I have inputted the 12V adapter to jetson nano accidentally, then it can not boot. How can I fix it?
If you have strong enough HW knowledge, you can check the power supply design of nano based on the P3449 schematic in DLC to find out which component is broken. Most likely the 5V load switch, U58, might be damaged. If you can not fix that, maybe you can try RMA.
