Install SciKit in Jetson AGX orin
I have installed scikit with the following command:
pip install -U scikit-learn
I can import scikit in python scripts, but when I try to use this commands:
from sklearn.model_selection import train_test_split
din_train, din_test, dout_train, dout_test = train_test_split(din,dout,
test_size=0.2,
random_state=42)
The following errors appear:
Contents of /home/user/.local/lib/python3.8/site-packages/sklearn/__check_build:
init.py pycache _check_build.cpython-38-aarch64-linux-gnu.so
It seems that scikit-learn has not been built correctly.
If you have installed scikit-learn from source, please do not forget
to build the package before using it: run python setup.py install or
make in the source directory.
Just want to confirm.
Is your default Python version Python 3?
python --version
Yes, my Python version is 3.8.10
Should I follow instructions here?:
I have tried to follow the instructions there but the same error appears.
If i import sklearn before tensorflow, then the error disappears.
Thanks for the update.
Is changing the import order WAR okay for you?
It sounds like some compatibility problem between scikit-learn and TensorFlow.
Yes when I change the import order then no error appears. My current version of scikit-learn is 1.3.1.
