Is there a way to get friction forces?
I am obtaining contact forces using RigidPrimView.get_net_contact_forces(), but this appears to not include friction forces. Is there a way to get the friction force between a body that is in contact with the ground?
Hi @jake.levy - In the Isaac Sim, the RigidPrimView.get_net_contact_forces() function provides the net contact forces on a rigid body, which includes both normal and friction forces. However, it does not provide a direct way to isolate the friction forces.
Friction forces are typically calculated internally within the physics engine based on the contact normal force, the friction coefficient of the materials in contact, and the relative velocity at the contact point. This information is not directly exposed through the Isaac Sim API.
If you need to estimate the friction force, you could potentially do so by making some assumptions and calculations. For example, if you know the total force, the normal force (which can be calculated from the weight of the object), and the angle of the surface, you could calculate the friction force using the equation:
Friction Force = Total Force - Normal Force * cos(Angle)
Please note that this is a simplification and may not accurately represent the actual friction force, especially in complex simulations with multiple contacts and dynamic conditions.
Hello @rthaker - thank you very much for the reply. However, I do not believe RigidPrimView.get_net_contact_forces() is giving friction forces. Here is a little experiment I did to check (but please let me know if I am doing something wrong).
I modified the Hello World isaac sim tutorial as follows:
  • Set the mass of the cube to 1.0 kg
  • Apply a physics material to the cube with static and dynamic coefficients of friction of 0.5
  • Set the with static and dynamic coefficients of friction to 0.5 for the default ground plane
  • Create a RigidPrimView of the cube
  • Print the contact forces with get_net_contact_forces()
Here is the code:
from omni.isaac.examples.base_sample import BaseSample
from omni.isaac.core.objects import DynamicCuboid
import numpy as np
from omni.isaac.core.prims.rigid_prim_view import RigidPrimView
from omni.isaac.core.materials.physics_material import PhysicsMaterial
# Note: checkout the required tutorials at https://docs.omniverse.nvidia.com/app_isaacsim/app_isaacsim/overview.html
class HelloWorld(BaseSample):
    def __init__(self) -> None:
        super().__init__()
        return
    def setup_scene(self):
        world = self.get_world()
        world.scene.add_default_ground_plane(static_friction=0.5,
                                             dynamic_friction=0.5)
        fancy_cube = world.scene.add(
            DynamicCuboid(
                prim_path="/World/random_cube",
                name="fancy_cube",
                position=np.array([0, 0, 1.0]),
                scale=np.array([0.50, 0.50, 0.50]),
                color=np.array([0, 0, 1.0]),
                mass=1.0,
                physics_material=PhysicsMaterial(
                    "/World/Physics_Materials/cube_mat",
                    name="cube_mat",
        self._cube_contact = RigidPrimView(
            prim_paths_expr="/World/random_cube",
            name="cube_vew",
            reset_xform_properties=False,
            track_contact_forces=True,
            prepare_contact_sensors=True,
        world.scene.add(self._cube_contact)
        return
    async def setup_post_load(self):
        self._world = self.get_world()
        self._cube = self._world.scene.get_object("fancy_cube")
        self._world.add_physics_callback("sim_step", callback_fn=self.print_cube_info)
        return
    def print_cube_info(self, step_size):
        print(self._cube_contact.get_net_contact_forces(dt=step_size))
    async def setup_pre_reset(self):
        return
    async def setup_post_reset(self):
        return
    def world_cleanup(self):
        return
Now, when I load the cube in, start the sim, and let it fall to the ground, the reported contact forces are close to [0.0, 0.0, 9.81] N, which is expected for the cube at rest on the ground:
Next, with the simulation paused, I will set the y-axis linear velocity of the random_cube to 5 m/s:
Now, basic physics calculations assuming m=1.0 kg; mu=0.5; g=9.81 ms^-2; v0 = 5.0 m/s result in a change in y of 2.55 m. I let the simulation play out until the cube comes to rest and look at the y-position of the cube:
The cube stops at 2.507 m; close to our guess of 2.55 m. This should validate that friction forces are happening to the cube with a coefficient of dynamic friction of 0.5.
However, when I examine the output from get_net_contact_forces() while the cube was moving during the experiment, the contact force in the y-direction is still zero, while the expected force should be (mu)(m)(g) = 4.9 N:
This is what leads me to believe that friction is not being reported as part of the contact forces.
@jake.levy
You are correct. The current behavior of the get_net_contact_forces and other contact APIs do not include any frictional effects. We are in the process of including frictional components in the API for the upcoming Isaac sim release.
Hi @Milad-Rakhsha, has the frictional force been included in the lastest release?
Hello
not yet but it will be part of the next public release
Hi @Milad-Rakhsha , is there any way to get the frictional force in IsaacSim 4.2.0? Thanks!
Is this problem still being tracked ? I also reached this total force missing friction part problem. And I have identified the problem in the PhysX code. Will PhysX be updated to meet this requirement ?
@flm8620 That’s interesting – could you open a new topic with the details of what you found in the PhysX code? It would help NVIDIA triage this and give it fresh visibility.
For friction forces, use get_friction_data() – but note you need max_contact_count > 0 when constructing the view (the default of 0 disables it). The docs have a full example here:
The contact_force_example() at the bottom shows how to combine get_friction_data() and get_contact_force_data() to get total forces.
