Hello
I have wrote a IMX678 driver,and testing capture image using GST or V4L2.
the driver I2C communicated successful with IMX678 Sensor,but my jetson nx board cannot get the image.
here is some information for debugging.
cmd:
echo 1 > /sys/kernel/debug/tracing/tracing_on
echo 30720 > /sys/kernel/debug/tracing/buffer_size_kb
echo 1 > /sys/kernel/debug/tracing/events/tegra_rtcpu/enable
echo 1 > /sys/kernel/debug/tracing/events/freertos/enable
echo 2 > /sys/kernel/debug/camrtc/log-level
echo 1 > /sys/kernel/debug/tracing/events/camera_common/enable
echo 1 > /sys/kernel/debug/bpmp/debug/clk/vi/mrq_rate_locked
echo 1 > /sys/kernel/debug/bpmp/debug/clk/isp/mrq_rate_locked
echo 1 > /sys/kernel/debug/bpmp/debug/clk/nvcsi/mrq_rate_locked
cat /sys/kernel/debug/bpmp/debug/clk/vi/max_rate |tee /sys/kernel/debug/bpmp/debug/clk/vi/rate
cat /sys/kernel/debug/bpmp/debug/clk/isp/max_rate | tee /sys/kernel/debug/bpmp/debug/clk/isp/rate
cat /sys/kernel/debug/bpmp/debug/clk/nvcsi/max_rate | tee /sys/kernel/debug/bpmp/debug/clk/nvcsi/rate
echo 998400000 > /sys/kernel/debug/bpmp/debug/clk/vi/rate
echo 1190400000 > /sys/kernel/debug/bpmp/debug/clk/isp/rate
echo 400000000 > /sys/kernel/debug/bpmp/debug/clk/nvcsi/rate
cat /sys/kernel/debug/tracing/trace
# tracer: nop
# entries-in-buffer/entries-written: 530/530 #P:6
# _-----=> irqs-off
# / _----=> need-resched
# | / _---=> hardirq/softirq
# || / _--=> preempt-depth
# ||| / delay
# TASK-PID CPU# |||| TIMESTAMP FUNCTION
kworker/2:1-8470 [002] .... 982.468213: rtos_queue_peek_from_isr_failed: tstamp:30985178796 queue:0x0bcbcf78
kworker/2:1-8470 [002] .... 982.468219: rtcpu_start: tstamp:30985180185
kworker/2:1-8470 [002] .... 982.468221: rtos_queue_send_from_isr_failed: tstamp:30985195818 queue:0x0bcb41f8
kworker/2:1-8470 [002] .... 982.468222: rtos_queue_send_from_isr_failed: tstamp:30985195968 queue:0x0bcb8a60
kworker/2:1-8470 [002] .... 982.468223: rtos_queue_send_from_isr_failed: tstamp:30985196117 queue:0x0bcba5e0
kworker/2:1-8470 [002] .... 982.468224: rtos_queue_send_from_isr_failed: tstamp:30985196264 queue:0x0bcbb3a0
kworker/2:1-8470 [002] .... 982.468225: rtos_queue_send_from_isr_failed: tstamp:30985196409 queue:0x0bcbc160
kworker/2:1-8470 [002] .... 982.468227: rtcpu_dbg_set_loglevel: tstamp:30985197629 old:0 new:2
kworker/2:1-8470 [002] .... 982.468228: rtos_queue_send_from_isr_failed: tstamp:30985199817 queue:0x0bcb41f8
kworker/2:1-8470 [002] .... 982.468229: rtos_queue_send_from_isr_failed: tstamp:30985199965 queue:0x0bcb8a60
kworker/2:1-8470 [002] .... 982.468230: rtos_queue_send_from_isr_failed: tstamp:30985200119 queue:0x0bcba5e0
kworker/2:1-8470 [002] .... 982.468231: rtos_queue_send_from_isr_failed: tstamp:30985200265 queue:0x0bcbb3a0
kworker/2:1-8470 [002] .... 982.468232: rtos_queue_send_from_isr_failed: tstamp:30985200413 queue:0x0bcbc160
kworker/2:1-8470 [002] .... 982.636284: rtos_queue_peek_from_isr_failed: tstamp:30990179360 queue:0x0bcbcf78
kworker/2:1-8470 [002] .... 982.804200: rtos_queue_peek_from_isr_failed: tstamp:30995179356 queue:0x0bcbcf78
kworker/2:1-8470 [002] .... 983.140443: rtos_queue_peek_from_isr_failed: tstamp:31005179355 queue:0x0bcbcf78
kworker/2:1-8470 [002] .... 983.308217: rtos_queue_peek_from_isr_failed: tstamp:31010179362 queue:0x0bcbcf78
kworker/2:1-8470 [002] .... 983.420211: rtos_queue_peek_from_isr_failed: tstamp:31015179362 queue:0x0bcbcf78
kworker/2:1-8470 [002] .... 983.588242: rtos_queue_peek_from_isr_failed: tstamp:31020179368 queue:0x0bcbcf78
kworker/2:1-8470 [002] .... 983.756236: rtos_queue_peek_from_isr_failed: tstamp:31025179364 queue:0x0bcbcf78
kworker/2:1-8470 [002] .... 983.924256: rtos_queue_peek_from_isr_failed: tstamp:31030179364 queue:0x0bcbcf78
kworker/2:1-8470 [002] .... 984.092444: rtos_queue_peek_from_isr_failed: tstamp:31035179356 queue:0x0bcbcf78
kworker/2:1-8470 [002] .... 984.260221: rtos_queue_peek_from_isr_failed: tstamp:31040179356 queue:0x0bcbcf78
kworker/2:1-8470 [002] .... 984.428224: rtos_queue_peek_from_isr_failed: tstamp:31045179369 queue:0x0bcbcf78
kworker/2:1-8470 [002] .... 984.540187: rtos_queue_peek_from_isr_failed: tstamp:31050179364 queue:0x0bcbcf78
kworker/2:1-8470 [002] .... 984.708207: rtos_queue_peek_from_isr_failed: tstamp:31055179377 queue:0x0bcbcf78
kworker/2:1-8470 [002] .... 984.876238: rtos_queue_peek_from_isr_failed: tstamp:31060179359 queue:0x0bcbcf78
kworker/2:1-8470 [002] .... 985.044340: rtos_queue_peek_from_isr_failed: tstamp:31065179355 queue:0x0bcbcf78
kworker/2:1-8470 [002] .... 985.212373: rtos_queue_peek_from_isr_failed: tstamp:31070179359 queue:0x0bcbcf78
kworker/2:1-8470 [002] .... 985.380198: rtos_queue_peek_from_isr_failed: tstamp:31075179372 queue:0x0bcbcf78
