I have been trying to install Cuda Driver & Cuda Toolkit on Ubuntu 14.04. I have downgraded from 16.04 as I had so many more bugs and problems.
I have tried to install from .run file, but it still says no kernel found for driver 304.29
I have downloaded cuda tool kit debian for 5 , 5.5, 6.5 and installed as follows:
$ sudo dpkg -i cuda-xxxxx.deb
$ sudo apt update
$ sudo apt upgrade
$ sudo apt install cuda
I doubt the last line of install cuda to be causing some discrepancies, but it seems to be my only choice.
Then I get Infinite Loenter code heregin Loop which I solve by :
$ sudo apt install nvidia-304
I login and run sudo make clean & sudo make or device query sample and I make sure I have the PATH with CUDA_HOME
$ nvidia-smi
Sun Apr 1 05:34:24 2018
| NVIDIA-SMI 4.304… Driver Version: 304.135 |
| GPU Name | Bus-Id Disp. | Volatile Uncorr. ECC |
| 0 GeForce 8800 GT | 0000:02:00.0 N/A | N/A |
| 30% 56C N/A N/A / N/A | 56% 284MB / 511MB | N/A Default |
| Compute processes: GPU Memory |
| GPU PID Process name Usage |
| 0 Not Supported |
$ nvcc -V
Copyright (c) 2005-2015 NVIDIA Corporation
Built on Mon_Feb_16_22:59:02_CST_2015
Cuda compilation tools, release 7.0, V7.0.27
$ ./deviceQuery
./deviceQuery Starting...
CUDA Device Query (Runtime API) version (CUDART static linking)
cudaGetDeviceCount returned 35
-> CUDA driver version is insufficient for CUDA runtime version
Result = FAIL
I have been in this error for ages, please help
