Regarding your response to my first message:
Before receiving your response, we had already attempted to eliminate the circuit differences between the original JAO/JAOi carrier board and the revised carrier board by removing all connected series resistors, pull-up resistors, pull-down resistors, and other related components. We retained only the GND connections for J62 and G5.
However, the same error persisted.
As an additional observation, on the original Orin carrier board, G5 is connected to the Ethernet switch for RGMII functionality and is not connected to GND. Nevertheless, MB1 booting on the Thor module completed successfully on this board.
SYS_VIN_SV becomes active immediately when power is applied to the board. Both carrier boards use the same circuit configuration and components for this supply.
VM_I2C is not connected to the carrier board on either design and is therefore inaccessible for external measurement.
Regarding the boot sequence, both boards use MCUs of the same part number to control the power-up sequence. We also tested both MCUs with the firmware exchanged between the boards, but the results remained unchanged. Furthermore, we observed no significant differences in the waveforms captured using an oscilloscope.
Regarding your response to my second message:
We had already implemented some of the suggested resistor-removal measures as part of our efforts to eliminate circuit differences. We applied the remaining measures as well, but the same error persisted.
We have now exhausted several avenues of investigation, yet the root cause remains unclear.
Our development schedule is becoming extremely tight, so we urgently need to identify the next steps.
Based on the findings above, are there any additional areas we should investigate? In particular, could you recommend any specific checks or diagnostic procedures to help determine why MB1 encounters an I2C timeout on the revised carrier board but works correctly on the original JAO/JAOi carrier board?
Any further technical guidance or assistance in identifying the root cause would be greatly appreciated.
Thank you for your continued support.