kworker/2:1-8470 [002] .... 985.548199: rtos_queue_peek_from_isr_failed: tstamp:31080179362 queue:0x0bcbcf78
kworker/2:1-8470 [002] .... 985.660181: rtos_queue_peek_from_isr_failed: tstamp:31085179364 queue:0x0bcbcf78
kworker/2:1-8470 [002] .... 985.828197: rtos_queue_peek_from_isr_failed: tstamp:31090179355 queue:0x0bcbcf78
kworker/2:1-8470 [002] .... 985.996188: rtos_queue_peek_from_isr_failed: tstamp:31095179355 queue:0x0bcbcf78
kworker/2:1-8470 [002] .... 986.164477: rtos_queue_peek_from_isr_failed: tstamp:31100179356 queue:0x0bcbcf78
kworker/2:1-8470 [002] .... 986.332252: rtos_queue_peek_from_isr_failed: tstamp:31105179353 queue:0x0bcbcf78
kworker/2:1-8470 [002] .... 986.500202: rtos_queue_peek_from_isr_failed: tstamp:31110179362 queue:0x0bcbcf78
kworker/2:1-8470 [002] .... 986.668178: rtos_queue_peek_from_isr_failed: tstamp:31115179356 queue:0x0bcbcf78
kworker/2:1-8470 [002] .... 986.780229: rtos_queue_peek_from_isr_failed: tstamp:31120179360 queue:0x0bcbcf78
kworker/2:1-8470 [002] .... 986.948207: rtos_queue_peek_from_isr_failed: tstamp:31125179356 queue:0x0bcbcf78
kworker/2:1-8470 [002] .... 987.116229: rtos_queue_peek_from_isr_failed: tstamp:31130179354 queue:0x0bcbcf78
kworker/2:1-8470 [002] .... 987.284214: rtos_queue_peek_from_isr_failed: tstamp:31135179354 queue:0x0bcbcf78
kworker/2:1-8470 [002] .... 987.452271: rtos_queue_peek_from_isr_failed: tstamp:31140179358 queue:0x0bcbcf78
kworker/2:1-8470 [002] .... 987.620220: rtos_queue_peek_from_isr_failed: tstamp:31145179358 queue:0x0bcbcf78
kworker/2:1-8470 [002] .... 987.788215: rtos_queue_peek_from_isr_failed: tstamp:31150179355 queue:0x0bcbcf78
kworker/2:1-8470 [002] .... 987.900183: rtos_queue_peek_from_isr_failed: tstamp:31155179362 queue:0x0bcbcf78
kworker/2:1-8470 [002] .... 988.068373: rtos_queue_peek_from_isr_failed: tstamp:31160179351 queue:0x0bcbcf78
kworker/2:1-8470 [002] .... 988.236338: rtos_queue_peek_from_isr_failed: tstamp:31165179355 queue:0x0bcbcf78
kworker/2:1-8470 [002] .... 988.292222: rtos_queue_peek_from_isr_failed: tstamp:31166165404 queue:0x0bcbcf78
gst-plugin-scan-8790 [003] .... 996.439967: tegra_channel_open: vi-output, imx678 9-001a
gst-plugin-scan-8790 [003] .... 996.442472: tegra_channel_set_power: imx678 9-001a : 0x1
gst-plugin-scan-8790 [003] .... 996.442481: camera_common_s_power: status : 0x1
gst-plugin-scan-8790 [003] .... 996.442560: tegra_channel_set_power: 15a00000.nvcsi--2 : 0x1
gst-plugin-scan-8790 [003] .... 996.442563: csi_s_power: enable : 0x1
gst-plugin-scan-8790 [003] .... 996.444606: tegra_channel_close: vi-output, imx678 9-001a
gst-plugin-scan-8790 [003] .... 996.444611: tegra_channel_set_power: imx678 9-001a : 0x0
gst-plugin-scan-8790 [003] .... 996.444615: camera_common_s_power: status : 0x0
gst-plugin-scan-8790 [003] .... 996.444680: tegra_channel_set_power: 15a00000.nvcsi--2 : 0x0
gst-plugin-scan-8790 [003] .... 996.444682: csi_s_power: enable : 0x0
gst-plugin-scan-8790 [000] .... 996.445670: tegra_channel_open: vi-output, imx678 10-001a
gst-plugin-scan-8790 [000] .... 996.445686: tegra_channel_set_power: imx678 10-001a : 0x1
gst-plugin-scan-8790 [000] .... 996.445695: camera_common_s_power: status : 0x1
gst-plugin-scan-8790 [000] .... 996.445772: tegra_channel_set_power: 15a00000.nvcsi--1 : 0x1
gst-plugin-scan-8790 [000] .... 996.445774: csi_s_power: enable : 0x1
gst-plugin-scan-8790 [000] .... 996.445840: tegra_channel_close: vi-output, imx678 10-001a
gst-plugin-scan-8790 [000] .... 996.445844: tegra_channel_set_power: imx678 10-001a : 0x0
gst-plugin-scan-8790 [000] .... 996.445873: camera_common_s_power: status : 0x0
gst-plugin-scan-8790 [000] .... 996.445925: tegra_channel_set_power: 15a00000.nvcsi--1 : 0x0
gst-plugin-scan-8790 [000] .... 996.445926: csi_s_power: enable : 0x0
kworker/2:1-8470 [002] .... 996.808234: rtos_queue_peek_from_isr_failed: tstamp:31432038601 queue:0x0bcbcf78
kworker/2:1-8470 [002] .... 996.808241: rtcpu_start: tstamp:31432040570
kworker/2:1-8470 [002] .... 996.808243: rtos_queue_send_from_isr_failed: tstamp:31432060653 queue:0x0bcb41f8
kworker/2:1-8470 [002] .... 996.808244: rtos_queue_send_from_isr_failed: tstamp:31432060805 queue:0x0bcb8a60
kworker/2:1-8470 [002] .... 996.808245: rtos_queue_send_from_isr_failed: tstamp:31432060954 queue:0x0bcba5e0
kworker/2:1-8470 [002] .... 996.808246: rtos_queue_send_from_isr_failed: tstamp:31432061099 queue:0x0bcbb3a0
kworker/2:1-8470 [002] .... 996.808247: rtos_queue_send_from_isr_failed: tstamp:31432061247 queue:0x0bcbc160
kworker/2:1-8470 [002] .... 996.808249: rtcpu_string: tstamp:31432061711 id:0x04010000 str:"Configuring ISP GoS.
