The camera video output is already rectified.
The distance on the apriltag detection is also off by like 30% when I am testing in the 0.5m to 2m range. The camera is also directly facing the apriltag. What might the cause of the error in apriltag distance? What are some ways I can try to mitigate this error?
I launched my camera by
zed_camera_node = ComposableNode(
package='zed_components',
plugin='stereolabs::ZedCamera',
name='zed_node',
parameters=[zed_config],
extra_arguments=[{'use_intra_process_comms': True}]
The config file:
# Parameters for testing ZED mini camera for SLAM
ros__parameters:
general:
camera_model: 'zedm'
camera_name: 'zedm'
grab_resolution: 'HD1080'
grab_frame_rate: 15
pub_resolution: 'NATIVE' # same resolution as grab_resolution
pub_frame_rate: 15.0
depth:
depth_mode: 'NONE'
object_detection:
od_enabled: false
advanced: # WARNING: do not modify unless you are confident of what you are doing
# Reference documentation: https://man7.org/linux/man-pages/man7/sched.7.html
thread_sched_policy: "SCHED_BATCH" # 'SCHED_OTHER', 'SCHED_BATCH', 'SCHED_FIFO', 'SCHED_RR' - NOTE: 'SCHED_FIFO' and 'SCHED_RR' require 'sudo'
thread_grab_priority: 50 # ONLY with 'SCHED_FIFO' and 'SCHED_RR' - [1 (LOW) z-> 99 (HIGH)] - NOTE: 'sudo' required
thread_sensor_priority: 70 # ONLY with 'SCHED_FIFO' and 'SCHED_RR' - [1 (LOW) z-> 99 (HIGH)] - NOTE: 'sudo' required
The launch file:
import launch
from launch_ros.actions import ComposableNodeContainer
from launch_ros.descriptions import ComposableNode
from ament_index_python.packages import get_package_share_directory
import os
def generate_launch_description():
apriltag_node = ComposableNode(
package='isaac_ros_apriltag',
plugin='nvidia::isaac_ros::apriltag::AprilTagNode',
name='apriltag',
namespace='',
remappings=[
('image', 'left_rgb8'),
('camera_info', '/zed_node/left/camera_info'), # already rectified
format_conversion_node = ComposableNode(
package='isaac_ros_image_proc',
plugin='nvidia::isaac_ros::image_proc::ImageFormatConverterNode',
name='format_conversion',
namespace='',
parameters=[{
'encoding_desired': 'rgb8',
'image_width': 1920,
'image_height': 1080,
remappings=[
('image_raw', '/zed_node/left/image_rect_color'), # input
('image', 'left_rgb8') # output
zed_config = os.path.join(
get_package_share_directory('drone_bringup'),
'config',
'zedm.yaml'
name='zed_node',
apriltag_container = ComposableNodeContainer(
package='rclcpp_components',
name='apriltag_container',
namespace='',
executable='component_container_mt',
composable_node_descriptions=[zed_camera_node, format_conversion_node, apriltag_node],
output='screen'
return launch.LaunchDescription([apriltag_container])
Thank you!
