My Pi Camera v2.1 is not recognized by the Jetson Nano even though it is connected to the MIPI CSI-2 connector (I checked multiples times already). I tried both connectors without success.
I get this error when trying the hello_camera notebooks for CSI camera:
"ls: cannot access '/dev/video*': no such file or directory"
When digging a bit more into dmseg in can see those lines:
[ 1.245959] imx219 7-0010: tegracam sensor driver:imx219_v2.0.6
[ 1.269252] tegra-vii2c 546c0000.i2c: no acknowledge from address 0x10
[ 1.269333] imx219 7-0010: imx219_board_setup: error during i2c read probe (-121)
[ 1.269364] imx219 7-0010: board setup failed
[ 1.269426] imx219: probe of 7-0010 failed with error -121
[ 1.269809] imx219 8-0010: tegracam sensor driver:imx219_v2.0.6
[ 1.279114] extcon-disp-state extcon:disp-state: cable 47 state 0
[ 1.279116] Extcon AUX1(HDMI) disable
[ 1.293085] tegra-vii2c 546c0000.i2c: no acknowledge from address 0x10
[ 1.293161] imx219 8-0010: imx219_board_setup: error during i2c read probe (-121)
[ 1.293189] imx219 8-0010: board setup failed
I’ve seen a lot of post about the same issue (or very similar with for example imx219 6-0010 instead of 7-0010) but was unable to find a solution thus opening this one.
Hardware:
- Jetson Nano B-01 (the one with two camera connectors)
- Pi Camera v2.1 (official one, I verified already)
- MicroUSB cable as power supply
I don’t have a DC barrel jack power supply and use microUSB as my main power supply, could this be the reason it doesn’t work? (I’m using Jetson Nano in 5W mode and it works as intended)