kworker/2:1-8470 [002] .... 996.808281: rtcpu_string: tstamp:31432061893 id:0x04010000 str:" VM GOS[#0] addr=0xc2100000
kworker/2:1-8470 [002] .... 996.808292: rtcpu_string: tstamp:31432062150 id:0x04010000 str:" VM GOS[#1] addr=0xc2101000
kworker/2:1-8470 [002] .... 996.808340: rtcpu_string: tstamp:31432062424 id:0x04010000 str:" VM GOS[#2] addr=0xc2102000
kworker/2:1-8470 [002] .... 996.808347: rtcpu_string: tstamp:31432062659 id:0x04010000 str:" VM GOS[#3] addr=0xc2103000
kworker/2:1-8470 [002] .... 996.808354: rtcpu_string: tstamp:31432062894 id:0x04010000 str:" VM GOS[#4] addr=0xc2104000
kworker/2:1-8470 [002] .... 996.808360: rtcpu_string: tstamp:31432063129 id:0x04010000 str:" VM GOS[#5] addr=0xc2105000
kworker/2:1-8470 [002] .... 996.808367: rtcpu_string: tstamp:31432076120 id:0x04010000 str:"WARNING: t194/isp5.c:901 [config_channel] ""
kworker/2:1-8470 [002] .... 996.808369: rtcpu_string: tstamp:31432076497 id:0x04010000 str:"All error notifications not enabled: correctable"
kworker/2:1-8470 [002] .... 996.808370: rtcpu_string: tstamp:31432076615 id:0x04010000 str:"=0x00 uncorrectable=0x00"
kworker/2:1-8470 [002] .... 996.808403: rtcpu_string: tstamp:31432076810 id:0x04010000 str:""
kworker/2:1-8470 [002] .... 996.920247: rtos_queue_peek_from_isr_failed: tstamp:31437038967 queue:0x0bcbcf78
nvargus-daemon-8800 [002] .... 996.981621: tegra_channel_open: vi-output, imx678 9-001a
nvargus-daemon-8800 [002] .... 996.981635: tegra_channel_set_power: imx678 9-001a : 0x1
nvargus-daemon-8800 [002] .... 996.981643: camera_common_s_power: status : 0x1
nvargus-daemon-8800 [002] .... 996.981757: tegra_channel_set_power: 15a00000.nvcsi--2 : 0x1
nvargus-daemon-8800 [002] .... 996.981760: csi_s_power: enable : 0x1
nvargus-daemon-8800 [002] .... 996.981881: tegra_channel_close: vi-output, imx678 9-001a
nvargus-daemon-8800 [002] .... 996.981885: tegra_channel_set_power: imx678 9-001a : 0x0
nvargus-daemon-8800 [002] .... 996.981889: camera_common_s_power: status : 0x0
nvargus-daemon-8800 [002] .... 996.981962: tegra_channel_set_power: 15a00000.nvcsi--2 : 0x0
nvargus-daemon-8800 [002] .... 996.981963: csi_s_power: enable : 0x0
nvargus-daemon-8800 [002] .... 996.984414: tegra_channel_open: vi-output, imx678 10-001a
nvargus-daemon-8800 [002] .... 996.984420: tegra_channel_set_power: imx678 10-001a : 0x1
nvargus-daemon-8800 [002] .... 996.984424: camera_common_s_power: status : 0x1
nvargus-daemon-8800 [002] .... 996.984484: tegra_channel_set_power: 15a00000.nvcsi--1 : 0x1
nvargus-daemon-8800 [002] .... 996.984485: csi_s_power: enable : 0x1
nvargus-daemon-8800 [002] .... 996.984563: tegra_channel_close: vi-output, imx678 10-001a
nvargus-daemon-8800 [002] .... 996.984566: tegra_channel_set_power: imx678 10-001a : 0x0
nvargus-daemon-8800 [002] .... 996.984569: camera_common_s_power: status : 0x0
nvargus-daemon-8800 [002] .... 996.984625: tegra_channel_set_power: 15a00000.nvcsi--1 : 0x0
nvargus-daemon-8800 [002] .... 996.984626: csi_s_power: enable : 0x0
nvargus-daemon-8800 [002] .... 996.989167: tegra_channel_open: vi-output, imx678 9-001a
nvargus-daemon-8800 [002] .... 996.989174: tegra_channel_set_power: imx678 9-001a : 0x1
nvargus-daemon-8800 [002] .... 996.989183: camera_common_s_power: status : 0x1
nvargus-daemon-8800 [002] .... 996.989300: tegra_channel_set_power: 15a00000.nvcsi--2 : 0x1
nvargus-daemon-8800 [002] .... 996.989303: csi_s_power: enable : 0x1
nvargus-daemon-8800 [002] .... 996.989479: tegra_channel_close: vi-output, imx678 9-001a
nvargus-daemon-8800 [002] .... 996.989485: tegra_channel_set_power: imx678 9-001a : 0x0
nvargus-daemon-8800 [002] .... 996.989488: camera_common_s_power: status : 0x0
nvargus-daemon-8800 [002] .... 996.989569: tegra_channel_set_power: 15a00000.nvcsi--2 : 0x0
nvargus-daemon-8800 [002] .... 996.989571: csi_s_power: enable : 0x0
nvargus-daemon-8800 [002] .... 996.997479: tegra_channel_open: vi-output, imx678 10-001a
nvargus-daemon-8800 [002] .... 996.997486: tegra_channel_set_power: imx678 10-001a : 0x1
nvargus-daemon-8800 [002] .... 996.997492: camera_common_s_power: status : 0x1
nvargus-daemon-8800 [002] .... 996.997578: tegra_channel_set_power: 15a00000.nvcsi--1 : 0x1
nvargus-daemon-8800 [002] .... 996.997580: csi_s_power: enable : 0x1
nvargus-daemon-8800 [002] .... 996.997674: tegra_channel_close: vi-output, imx678 10-001a
nvargus-daemon-8800 [002] .... 996.997677: tegra_channel_set_power: imx678 10-001a : 0x0
nvargus-daemon-8800 [002] .... 996.997681: camera_common_s_power: status : 0x0
nvargus-daemon-8800 [002] .... 996.997747: tegra_channel_set_power: 15a00000.nvcsi--1 : 0x0
nvargus-daemon-8800 [002] .... 996.997749: csi_s_power: enable : 0x0
