Installing Isaac Sim without Omniverse GUI
I am trying to install Isaac sim on a remote workstation and so I wonder if it is possible to install Isaac sim without launching Omniverse GUI? This workstation does not allow docker and so I need to install Omniverse and Isaac sim without using the container version.
Hi. You can try copy the Isaac Sim package folder from another Workstation that have Isaac Sim installed from the Omniverse Launcher or copy the /isaac-sim folder from the docker container then run it directly on this remote workstation.
Thank you, does this still require Omniverse launcher to be installed on the remote workstation?
You don’t need to install the Omniverse Launcher to run the Isaac Sim container.
In the container, the default is to pull assets from the Cloud but you can install a remote Nucleus for it to connect to.
