Imx219 120fps on jetson orin nano
Hello, I am working with a Jetson Orin Nano and recently found out that the IMX219 camera can run at 120 FPS. As I am new to the Jetson platform, I am having trouble figuring out how to enable this mode. I understand that 120 FPS support is not available out-of-the-box, and that on JetPack 4.4 it can be enabled through manual configuration. Could you please clarify if a similar approach is possible on JetPack 6? Or are there fundamental differences that make this unfeasible on the newer platform? If this is achievable on JP6, could you kindly share any guides, documentation links, or step-by-step instructions on how to configure the IMX219 for 120 FPS capture?
Suppose Orin Nano only have 2 lanes HW design to have bandwidth to support 120fps.
Thanks for the reply! Could you please share any instructions, guides, or materials that might help me achieve this?
You can download older driver copy the 120fps sensor mode for it.
Do you have a link to download this version? I can’t find it
The link from here.
I don’t recall which version have it.
Have reference to below link.