nvargus-daemon-8800 [002] .... 997.030826: tegra_channel_open: vi-output, imx678 10-001a
nvargus-daemon-8800 [002] .... 997.030838: tegra_channel_set_power: imx678 10-001a : 0x1
nvargus-daemon-8800 [002] .... 997.030846: camera_common_s_power: status : 0x1
nvargus-daemon-8800 [002] .... 997.030969: tegra_channel_set_power: 15a00000.nvcsi--1 : 0x1
nvargus-daemon-8800 [002] .... 997.030971: csi_s_power: enable : 0x1
nvargus-daemon-8800 [002] .... 997.030999: tegra_channel_close: vi-output, imx678 10-001a
nvargus-daemon-8800 [002] .... 997.031002: tegra_channel_set_power: imx678 10-001a : 0x0
nvargus-daemon-8800 [002] .... 997.031005: camera_common_s_power: status : 0x0
nvargus-daemon-8800 [002] .... 997.031061: tegra_channel_set_power: 15a00000.nvcsi--1 : 0x0
nvargus-daemon-8800 [002] .... 997.031062: csi_s_power: enable : 0x0
nvargus-daemon-8800 [002] .... 997.034110: tegra_channel_open: vi-output, imx678 9-001a
nvargus-daemon-8800 [002] .... 997.034119: tegra_channel_set_power: imx678 9-001a : 0x1
nvargus-daemon-8800 [002] .... 997.034126: camera_common_s_power: status : 0x1
nvargus-daemon-8800 [005] .... 997.034895: tegra_channel_set_power: 15a00000.nvcsi--2 : 0x1
nvargus-daemon-8800 [005] .... 997.034901: csi_s_power: enable : 0x1
nvargus-daemon-8800 [005] .... 997.034944: tegra_channel_close: vi-output, imx678 9-001a
nvargus-daemon-8800 [005] .... 997.034949: tegra_channel_set_power: imx678 9-001a : 0x0
nvargus-daemon-8800 [005] .... 997.034956: camera_common_s_power: status : 0x0
nvargus-daemon-8800 [005] .... 997.035033: tegra_channel_set_power: 15a00000.nvcsi--2 : 0x0
nvargus-daemon-8800 [005] .... 997.035071: csi_s_power: enable : 0x0
nvargus-daemon-8800 [000] .... 997.036274: tegra_channel_open: vi-output, imx678 9-001a
nvargus-daemon-8800 [000] .... 997.036289: tegra_channel_set_power: imx678 9-001a : 0x1
nvargus-daemon-8800 [000] .... 997.036298: camera_common_s_power: status : 0x1
nvargus-daemon-8800 [000] .... 997.036376: tegra_channel_set_power: 15a00000.nvcsi--2 : 0x1
nvargus-daemon-8800 [000] .... 997.036380: csi_s_power: enable : 0x1
nvargus-daemon-8800 [000] .... 997.036552: tegra_channel_close: vi-output, imx678 9-001a
nvargus-daemon-8800 [000] .... 997.036556: tegra_channel_set_power: imx678 9-001a : 0x0
nvargus-daemon-8800 [000] .... 997.036560: camera_common_s_power: status : 0x0
nvargus-daemon-8800 [000] .... 997.036622: tegra_channel_set_power: 15a00000.nvcsi--2 : 0x0
nvargus-daemon-8800 [000] .... 997.036623: csi_s_power: enable : 0x0
nvargus-daemon-8800 [002] .... 997.038697: tegra_channel_open: vi-output, imx678 9-001a
nvargus-daemon-8800 [002] .... 997.038711: tegra_channel_set_power: imx678 9-001a : 0x1
nvargus-daemon-8800 [002] .... 997.038719: camera_common_s_power: status : 0x1
nvargus-daemon-8800 [002] .... 997.038803: tegra_channel_set_power: 15a00000.nvcsi--2 : 0x1
nvargus-daemon-8800 [002] .... 997.038806: csi_s_power: enable : 0x1
nvargus-daemon-8800 [002] .... 997.038899: tegra_channel_close: vi-output, imx678 9-001a
nvargus-daemon-8800 [002] .... 997.038903: tegra_channel_set_power: imx678 9-001a : 0x0
nvargus-daemon-8800 [002] .... 997.038906: camera_common_s_power: status : 0x0
nvargus-daemon-8800 [002] .... 997.038970: tegra_channel_set_power: 15a00000.nvcsi--2 : 0x0
nvargus-daemon-8800 [002] .... 997.038972: csi_s_power: enable : 0x0
nvargus-daemon-8800 [001] .... 997.085348: tegra_channel_open: vi-output, imx678 10-001a
nvargus-daemon-8800 [001] .... 997.085365: tegra_channel_set_power: imx678 10-001a : 0x1
nvargus-daemon-8800 [001] .... 997.085375: camera_common_s_power: status : 0x1
nvargus-daemon-8800 [001] .... 997.085467: tegra_channel_set_power: 15a00000.nvcsi--1 : 0x1
nvargus-daemon-8800 [001] .... 997.085470: csi_s_power: enable : 0x1
nvargus-daemon-8800 [001] .... 997.085499: tegra_channel_close: vi-output, imx678 10-001a
nvargus-daemon-8800 [001] .... 997.085503: tegra_channel_set_power: imx678 10-001a : 0x0
nvargus-daemon-8800 [001] .... 997.085506: camera_common_s_power: status : 0x0
nvargus-daemon-8800 [001] .... 997.085562: tegra_channel_set_power: 15a00000.nvcsi--1 : 0x0
nvargus-daemon-8800 [001] .... 997.085563: csi_s_power: enable : 0x0
nvargus-daemon-8800 [001] .... 997.086527: tegra_channel_open: vi-output, imx678 10-001a
nvargus-daemon-8800 [001] .... 997.086533: tegra_channel_set_power: imx678 10-001a : 0x1
nvargus-daemon-8800 [001] .... 997.086538: camera_common_s_power: status : 0x1
nvargus-daemon-8800 [001] .... 997.086595: tegra_channel_set_power: 15a00000.nvcsi--1 : 0x1
nvargus-daemon-8800 [001] .... 997.086597: csi_s_power: enable : 0x1
