Hi Omniverse devs!
Thank you for putting together these forums – very cool to see what other people have been working on with omniverse.
Our team is trying to import the Fetch robot into IsaacSim based on its URDF defined HERE. We are able to import the robot using the URDF Importer extension, but it behaves very strangely when we try to articulate the robot.
Moreover, when trying to programmatically control the robot, it seems that trying to access the robot’s joint parent / child links via dc.get_joint_<parent / child>_body(joint_handle)returns inconsistent values – for some joints, it appears to return the flipped values – i.e.: calling the parent link actually returns the child link name, and vise versa.
This behavior can be easily reproduced via the following:
# Assumes fetch has already been imported to USD format from URDF
class HelloWorld(BaseSample):
def __init__(self) -> None:
super().__init__()
def setup_scene(self):
world = self.get_world()
# Import robot
add_reference_to_stage(usd_path=<PATH_TO_FETCH>.usd, prim_path=f"/World/fetch")
fetch_robot = world.scene.add(Robot(prim_path="/World/fetch", name="fetch"))
async def setup_post_load(self):
self._world = self.get_world()
self._fetch = self._world.scene.get_object("fetch")
self._fetch.set_enabled_self_collisions(False)
# Get joint info
dc = self._fetch._dc_interface
art = dc.get_articulation(self._fetch.prim_path)
n_joints = dc.get_articulation_joint_count(art)
joint_handles = [dc.get_articulation_joint(art, i) for i in range(n_joints)]
self._joints = OrderedDict()
n_dofs = dc.get_articulation_dof_count(art)
self.dof_handles = [dc.get_articulation_dof(art, i) for i in range(n_dofs)]
dof_names = [dc.get_dof_name(handle) for handle in self.dof_handles]
dof_count = 0
for i, joint_handle in enumerate(joint_handles):
# Here is the problem: Sometimes parent / child names are flipped, e.g. for joint shoulder_lift_joint, see attached screenshot of Fetch tree structure
name = dc.get_joint_name(joint_handle)
print(f"joint {i} name: {dc.get_joint_name(joint_handle)}")
parent_handle = dc.get_joint_parent_body(joint_handle)
parent_name = dc.get_rigid_body_name(parent_handle)
joint_type = dc.get_joint_type(joint_handle)
self._joints[name] = {
"handle": joint_handle,
"parent_handle": parent_handle,
"type": joint_type,
print(f"joint {i} parent name: {parent_name}")
child_handle = dc.get_joint_child_body(joint_handle)
child_name = dc.get_rigid_body_name(child_handle)
print(f"joint {i} child name: {child_name}")
I tried to upload directly the fetch .usd file I was using, but it’s apparently much too large (>800MB). I’ve instead uploaded it to google drive; the files can be downloaded HERE.
Any help would be greatly appreciated!
