I have new Jetson xavier nx
SD card image was downloaded from https://developer.nvidia.com/jetson-nx-developer-kit-sd-card-image today (July 3 2020)
md5sum verified match 4b24e23867ed3d4b651934d0ac40c92c
sd card was flashed and system up running. But there is an imx219_board_setup error.
Messages generated from using command dmesg shows imx219_board_setup: error during i2c read probe
Here is the related details:
[ 1.995205] tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock
[ 1.995418] i2c /dev entries driver
[ 1.997726] i2c i2c-2: Added multiplexed i2c bus 9
[ 1.998271] i2c i2c-2: Added multiplexed i2c bus 10
[ 1.998277] i2c-mux-gpio cam_i2cmux: 2 port mux on 3180000.i2c adapter
[ 1.998719] imx219 9-0010: tegracam sensor driver:imx219_v2.0.6
[ 2.022179] tegra-i2c 3180000.i2c: no acknowledge from address 0x10
[ 2.022231] imx219 9-0010: imx219_board_setup: error during i2c read probe (-121)
[ 2.022276] imx219 9-0010: board setup failed
[ 2.022381] imx219: probe of 9-0010 failed with error -121
[ 2.022906] imx219 10-0010: tegracam sensor driver:imx219_v2.0.6
[ 2.046138] tegra-i2c 3180000.i2c: no acknowledge from address 0x10
[ 2.046184] imx219 10-0010: imx219_board_setup: error during i2c read probe (-121)
[ 2.046243] imx219 10-0010: board setup failed
[ 2.046364] imx219: probe of 10-0010 failed with error -121
[ 2.047709] max77620-power max20024-power: Event recorder REG_NVERC : 0x0
[ 2.054357] tegra-thermal-throttle bthrot_cdev: clk:cpu max:1907200000, min:115200000 steps:24
I can’t move on with my csi cameras.
What can I do?
Please help,
Thank you
[ +0.000368] i2c /dev entries driver [ +0.002496] i2c i2c-2: Added multiplexed i2c bus 9 [ +0.000607] i2c i2c-2: Added multiplexed i2c bus 10 [ +0.000122] i2c-mux-gpio cam_i2cmux: 2 port mux on 3180000.i2c adapter [ +0.003208] tegra-i2c 3180000.i2c: no acknowledge from address 0x10 [ +0.000195] imx219 9-0010: imx219_board_setup: error during i2c read probe (-121)
I’ve spent hours checking my pinmux, checking the schematic pinout connections. Generating device tree.
My camera ‘works’ but the video looks like it was taken from a 2001 mobile phone sensor. The quality is bad, but the best performance is with the resolution set to 1280x720. If you set higher, the quality gets much much worse.
My camera ‘works’ but the video looks like it was taken from a 2001 mobile phone sensor. The quality is bad, but the best performance is with the resolution set to 1280x720. If you set higher, the quality gets much much worse. Showboxjiofi.local.htmltplinklogin