nvargus-daemon-8800 [001] .... 997.086684: tegra_channel_close: vi-output, imx678 10-001a
nvargus-daemon-8800 [001] .... 997.086687: tegra_channel_set_power: imx678 10-001a : 0x0
nvargus-daemon-8800 [001] .... 997.086689: camera_common_s_power: status : 0x0
nvargus-daemon-8800 [001] .... 997.086744: tegra_channel_set_power: 15a00000.nvcsi--1 : 0x0
nvargus-daemon-8800 [001] .... 997.086746: csi_s_power: enable : 0x0
nvargus-daemon-8800 [001] .... 997.087732: tegra_channel_open: vi-output, imx678 10-001a
nvargus-daemon-8800 [001] .... 997.087738: tegra_channel_set_power: imx678 10-001a : 0x1
nvargus-daemon-8800 [001] .... 997.087742: camera_common_s_power: status : 0x1
nvargus-daemon-8800 [001] .... 997.087800: tegra_channel_set_power: 15a00000.nvcsi--1 : 0x1
nvargus-daemon-8800 [001] .... 997.087801: csi_s_power: enable : 0x1
nvargus-daemon-8800 [001] .... 997.087861: tegra_channel_close: vi-output, imx678 10-001a
nvargus-daemon-8800 [001] .... 997.087889: tegra_channel_set_power: imx678 10-001a : 0x0
nvargus-daemon-8800 [001] .... 997.087891: camera_common_s_power: status : 0x0
nvargus-daemon-8800 [001] .... 997.087945: tegra_channel_set_power: 15a00000.nvcsi--1 : 0x0
nvargus-daemon-8800 [001] .... 997.087947: csi_s_power: enable : 0x0
kworker/2:1-8470 [002] .... 997.088259: rtos_queue_peek_from_isr_failed: tstamp:31442038958 queue:0x0bcbcf78
kworker/2:1-8470 [002] .... 997.144260: rtos_queue_send_from_isr_failed: tstamp:31443649255 queue:0x0bcb41f8
kworker/2:1-8470 [002] .... 997.144265: rtos_queue_send_from_isr_failed: tstamp:31443649411 queue:0x0bcb8a60
kworker/2:1-8470 [002] .... 997.144267: rtos_queue_send_from_isr_failed: tstamp:31443649564 queue:0x0bcba5e0
kworker/2:1-8470 [002] .... 997.144268: rtos_queue_send_from_isr_failed: tstamp:31443649710 queue:0x0bcbb3a0
kworker/2:1-8470 [002] .... 997.144269: rtos_queue_send_from_isr_failed: tstamp:31443649858 queue:0x0bcbc160
kworker/2:1-8470 [002] .... 997.144271: rtcpu_string: tstamp:31443650297 id:0x04010000 str:"Configuring VI GoS.
kworker/2:1-8470 [002] .... 997.144307: rtcpu_string: tstamp:31443650474 id:0x04010000 str:"VM GOS[#0] addr=0xc2100000
kworker/2:1-8470 [002] .... 997.144319: rtcpu_string: tstamp:31443650727 id:0x04010000 str:"VM GOS[#1] addr=0xc2101000
kworker/2:1-8470 [002] .... 997.144331: rtcpu_string: tstamp:31443650990 id:0x04010000 str:"VM GOS[#2] addr=0xc2102000
kworker/2:1-8470 [002] .... 997.144342: rtcpu_string: tstamp:31443651222 id:0x04010000 str:"VM GOS[#3] addr=0xc2103000
kworker/2:1-8470 [002] .... 997.144353: rtcpu_string: tstamp:31443651454 id:0x04010000 str:"VM GOS[#4] addr=0xc2104000
kworker/2:1-8470 [002] .... 997.144364: rtcpu_string: tstamp:31443651688 id:0x04010000 str:"VM GOS[#5] addr=0xc2105000
kworker/2:1-8470 [002] .... 997.144374: rtcpu_string: tstamp:31443660400 id:0x04010000 str:"vi5_hwinit: firmware CL2018101701 protocol versi"
kworker/2:1-8470 [002] .... 997.144376: rtcpu_string: tstamp:31443660520 id:0x04010000 str:"on 2.2
kworker/2:1-8470 [002] .... 997.144386: rtos_queue_send_from_isr_failed: tstamp:31443671597 queue:0x0bcb41f8
kworker/2:1-8470 [002] .... 997.144387: rtos_queue_send_from_isr_failed: tstamp:31443671750 queue:0x0bcb8a60
kworker/2:1-8470 [002] .... 997.144388: rtos_queue_send_from_isr_failed: tstamp:31443671906 queue:0x0bcba5e0
kworker/2:1-8470 [002] .... 997.144389: rtos_queue_send_from_isr_failed: tstamp:31443672052 queue:0x0bcbb3a0
kworker/2:1-8470 [002] .... 997.144390: rtos_queue_send_from_isr_failed: tstamp:31443672197 queue:0x0bcbc160
kworker/2:1-8470 [002] .... 997.144398: rtcpu_nvcsi_intr: tstamp:31443674591 class:GLOBAL type:PHY_INTR0 phy:1 cil:0 st:0 vc:0 status:0x00000089
kworker/2:1-8470 [002] .... 997.144400: rtcpu_nvcsi_intr: tstamp:31443674591 class:GLOBAL type:PHY_INTR0 phy:1 cil:1 st:0 vc:0 status:0x00000088
kworker/2:1-8470 [002] .... 997.260234: rtos_queue_peek_from_isr_failed: tstamp:31447038962 queue:0x0bcbcf78
kworker/2:1-8470 [002] .... 997.436240: rtos_queue_peek_from_isr_failed: tstamp:31452038961 queue:0x0bcbcf78
kworker/2:1-8470 [002] .... 997.436247: rtos_queue_send_from_isr_failed: tstamp:31452334927 queue:0x0bcb41f8
kworker/2:1-8470 [002] .... 997.436248: rtos_queue_send_from_isr_failed: tstamp:31452335076 queue:0x0bcb8a60
kworker/2:1-8470 [002] .... 997.436249: rtos_queue_send_from_isr_failed: tstamp:31452335227 queue:0x0bcba5e0
kworker/2:1-8470 [002] .... 997.436250: rtos_queue_send_from_isr_failed: tstamp:31452335377 queue:0x0bcbb3a0
kworker/2:1-8470 [002] .... 997.436251: rtos_queue_send_from_isr_failed: tstamp:31452335523 queue:0x0bcbc160
kworker/2:1-8470 [002] .... 997.436252: rtos_queue_send_from_isr_failed: tstamp:31452335730 queue:0x0bcb4190
