"In L4T 35.1.0, how do I compile the kernel? My previous method of compiling the kernel was as follows:
make ARCH=arm64 O=$TEGRA_KERNEL_OUT tegra_defconfig
make ARCH=arm64 O=$TEGRA_KERNEL_OUT -j4
Compiling the kernel separately:
make ARCH=arm64 O=$TEGRA_KERNEL_OUT zImage
make ARCH=arm64 O=$TEGRA_KERNEL_OUT dtbs
In the R35.1 tutorial, the kernel compilation method is: ./nvbuild.sh -o $PWD/kernel_out.
Could you guide me on how to modify the default configuration and compile the kernel and device tree separately?"
你直接打開nvbuild.sh,把你不想build的部份註解掉就好…
使用nvbuild.sh,提示下面的錯誤信息:
nvidia@ubuntu:~/l4t/l4t_35_1_0/public$ ./nvbuild.sh -o ../kernel_out/001/
Building kernel-5.10 sources
make: Entering directory '/home/nvidia/l4t/l4t_35_1_0/public/kernel/kernel-5.10'
make[1]: Entering directory '/home/nvidia/l4t/l4t_35_1_0/public/kernel/kernel_out/001'
GEN Makefile
HOSTCC scripts/basic/fixdep
HOSTCC scripts/kconfig/conf.o
HOSTCC scripts/kconfig/confdata.o
HOSTCC scripts/kconfig/expr.o
LEX scripts/kconfig/lexer.lex.c
/bin/sh: 1: flex: not found
make[2]: *** [scripts/Makefile.host:9: scripts/kconfig/lexer.lex.c] Error 127
make[1]: *** [/home/nvidia/l4t/l4t_35_1_0/public/kernel/kernel-5.10/Makefile:633: tegra_defconfig] Error 2
make[1]: Leaving directory '/home/nvidia/l4t/l4t_35_1_0/public/kernel/kernel_out/001'
make: *** [Makefile:213: __sub-make] Error 2
make: Leaving directory '/home/nvidia/l4t/l4t_35_1_0/public/kernel/kernel-5.10'
好的,下面的錯誤是該裝什麽?
WRAP arch/arm64/include/generated/asm/mm-arch-hooks.h
WRAP arch/arm64/include/generated/asm/mmiowb.h
WRAP arch/arm64/include/generated/asm/msi.h
WRAP arch/arm64/include/generated/asm/rwonce.h
WRAP arch/arm64/include/generated/asm/serial.h
WRAP arch/arm64/include/generated/asm/switch_to.h
WRAP arch/arm64/include/generated/asm/unaligned.h
WRAP arch/arm64/include/generated/asm/vga.h
UPD include/generated/uapi/linux/version.h
HOSTCC scripts/dtc/dtc-parser.tab.o
UPD include/generated/utsrelease.h
HOSTLD scripts/dtc/dtc
HOSTCC scripts/selinux/genheaders/genheaders
HOSTCC scripts/genksyms/genksyms.o
HOSTCC scripts/selinux/mdp/mdp
LEX scripts/genksyms/lex.lex.c
YACC scripts/genksyms/parse.tab.[ch]
HOSTCC scripts/genksyms/parse.tab.o
HOSTCC scripts/kallsyms
HOSTCC scripts/sorttable
HOSTCC scripts/genksyms/lex.lex.o
HOSTLD scripts/genksyms/genksyms
HOSTCC scripts/sign-file
/home/nvidia/l4t/l4t_35_1_0/public/kernel/kernel-5.10/scripts/sign-file.c:25:10: fatal error: openssl/opensslv.h: No such file or directory
25 | #include <openssl/opensslv.h>
compilation terminated.
make[2]: *** [scripts/Makefile.host:95: scripts/sign-file] Error 1
make[2]: *** Waiting for unfinished jobs....
HOSTCC scripts/asn1_compiler
make[1]: *** [/home/nvidia/l4t/l4t_35_1_0/public/kernel/kernel-5.10/Makefile:1231: scripts] Error 2
