Execute 725:no cameras available
i am using jetson nano with os ubuntu 20.04 .i am trying to run imx219-200 camera module through csi port jetson but i am unable to do so. i am not able to even view /dev/video* .for v4l2-ctl --list-devices
NVIDIA Tegra Video Input Device (platform:vi):
/dev/media0
Cannot open device /dev/video0, exiting.
after inspection this is what i found
[ 1.313975] i2c /dev entries driver
[ 1.315575] i2c i2c-6: Added multiplexed i2c bus 7
[ 1.315872] i2c i2c-6: Added multiplexed i2c bus 8
[ 1.315876] i2c-mux-gpio cam_i2cmux: 2 port mux on Tegra I2C adapter adapter
[ 1.316456] imx219 7-0010: tegracam sensor driver:imx219_v2.0.6
[ 1.339750] tegra-vii2c 546c0000.i2c: no acknowledge from address 0x10
[ 1.339831] imx219 7-0010: imx219_board_setup: error during i2c read probe (-121)
[ 1.339902] imx219 7-0010: board setup failed
[ 1.339954] imx219: probe of 7-0010 failed with error -121
[ 1.340397] imx219 8-0010: tegracam sensor driver:imx219_v2.0.6
[ 1.346650] extcon-disp-state extcon:disp-state: cable 47 state 0
[ 1.346653] Extcon AUX1(HDMI) disable
[ 1.363667] tegra-vii2c 546c0000.i2c: no acknowledge from address 0x10
[ 1.363742] imx219 8-0010: imx219_board_setup: error during i2c read probe (-121)
[ 1.363797] imx219 8-0010: board setup failed
[ 1.363844] imx219: probe of 8-0010 failed with error -121
hello hydropericardi,
according to the logs, it’s system trying to register IMX219 camera device but has i2c communication failed.
had you validate this camera device before? please examine pin direction of your flex cable.
the camera is in working condition i have tested it before on jetson with another image .by pin direction if you mean to say blue coloured side of ribbon cable outward facing then i have done that the camera is still not working
may I know which sensor vendor it is? Jetson Nano support Raspberry pi imx219 by default.
it is raspberry pi imx219 -200 camera
may I also know what does this -200 represent? could you please share the webpage to the product?
we’ve test/confirmed Jetson Nano works with Raspberry pi imx219 on r32.7.4
please also share the L4T release version of your target. i.e.$ cat /etc/nv_tegra_release
furthermore, please also check waveshare IMX219 camera module around forum discussion thread.
for example, Topic 258404, Topic 239786, and Topic 212472.
content of nv_tegra_release
R32 (release), REVISION: 6.1, GCID: 27863751, BOARD: t210ref, EABI: aarch64, DATE: Mon Jul 26 19:20:30 UTC 2021
i am relatively new with kernel systems i am not able to understand if i need to makes changes to my device tree .following is my dts file .thank you for your assistance
dts.txt (324.0 KB)
jetson@nano:~$ sudo i2cdetect -r 2
WARNING! This program can confuse your I2C bus, cause data loss and worse!
I will probe file /dev/i2c-2 using receive byte commands.
I will probe address range 0x03-0x77.
Continue? [Y/n] y
0 1 2 3 4 5 6 7 8 9 a b c d e f
00: – – – – – – – – – – – – –
10: – – – – – – – – – – – – – – – –
20: – – – – – – – – – – – – – – – –
30: – – – – – – – – – – – – – – – –
40: – – – – – – – – – – – – – – – –
50: 50 – – – – – – 57 – – – – – – – –
60: – – – – – – – – – – – – – – – –
70: – – – – – – – –
thank you for your help i was able to run the camera .there was power issue.
