I’m a student trying to set up my Jetson Orin (Jetpack 6.0) RC car with a CSI Raspberry Pi Camera V2; when I run “v4l2-ctl --list-devices” it detects a camera, but can’t run the video from /dev/video0
I checked /proc/config.gz and it shows “CONFIG_IMX219” as commented out–I read that this is a kernel file and modifying it requires the kernel to be rebuilt–is this correct?
How can I enable the config for the IMX219 camera so I can get video output on my orin?
The same camera was tested on a Jetson Nano dev kit and works as expected, so I don’t think the camera is the issue. The cable is brand new and is being detected, so I don’t think the cable is the issue. I confirmed that the cable is oriented correctly because switching the orientation causes the camera to not be detected on a reboot.
Hi arvind,
I experienced exactly the same problem. I simply reflashed my orin nano and it works smooth… Could you try gst-launch-1.0 nvarguscamerasrc sensor_id=0 ! nv3dsink
sensor id depends on the port you have connected your camera to.
I know why the camera wasn’t working in JP 6.0, it was because I was using the orin via VNC server. I suspect the camera would have worked fine if I tested it while connected to a monitor, keyboard, and mouse.
I know this is the case because I am on JP 5.1.2 (not a typo) and I tested the camera while connected to a display/kb/mouse and it worked as expected, but the same camera does not work when using VNC (headless with GUI passed over network to remote computer) in 5.1.2 also–is there a way to get the CSI camera working while using orin via VNC without a physical display connected to the orin?
I googled and shut down x server by running “sudo service gdm stop” then I ran “xinit&” then “export DISPLAY=:0” (I was connected via SSH when running these commands on the Orin Nano)
After running that I no longer have VNC server running though, and knowing it wouldn’t work I tried to run the camera test and it failed with the same error
Hi, in my above screenshot I SSH’d into the Orin Nano (the screenshots with the black background) and ran the same commands and it gave me the same error
That being said, it sounds the like Argus platform would need to have the camera streamed to have it be visible when using the VNC
