I am trying to install cuda-toolkit to my fresh ubuntu-15.10 . After reading the official instructions here http://developer.download.nvidia.com/compute/cuda/7.5/Prod/docs/sidebar/CUDA_Installation_Guide_Linux.pdf
lspci | grep -i nvidia
02:00.0 VGA compatible controller: NVIDIA Corporation G94 [GeForce 9600 GT] (rev a1)
uname -m && cat /etc/*release
x86_64
DISTRIB_ID=Ubuntu
DISTRIB_RELEASE=15.10
DISTRIB_CODENAME=wily
DISTRIB_DESCRIPTION=“Ubuntu 15.10”
gcc --version
gcc (Ubuntu 5.2.1-22ubuntu2) 5.2.1 20151010
I downloaded the cuda-repo-ubuntu1504-7-5-local_7.5-18_amd64.deb file and run the following commands:
Installation Instructions:
sudo dpkg -i cuda-repo-ubuntu1504-7-5-local_7.5-18_amd64.deb
sudo apt-get update
sudo apt-get install cuda
But when I try installing cuda I get that message
E: Failed to fetch file:/var/cuda-repo-7-5-local/./cuda-visual-tools-7-5_7.5-18_amd64.deb Hash Sum mismatch
E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
I tried apt-get update and everything updated correctly. With --fix-missing? I get
Unable to correct missing packages.
E: Aborting install.
Nvidia drivers under additional drivers section
Using NVIDIA binary driver-version 340.96 from nvidia-340(proprietary,tested)
If anyone has anything to suggest or if I did something wrong please help me I am new to Ubuntu as well to cuda . Thank you very much.
