@Mahesh1305 is trying to use python 3.8.5 or greater versions for running my application. @Mahesh1305
has tried installing the libraries using apt-get, apt, and pip3. Is there any possibility to uninstall default versions?
Hi, @Mahesh1305
Since the default python in Ubuntu 18.04 is v3.6, not all the libraries will have a prebuilt for python 3.8 in the apt server.
So you may need to build it from the source for those libraries.
Does your use case have some dependencies on python 3.8?
Hello, @AastaLLL
Is there a way to build from source to use python3.7 or higher in jetson?
Thank you.
