I modified the “Hello World” Isaac Example to give the cube a mass of 1.0 kg and to add a RigidPrimView that I can call get_net_contact_forces() on, following advice from here. Gravity is set to 9.81 m/s^2, so the contact force should be 9.81 N. However 1.635e-01 N is reported by Isaac Sim. Code and output below.
class HelloWorld(BaseSample):
def __init__(self) -> None:
super().__init__()
return
def setup_scene(self):
world = self.get_world()
world.scene.add_default_ground_plane()
fancy_cube = world.scene.add(
DynamicCuboid(
prim_path="/World/random_cube",
name="fancy_cube",
position=np.array([0, 0, 1.0]),
scale=np.array([0.5015, 0.5015, 0.5015]),
color=np.array([0, 0, 1.0]),
mass=1.0
self._cube_contact = RigidPrimView(
prim_paths_expr="/World/random_cube",
name="cube_vew",
reset_xform_properties=False,
track_contact_forces=True,
prepare_contact_sensors=True,
world.scene.add(self._cube_contact)
return
async def setup_post_load(self):
self._world = self.get_world()
self._cube = self._world.scene.get_object("fancy_cube")
self._world.add_physics_callback("sim_step", callback_fn=self.print_cube_info)
return
def print_cube_info(self, step_size):
print(self._cube_contact.get_net_contact_forces())
