@WayneWWW Trying to modify the kernel, pinmux, and the DTB files for the custom board.
These are the setups that i followed:
- Use the excel sheet and change the pinmux. I set many many of the unused pins (such as SPIs, I2Ss, etc.) to “not assigned”.
- Download the public _source zip from nvidia for 35.3.1 for Jetpack 5.1.1
- Modified the kernel dts files “tegra234-p3701-0004-p3737-0000.dts”, "tegra234-p3701-0000-as-pxxxx-p3737-0000.dts, “cvb/tegra234-p3737-0000-a04.dtsi” under
.../t23x/concord/
- Compiled the new kernel using
./nvbuild.sh
- Copied the compiled DTB and Image files to the
..../kernel/boot/
and..../kernal/
respectively - Copied the pinmux files to
..../bootloader/
- Created another config file to point to the correct pinmux and DTB files for the custom board.
- Run this command:
sudo ./apply_binaries.sh
- Run the flash command:
sudo ./flash <newconfig> mmcblk0p1
I’ve attached the modified DTSI files, pinmux files:
Orin-jetson_agx_orin-pinmux (Modified).zip (5.0 KB)
concord (modified dts).zip (76.9 KB)
These are the custom board differences:
- No OTG USB
- The USB 2 and USB 3 companion mappings are different
- No PCIe
- No Wifi M.2
- No audio (no I2S etc.)
- No cameras (mipi lines etc.)
- No SPI
- No power button, forced recovery button, (but there is a reset button)
- No fan control PWM and tachometer
This is the error I get when using the original OR newly compiled kernel with the new DTB file
[ 3.9757 ] Added binary blob_display-t234-dce_with_kernel_tegra234-p3701-0000-p3737-0000_sigheader.bin.encrypt of size 9303552
[ 3.9787 ] Added binary blob_nvdec_t234_prod_sigheader.fw.encrypt of size 294912
[ 3.9796 ] Added binary blob_bpmp_t234-TE990M-A1_prod_sigheader.bin.encrypt of size 1048000
[ 3.9800 ] Added binary blob_tegra234-bpmp-3701-0000-3737-0000_with_odm_sigheader.dtb.encrypt of size 140416
[ 3.9801 ] Added binary blob_camera-rtcpu-sce_sigheader.img.encrypt of size 166304
[ 3.9802 ] Added binary blob_camera-rtcpu-t234-rce_sigheader.img.encrypt of size 537952
[ 3.9804 ] Added binary blob_adsp-fw_sigheader.bin.encrypt of size 400960
[ 3.9804 ] Added binary blob_spe_t234_sigheader.bin.encrypt of size 270336
[ 3.9806 ] Added binary blob_tos-optee_t234_sigheader.img.encrypt of size 1064752
[ 3.9807 ] Added binary blob_eks_t234_sigheader.img.encrypt of size 9232
[ 3.9872 ] Sending membct and RCM blob
[ 3.9882 ] tegrarcm_v2 --chip 0x23 0 --pollbl --download bct_mem mem_rcm_sigheader.bct.encrypt --download blob blob.bin
[ 3.9889 ] BL: version 0.32.0.0-t234-54845784-57325615 last_boot_error: 0
[ 4.1880 ] Sending bct_mem
[ 4.4028 ] Sending blob
[ 4.4418 ] ERROR: might be timeout in USB write.
Error: Return value 3
Command tegrarcm_v2 --chip 0x23 0 --pollbl --download bct_mem mem_rcm_sigheader.bct.encrypt --download blob blob.bin
Failed flashing t186ref.
Here are some questions I have:
- If you change the DTS/DTB files do you have to recompile the entire kernel Image file? Or can i just get the DTB files and copy it while using the old Image file?
- Does the Image file have to be signed?
- Does removing the OTG USB service cause a flashing issue since it uses the same USB port for flashing on the dev board?
