Python & Venv on Jetson Nano
Hello.
In this guide will show how to get Python3.10 on jetson nano.
Also guide uploaded here
More guides here
This guide was inspired by How to Install Python 3.10 on Ubuntu 20.04 & Ubuntu 18.04
Installation Guide
[NOTE] You can build python without SSL, though pip won’t work.
Download & Build OpenSSL 1.1.1
cd /opt
border-leftsudo wget -O openssl.tgz https://ftp.openssl.org/source/old/1.1.1/openssl-1.1.1j.tar.gz
sudo tar xzf openssl.tgz
sudo rm openssl.tgz
cd openssl-1.1.1j/
sudo ./config --prefix=/opt/openssl
sudo make
sudo make install
Install Python 3.10.6
cd /opt
sudo wget https://www.python.org/ftp/python/3.10.0/Python-3.10.0.tgz
sudo tar xzf Python-3.10.0.tgz
cd Python-3.10.0
sudo ./configure --with-openssl=/opt/openssl
if you won’t use altinstall then it can replace your current version.
sudo make altinstall
Check python version
python3.10 --version
Personally I like to store python environment in the same folder with my project.
So let’s create it.
mkdir PyProject
cd PyProject
python3.10 -m venv ./venv
source venv/bin/activate # source venv/bin/activate.fish  (for fish shell)
Now normal python command should work, because we are in the environment.
python --version
and now we can upgrade pip
python -m pip install --upgrade pip
And to exit/deactivate environment we can just do:
deactivate
Thanks for sharing.
Hello, Just wanted to add thanks for posting this. I was stuck on this an entire day and your guide helped.
I did encounter an error due to not having zlib installed. I used the solution found here: software installation - Configure error: could not find the zlib library - Ask Ubuntu
cd /opt
sudo wget -O openssl.tgz https://github.com/openssl/openssl/releases/download/OpenSSL_1_1_1j/openssl-1.1.1j.tar.gz
sudo rm openssl.tgz
cd openssl-1.1.1j/
sudo make
sudo make install
updated instructions to build openssl, fixed an (i think) accidental border-leftsudo => sudo and the url has changed.
thanks for this! @luklevus
