So I’m trying to record a video using this camera, my problem is that the fps fluctuate way too much.
To record a video I’m using ffmpeg, this version to be more precise, since there’s no support for nvenc with ffmpeg. The script to make the recording is a very simple one and can be reduced to this pseudocode.
while True:
----cam.grab_frame()
----ffmpeg_recorder.write_frame()
I can ensure that the camera grabs 67 frames per second and the frame captured it’s always the last one. FMPEG is called inside a thread and a queue is used for communication. The camera captures a 2592x1944 image and FFMPEG is set up so it can record a 1080p@60fps video. In reality at best I can capture 1080@50fps with hevc_nvmpi, this is fine. By the way I’m using ffmpeg-python to control the pipeline.
If I could capture 1080@50fps that would be enough for me but like I said at the start the fps fluctuate a lot under the same parameters. In what I call “good runs” the NVENC frequency is set at 499MHz and doesn’t change too much, in turn I record at 1080@50fps. My problem is with “bad runs” in wich the frequency gets stuck at 422 MHz so I can only record at 1080p@30-37 fps.
Some additional info, at first I thought this could be a problem related to the temperature my Jetson, so I increased the fan power from 50% to 100% this didn’t change much. The power mode as seen with jtop is NV POWER[2] 15W 6CORE. The temperature never goes above 50 C and it fluctuates between 43-47C.
Is there a way to solve this?