kworker/2:1-8470 [002] .... 997.436253: rtos_queue_send_from_isr_failed: tstamp:31452335867 queue:0x0bcb41f8
kworker/2:1-8470 [002] .... 997.436254: rtos_queue_send_from_isr_failed: tstamp:31452336002 queue:0x0bcb89f8
kworker/2:1-8470 [002] .... 997.436255: rtos_queue_send_from_isr_failed: tstamp:31452336137 queue:0x0bcb8a60
kworker/2:1-8470 [002] .... 997.436256: rtos_queue_send_from_isr_failed: tstamp:31452336274 queue:0x0bcba578
kworker/2:1-8470 [002] .... 997.436257: rtos_queue_send_from_isr_failed: tstamp:31452336408 queue:0x0bcba5e0
kworker/2:1-8470 [002] .... 997.436258: rtos_queue_send_from_isr_failed: tstamp:31452336544 queue:0x0bcbb338
kworker/2:1-8470 [002] .... 997.436259: rtos_queue_send_from_isr_failed: tstamp:31452336676 queue:0x0bcbb3a0
kworker/2:1-8470 [002] .... 997.436260: rtos_queue_send_from_isr_failed: tstamp:31452336814 queue:0x0bcbc0f8
kworker/2:1-8470 [002] .... 997.436261: rtos_queue_send_from_isr_failed: tstamp:31452336947 queue:0x0bcbc160
kworker/2:1-8470 [002] .... 997.436262: rtos_queue_send_from_isr_failed: tstamp:31452351890 queue:0x0bcb41f8
kworker/2:1-8470 [002] .... 997.436263: rtos_queue_send_from_isr_failed: tstamp:31452352042 queue:0x0bcb8a60
kworker/2:1-8470 [002] .... 997.436264: rtos_queue_send_from_isr_failed: tstamp:31452352194 queue:0x0bcba5e0
kworker/2:1-8470 [002] .... 997.436265: rtos_queue_send_from_isr_failed: tstamp:31452352341 queue:0x0bcbb3a0
kworker/2:1-8470 [002] .... 997.436266: rtos_queue_send_from_isr_failed: tstamp:31452352487 queue:0x0bcbc160
kworker/2:1-8470 [002] .... 997.436266: rtos_queue_send_from_isr_failed: tstamp:31452355976 queue:0x0bcb41f8
kworker/2:1-8470 [002] .... 997.436267: rtos_queue_send_from_isr_failed: tstamp:31452356121 queue:0x0bcb8a60
kworker/2:1-8470 [002] .... 997.436268: rtos_queue_send_from_isr_failed: tstamp:31452356270 queue:0x0bcba5e0
kworker/2:1-8470 [002] .... 997.436269: rtos_queue_send_from_isr_failed: tstamp:31452356418 queue:0x0bcbb3a0
kworker/2:1-8470 [002] .... 997.436270: rtos_queue_send_from_isr_failed: tstamp:31452356563 queue:0x0bcbc160
kworker/2:1-8470 [002] .... 997.548325: rtos_queue_send_from_isr_failed: tstamp:31455419980 queue:0x0bcb41f8
kworker/2:1-8470 [002] .... 997.548347: rtos_queue_send_from_isr_failed: tstamp:31455420131 queue:0x0bcb8a60
kworker/2:1-8470 [002] .... 997.548349: rtos_queue_send_from_isr_failed: tstamp:31455420282 queue:0x0bcba5e0
kworker/2:1-8470 [002] .... 997.548350: rtos_queue_send_from_isr_failed: tstamp:31455420429 queue:0x0bcbb3a0
kworker/2:1-8470 [002] .... 997.548351: rtos_queue_send_from_isr_failed: tstamp:31455420578 queue:0x0bcbc160
kworker/2:1-8470 [002] .... 997.548352: rtos_queue_send_from_isr_failed: tstamp:31455420779 queue:0x0bcb4190
kworker/2:1-8470 [002] .... 997.548353: rtos_queue_send_from_isr_failed: tstamp:31455420915 queue:0x0bcb41f8
kworker/2:1-8470 [002] .... 997.548354: rtos_queue_send_from_isr_failed: tstamp:31455421051 queue:0x0bcb89f8
kworker/2:1-8470 [002] .... 997.548355: rtos_queue_send_from_isr_failed: tstamp:31455421187 queue:0x0bcb8a60
kworker/2:1-8470 [002] .... 997.548357: rtos_queue_send_from_isr_failed: tstamp:31455421326 queue:0x0bcba578
kworker/2:1-8470 [002] .... 997.548358: rtos_queue_send_from_isr_failed: tstamp:31455421458 queue:0x0bcba5e0
kworker/2:1-8470 [002] .... 997.548359: rtos_queue_send_from_isr_failed: tstamp:31455421597 queue:0x0bcbb338
kworker/2:1-8470 [002] .... 997.548360: rtos_queue_send_from_isr_failed: tstamp:31455421729 queue:0x0bcbb3a0
kworker/2:1-8470 [002] .... 997.548361: rtos_queue_send_from_isr_failed: tstamp:31455421864 queue:0x0bcbc0f8
kworker/2:1-8470 [002] .... 997.548362: rtos_queue_send_from_isr_failed: tstamp:31455421998 queue:0x0bcbc160
kworker/2:1-8470 [002] .... 997.548363: rtos_queue_send_from_isr_failed: tstamp:31455446643 queue:0x0bcb41f8
kworker/2:1-8470 [002] .... 997.548365: rtos_queue_send_from_isr_failed: tstamp:31455446794 queue:0x0bcb8a60
kworker/2:1-8470 [002] .... 997.548366: rtos_queue_send_from_isr_failed: tstamp:31455446946 queue:0x0bcba5e0
kworker/2:1-8470 [002] .... 997.548444: rtos_queue_send_from_isr_failed: tstamp:31455447091 queue:0x0bcbb3a0
kworker/2:1-8470 [002] .... 997.548445: rtos_queue_send_from_isr_failed: tstamp:31455447239 queue:0x0bcbc160
kworker/2:1-8470 [002] .... 997.604262: rtos_queue_peek_from_isr_failed: tstamp:31457039163 queue:0x0bcbcf78
kworker/2:1-8470 [002] .... 997.716274: rtos_queue_peek_from_isr_failed: tstamp:31462039145 queue:0x0bcbcf78
kworker/2:1-8470 [002] .... 997.884273: rtos_queue_peek_from_isr_failed: tstamp:31467039141 queue:0x0bcbcf78
