MIPI CSI issue (Imx219_board_setup: error during i2c read probe (-121))
Dear Nvidia Community,
I just bought an Nvidia jetson xavier nx platform.
The SD card image was downloaded from:
The sd card was flashed and system up running. But there is an imx219_board_setup error.
I can not use the MIPI CSI ports.
I have a Raspberry pi hq camera and even that does not work.
You can see the image below when I boot my platform.
It’s could be the HW connection problem cause the i2c failed.
Thank you ShaneCC for your message.
The external camera I want to connect has specific drivers.
I changed the camera cable and several times I connect and disconnect that but nothing.So, without installing the camera drivers it appears me the above message.
Also if i type v4l2-ctl–list devices it appears me:
Do I have to install something from the start. I am asking because I am new with that platform
Need to install the v4l-utils by sudo apt-get install v4l-utils
I did that and still the same message appears.
Need space after the v4l2-ctl like below.
v4l2-ctl --list-formats
ok now it appears me:
dask@dask-desktop:~$ v4l2-ctl --list-formats
ioctl: VIDIOC_ENUM_FMT
Index : 0
Type : Video Capture
Pixel Format: ‘RG10’
Name : 10-bit Bayer RGRG/GBGB
About the camera I use the Rasberry Pi HQ camera with IMX447 sensor. I had a contact with camera supplier and provided me the drivers:
but the same error appears me when I boot the platform. General is there a solution on that problem or it has to to only with HW?
Thanks for the consideration,
I also encountered this i2C problem, may I ask how to solve it in the future
Have you solved this problem? My Xavier NX also encountered the same problem as you when I started up again. Could you please tell me how to solve it if it’s convenient? ?
For IMX477 have apply below patch to try.
diff --git a/drivers/media/i2c/imx477_mode_tbls.h b/drivers/media/i2c/imx477_mode_tbls.h
index 9e66a0e..c3ba2fa 100644
--- a/drivers/media/i2c/imx477_mode_tbls.h
+++ b/drivers/media/i2c/imx477_mode_tbls.h
@@ -29,6 +29,7 @@
 static const imx477_reg imx477_start[] = {
        {IMX477_STANDBY_REG, 0x1},
+       {IMX477_TABLE_WAIT_MS, IMX477_WAIT_MS*3},
        {IMX477_TABLE_END, 0x00}
@@ -38,7 +39,9 @@ static const imx477_reg imx477_stop[] = {
 static const imx477_reg imx477_mode_common[] = {
        /* software reset */
        {0x0103, 0x01},
+       {IMX477_TABLE_WAIT_MS, IMX477_WAIT_MS*10},
