:0 vi:1 tag:FE channel:0x00 frame:59 vi_tstamp:82701398016 data:0x0000003b00000022
kworker/2:9-143 [002] .... 65.341376: rtcpu_string: tstamp:2768585432 id:0x04010000 str:"VM0 deactivating."
Any idea about the errors?
Regards
imx678.txt (7.1 KB)
