How to install TeamViewer Host on Jetson TK1
I use Teamviewer quite a bit on TK1. I wanted to share this with all TK1 users. Here are the steps to install TeamViewer Host on Jetson TK1.
Download teamviewer-host_armhf.deb
Copy over to TK1 through sftp.
SSH into Jetson to install deb package:
sudo dpkg -i teamviewer-host_armhf.deb
Resolve missing depends:
sudo apt-get -f install
Start teamviewer setup as root:
sudo teamviewer setup
Enter login info and confirm device in email.
Reboot for TeamViewer to run at startup.
ENJOY Teamviewer Host on TK1!
I’d be interested in a 64-bit ARM Teamviewer for TX1/TX2/Xavier. I’ve never found anything other than x86 versions. Do you have any advice on how to find ARM 32-bit/64-bit versions?
Hi, as of december 2021, were you able to finally remote using teamviewer? Or do you use some other tool?
Best regards.
