Hello everyone,
I’m working on Jetson TX2 and trying to access it remotely using Teamviewer on both my host PC (in the Hause) ad the Jetson (in the company). As I first run the installation command, it returns with the following Error :
dpkg: error processing archive teamviewer_14.7.1965_amd64.deb (–install):
package architecture (amd64) does not match system (arm64)
Errors were encountered while processing:
So do I only need to look for a version that supports arm64?. If yes, can you please refer with the link. If you have any better suggestions of accessing the Jetson TX2 remotely, I’ll be glad to read.
Thanks in regards