kworker/2:1-8470 [002] .... 998.052332: rtos_queue_peek_from_isr_failed: tstamp:31472039139 queue:0x0bcbcf78
kworker/2:1-8470 [002] .... 998.220314: rtos_queue_peek_from_isr_failed: tstamp:31477039136 queue:0x0bcbcf78
kworker/2:1-8470 [002] .... 998.388292: rtos_queue_peek_from_isr_failed: tstamp:31482039141 queue:0x0bcbcf78
kworker/2:1-8470 [002] .... 998.556213: rtos_queue_peek_from_isr_failed: tstamp:31487039140 queue:0x0bcbcf78
kworker/2:1-8470 [002] .... 998.724237: rtos_queue_peek_from_isr_failed: tstamp:31492039140 queue:0x0bcbcf78
kworker/2:1-8470 [002] .... 998.836200: rtos_queue_peek_from_isr_failed: tstamp:31497039145 queue:0x0bcbcf78
kworker/2:1-8470 [002] .... 999.004191: rtos_queue_peek_from_isr_failed: tstamp:31502039140 queue:0x0bcbcf78
kworker/2:1-8470 [002] .... 999.172562: rtos_queue_peek_from_isr_failed: tstamp:31507038958 queue:0x0bcbcf78
kworker/2:1-8470 [002] .... 999.340200: rtos_queue_peek_from_isr_failed: tstamp:31512039143 queue:0x0bcbcf78
kworker/2:1-8470 [002] .... 999.508200: rtos_queue_peek_from_isr_failed: tstamp:31517039137 queue:0x0bcbcf78
kworker/2:1-8470 [002] .... 999.676179: rtos_queue_peek_from_isr_failed: tstamp:31522039140 queue:0x0bcbcf78
kworker/2:1-8470 [002] .... 999.844213: rtos_queue_peek_from_isr_failed: tstamp:31527039140 queue:0x0bcbcf78
kworker/2:1-8470 [002] .... 999.956200: rtos_queue_peek_from_isr_failed: tstamp:31532039143 queue:0x0bcbcf78
kworker/2:1-8470 [002] .... 1000.124304: rtos_queue_peek_from_isr_failed: tstamp:31537039159 queue:0x0bcbcf78
kworker/2:1-8470 [002] .... 1000.292226: rtos_queue_peek_from_isr_failed: tstamp:31542039137 queue:0x0bcbcf78
kworker/2:1-8470 [002] .... 1000.460266: rtos_queue_peek_from_isr_failed: tstamp:31547039141 queue:0x0bcbcf78
kworker/2:1-8470 [002] .... 1000.628202: rtos_queue_peek_from_isr_failed: tstamp:31552039145 queue:0x0bcbcf78
kworker/2:1-8470 [002] .... 1000.796201: rtos_queue_peek_from_isr_failed: tstamp:31557039143 queue:0x0bcbcf78
kworker/2:1-8470 [002] .... 1000.964215: rtos_queue_peek_from_isr_failed: tstamp:31562039141 queue:0x0bcbcf78
kworker/2:1-8470 [002] .... 1001.076362: rtos_queue_peek_from_isr_failed: tstamp:31567039136 queue:0x0bcbcf78
kworker/2:1-8470 [002] .... 1001.244281: rtos_queue_peek_from_isr_failed: tstamp:31572039149 queue:0x0bcbcf78
kworker/2:1-8470 [002] .... 1001.412229: rtos_queue_peek_from_isr_failed: tstamp:31577039145 queue:0x0bcbcf78
kworker/2:1-8470 [002] .... 1001.580191: rtos_queue_peek_from_isr_failed: tstamp:31582039145 queue:0x0bcbcf78
kworker/2:1-8470 [002] .... 1001.748247: rtos_queue_peek_from_isr_failed: tstamp:31587039140 queue:0x0bcbcf78
kworker/2:1-8470 [002] .... 1001.916208: rtos_queue_peek_from_isr_failed: tstamp:31592039146 queue:0x0bcbcf78
kworker/2:1-8470 [002] .... 1002.084419: rtos_queue_peek_from_isr_failed: tstamp:31597039145 queue:0x0bcbcf78
kworker/2:1-8470 [002] .... 1002.196425: rtos_queue_peek_from_isr_failed: tstamp:31602039137 queue:0x0bcbcf78
kworker/2:1-8470 [002] .... 1002.364220: rtos_queue_peek_from_isr_failed: tstamp:31607039144 queue:0x0bcbcf78
kworker/2:1-8470 [002] .... 1002.532207: rtos_queue_peek_from_isr_failed: tstamp:31612039145 queue:0x0bcbcf78
kworker/2:1-8470 [002] .... 1002.700239: rtos_queue_peek_from_isr_failed: tstamp:31617039143 queue:0x0bcbcf78
kworker/2:1-8470 [002] .... 1002.868263: rtos_queue_peek_from_isr_failed: tstamp:31622039145 queue:0x0bcbcf78
kworker/2:1-8470 [002] .... 1003.036420: rtos_queue_peek_from_isr_failed: tstamp:31627039143 queue:0x0bcbcf78
kworker/2:1-8470 [002] .... 1003.204363: rtos_queue_peek_from_isr_failed: tstamp:31632039140 queue:0x0bcbcf78
kworker/2:1-8470 [002] .... 1003.316218: rtos_queue_peek_from_isr_failed: tstamp:31637039145 queue:0x0bcbcf78
kworker/2:1-8470 [002] .... 1003.372233: rtos_queue_peek_from_isr_failed: tstamp:31638159306 queue:0x0bcbcf78
kworker/2:1-8470 [002] .... 1018.496408: rtos_queue_peek_from_isr_failed: tstamp:32110627782 queue:0x0bcbcf78
kworker/2:1-8470 [002] .... 1018.496438: rtcpu_start: tstamp:32110629474
kworker/2:1-8470 [002] .... 1018.496446: rtos_queue_send_from_isr_failed: tstamp:32110739685 queue:0x0bcb41f8
kworker/2:1-8470 [002] .... 1018.496447: rtos_queue_send_from_isr_failed: tstamp:32110740201 queue:0x0bcb8a60
kworker/2:1-8470 [002] .... 1018.496450: rtos_queue_send_from_isr_failed: tstamp:32110740714 queue:0x0bcba5e0
kworker/2:1-8470 [002] .... 1018.496531: rtos_queue_send_from_isr_failed: tstamp:32110741213 queue:0x0bcbb3a0
kworker/2:1-8470 [002] .... 1018.496532: rtos_queue_send_from_isr_failed: tstamp:32110741711 queue:0x0bcbc160
kworker/2:1-8470 [002] .... 1018.496538: rtcpu_string: tstamp:32110743197 id:0x04010000 str:"Configuring ISP GoS.
