Jetson Orin NX module on Jetson Orin Nano Developer Kit
Hello, I plan on buying a Jetson Orin NX modules and placing it on my Jetson Orin Nano Developer Kit carrier board. What process would be involved so that I am able to use the Orin NX module, or is it simply swapping out the modules and running it as usual? is there a guide for this procedure?
thank you for your time
Yes, they’re pin to pin comptible, just be sure you flash the correct SW image for your Orin NX, you can refer to Flashing Support — Jetson Linux Developer Guide documentation (nvidia.com)
You need to re-flash the device before using it, but the flashing command for Orin NX and Orin Nano is the same:
https://docs.nvidia.com/jetson/archives/r35.4.1/DeveloperGuide/text/IN/QuickStart.html
