IMX477 OrinNX Custom Carrier Board
I am using Custom Carrier Board with Orin NX module and IMX477 Arducam when i install IMX477 driver it through error and when i install anything on my som with my custom carrier board it throught the same error when i install anything to the SOM but every installation works fine but still it through error “No dtb found” How to resolve this issue.
At the time of flashing i used this commands to flash orin nx modulw with custom carrier board
sudo ./tools/kernel_flash/l4t_initrd_flash.sh --external-device nvme0n1p1 -c tools/kernel_flash/flash_l4t_external.xml -p “-c bootloader/t186ref/cfg/flash_t234_qspi.xml --no-systemimg” --showlogs --network usb0 p3509-a02+p3767-0000 internal
please contact with vendor for further supports since you’re not using default Jetpack release image.
