Teamviewer Host on Jetson Xavier NX
Hello! How can I install Teamviewer Host on Jetson Xavier NX? I am having trouble finding the version for the CPU Jetson Xavier NX uses and I have not found any solution until now. Thank you!
Not sure an arm64 build of teamviewer is available from apt. Only armhf (32 bits) may be available, and although it could work, it would probably be slow.
You may be able to rather use VNC.
Installing NoMachine (install ARMv8 deb package) would be also work and be easy.
Better configure your Jetson Ubuntu user to auto-login at first.
Thank you very much. I will try it.