my dts config is
cam_i2cmux {
compatible = “i2c-mux-gpio”;
#address-cells = <0x1>;
#size-cells = <0x0>;
i2c-parent = <0xd3>;
mux-gpios = <0x25 0x13 0x0>;
i2c@0 {
reg = <0x0>;
linux,phandle = <0x174>;
phandle = <0x174>;
imx678_a@1a {
compatible = "sony,imx678";
mclk_khz = "37125";
reg = <0x1a>;
devnode = "video0";
physical_w = "3.674";
physical_h = "2.738";
sensor_model = "imx678";
dovdd-supply = <0x1f>;
iovdd-reg = "dovdd";
vana-supply = <0x1d>;
avdd-reg = "vana";
vdig-supply = <0x1e>;
dvdd-reg = "vdig";
delayed_gain = "true";
status = "okay";
fuse_id_start_addr = <0x5b>;
linux,phandle = <0x175>;
phandle = <0x175>;
mode0 {
mclk_khz = "37125";
num_lanes = [34 00];
phy_mode = "DPHY";
discontinuous_clk = "no";
dpcm_enable = "false";
cil_settletime = [30 00];
lane_polarity = [36 00];
active_w = "3856";
active_h = "2180";
mode_type = "bayer";
pixel_phase = "rggb";
csi_pixel_bit_depth = "10";
readout_orientation = [30 00];
line_length = "4056";
inherent_gain = [31 00];
pix_clk_hz = "297000000";
serdes_pix_clk_hz = "594000000";
gain_factor = "10";
framerate_factor = "1000000";
exposure_factor = "1000000";
min_gain_val = [30 00];
max_gain_val = "1560";
step_gain_val = [33 00];
default_gain = "16";
min_hdr_ratio = [31 00];
max_hdr_ratio = [31 00];
min_framerate = "2000000";
max_framerate = "25000000";
step_framerate = [31 00];
default_framerate = "25000000";
min_exp_time = "27";
max_exp_time = "660000";
step_exp_time = [31 00];
default_exp_time = "1600";
embedded_metadata_height = [31 00];
ports {
port@0 {
reg = <0x0>;
endpoint {
status = "okay";
port-index = <0x0>;
bus-width = <0x4>;
remote-endpoint = <0xd4>;
linux,phandle = <0x70>;
phandle = <0x70>;
i2c@1 {
reg = <0x1>;
linux,phandle = <0x176>;
phandle = <0x176>;
imx678_a@1a {
reg = <0x1a>;
devnode = "video1";
avdd-reg = "vana";
dvdd-reg = "vdig";
status = "okay";
linux,phandle = <0x177>;
phandle = <0x177>;
mode0 {
mclk_khz = "37125";
tegra_sinterface = "serial_c";
phy_mode = "DPHY";
lane_polarity = [30 00];
active_w = "3856";
active_h = "2176";
dynamic_pixel_bit_depth = "10";
line_length = "3856";
gain_factor = "10";
max_framerate = "30000000";
default_framerate = "30000000";
ports {
port@0 {
reg = <0x0>;
endpoint {
status = "okay";
port-index = <0x2>;
bus-width = <0x4>;
remote-endpoint = <0xd5>;
linux,phandle = <0x72>;
phandle = <0x72>;
device has connected only one camera sensor imx678.
I was found /dev/video0 and /dev/video1 after insmod imx678.ko
sudo media-ctl -p -d /dev/media0
Media controller API version 0.1.0
Media device information
driver tegra194-vi5
model NVIDIA Tegra Video Input Device
serial
bus info
hw revision 0x3
driver version 0.0.0
Device topology
entity 1: 15a00000.nvcsi–2 (2 pads, 2 links)
type V4L2 subdev subtype Unknown flags 0
device node name /dev/v4l-subdev0
pad0: Sink
← “imx678 9-001a”:0 [ENABLED]
pad1: Source
→ “vi-output, imx678 9-001a”:0 [ENABLED] -
entity 4: 15a00000.nvcsi–1 (2 pads, 2 links)
device node name /dev/v4l-subdev1
pad0: Sink
← “imx678 10-001a”:0 [ENABLED]
pad1: Source
→ “vi-output, imx678 10-001a”:0 [ENABLED] -
entity 35: imx678 9-001a (1 pad, 1 link)
type V4L2 subdev subtype Sensor flags 0
device node name /dev/v4l-subdev2
pad0: Source
[fmt:SRGGB10_1X10/3840x2160 field:none colorspace:srgb]
→ “15a00000.nvcsi–2”:0 [ENABLED] -
entity 37: vi-output, imx678 9-001a (1 pad, 1 link)
type Node subtype V4L flags 0
device node name /dev/video0
pad0: Sink
← “15a00000.nvcsi–2”:1 [ENABLED] -
entity 51: imx678 10-001a (1 pad, 1 link)
device node name /dev/v4l-subdev3
pad0: Source
→ “15a00000.nvcsi–1”:0 [ENABLED] -
entity 53: vi-output, imx678 10-001a (1 pad, 1 link)
device node name /dev/video1
pad0: Sink
← “15a00000.nvcsi–1”:1 [ENABLED]
cmd:
v4l2-ctl -d /dev/video0 --set-fmt-video=width=3840,height=2160,pixelformat=RG10 --set-ctrl bypass_mode=0 --stream-mmap --stream-count=100
uncorr_err: request timed out after 2500 ms
[ 1398.100545] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[ 1398.102905] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
[ 1400.660230] tegra194-vi5 15c10000.vi: no reply from camera processor
[ 1400.660427] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[ 1400.660575] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[ 1400.662806] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
[ 1403.220245] tegra194-vi5 15c10000.vi: no reply from camera processor
[ 1403.220441] tegra194-vi5 15c10000.vi: uncorr_err: request timed out after 2500 ms
[ 1403.220598] tegra194-vi5 15c10000.vi: err_rec: attempting to reset the capture channel
[ 1403.222888] tegra194-vi5 15c10000.vi: err_rec: successfully reset the capture channel
[ 1405.780218] tegra194-vi5 15c10000.vi: no reply from camera processor
