Inquiry about flashing Orin-X with Jetson
Dear NVIDIA Support Team,
I have an Orin-X chip that was originally running Drive OS. I would now like to flash it with Jetson. Could you please confirm whether this is supported, and if so, provide guidance or documentation on the correct procedure?
Thank you very much for your assistance.
Best regards,
No, this is not supported.
I’m happy to help you with your question!
However, I must point out that the provided context does not contain any information about flashing an OrinX chip with Jetson or Drive OS. The context appears to be a collection of documentation and guides for NVIDIA Jetson modules, including the Jetson Orin NX Series, Jetson Orin Nano Series, and Jetson AGX Orin Series.
That being said, I can try to provide some general guidance on the topic.
The OrinX chip is likely a custom board designed for NVIDIA’s Drive platform, which is a software development kit for autonomous vehicles. Drive OS is the operating system used on the Drive platform.
Flashing an OrinX chip with Jetson would require a different operating system and software stack, which might not be compatible with the original Drive OS configuration.
To determine whether this is supported, I would recommend checking the following:
  1. Compatibility: Verify that the OrinX chip is compatible with the Jetson software and hardware. You can check the NVIDIA website for documentation on supported hardware and software configurations.
  2. Flashing procedure: If the OrinX chip is compatible, you’ll need to find the correct flashing procedure for the Jetson software. This might involve using NVIDIA’s flashing tools, such as the NVIDIA SDK Manager or the flash.sh script.
  3. Documentation and support: Reach out to NVIDIA’s support team or check their documentation for guidance on flashing an OrinX chip with Jetson. They may have specific instructions or recommendations for this process.
In summary, while I couldn’t find any specific information on flashing an OrinX chip with Jetson in the provided context, I recommend checking the compatibility, flashing procedure, and documentation/support from NVIDIA to determine the correct course of action.
If you have any further questions or would like more information, please feel free to ask!
My understanding is that the Jetson AGX Orin module also uses the Orin-X chip. From a theoretical perspective, this would suggest it should be possible to flash Jetson software onto an Orin-X device. Could you please clarify if this is supported?
If it is not supported, could you explain the reasons why (e.g., BSP compatibility, software licensing, or hardware validation constraints)? Additionally, if I configure the Orin-X with the same peripheral hardware as the Jetson module, would it still not be possible to flash it with Jetson?
Thank you very much for your guidance.
AFAIK, Orin and Orin-X are different SKUs, the current JetPack SW can’t work on Orin-X.
Thank you for your previous guidance.
I have an additional question: if I purchase a Jetson AGX Orin module, as long as the eFuses have not been blown, would it be possible to switch between Jetson and Drive OS freely? Are there any specific precautions or limitations I should be aware of when doing so?
I appreciate your advice and clarification on this matter.
Best regards,
No, as previous comments, they’re different SKUs, thus the DriveOS also not able to flash and work on Jetson platform.
I noticed that the Jetson AGX Orin 64GB module is built with the Orin-X chip, which suggests that they share the same SKU. Based on this, I would like to confirm whether it is possible to switch freely between Jetson and Drive OS on such a module.
If switching is supported, could you please clarify whether the eFuse configuration would affect this process or impose any limitations?
Thank you very much for your assistance and clarification.
I don’t think this is correct, and don’t know where you got this informatioon.
I have replied this is not support.
