Connect the RPi Camera Module v2 to Jetson Orin Nano Developer Kit using csi camera connector, but camera isn’t detected. What issue can be in this case?
I try to configure csi connector throw the Jetson-io, but after this Jetson stop boot at all and have to make reflashing.
What’s the version? Did you try J5.1.3 latest release?
Does it on Jetson Orin Nano devkit?
Yes, it is
We tried with Jetpack 6
Here is our connected camera:
and when we check in terminal by command:
v4l2-ctl --list-devices
we get the response:
NVIDIA Tegra Video Input Device (platform:tegra-camrtc-ca):
/dev/media0
Cannot open device /dev/video0, exiting.
Below is the full information about jetpack that we use:
> Package: nvidia-jetpack
> Version: 6.0-b52
> Architecture: arm64
> Maintainer: NVIDIA Corporation
> Installed-Size: 194
> Depends: nvidia-jetpack-runtime (= 6.0-b52), nvidia-jetpack-dev (= 6.0-b52)
> Homepage: http://developer.nvidia.com/jetson
> Priority: standard
> Section: metapackages
> Filename: pool/main/n/nvidia-jetpack/nvidia-jetpack_6.0-b52_arm64.deb
> SHA256: 01f3cfaed6f45ebabacbe5f2d4c3b74a296200ae928d68b97956470d54c4be98
> SHA1: 950626b2b51381650e8ecb7e3b21f5e2e89cddb6
> MD5sum: 1e58b6faa4b7a9695a1f5b0cb6035d85
> Description: NVIDIA Jetpack Meta Package
> Description-md5: ad1462289bdbc54909ae109d1d32c0a8
And additionally loaded the system logs by command:
dmesg > klogs.txt
Here is the file:
klogs.txt (58.6 KB)
Hi leonidu,
Confirmed IMX219 is working on Orin-Nano + JP-6.0 DP.
Are you enable “Camera IMX219 Dual” from Jetson-IO?
$ sudo apt-cache show nvidia-jetpack
Version: 6.0-b52
Architecture: arm64
Installed-Size: 194
Priority: standard
$ v4l2-ctl --list-devices
/dev/media0
vi-output, imx219 10-0010 (platform:tegra-capture-vi:1):
/dev/video1
vi-output, imx219 9-0010 (platform:tegra-capture-vi:2):
/dev/video0
We reflashed the Jetpack to 5.1.3 and now camera is working without any problems.
With Jetpack 6.0 DP unfortunately for us it didn’t work at all. Tried different ways to use it but results were nothing.
We can confirm the issue: IMX-219 not detected on Orin-Nano with JP 6.0 DP.
Reverting to JP 5.1.3 solved this for us temporarily.
S.a. this thread: https://forums.developer.nvidia.com/t/jetson-orin-nano-not-booting-after-csi-reconfiguration/286567/14
