How to install TeamViewer?
Hi.
I installed Teamview on Jetson TX2 in the following way.
sudo dpkg --add-architecture armhf
sudo apt-get update
sudo dpkg -i teamviewer-host_armhf.deb
sudo apt-get -f install
sudo teamviewer setup
I have confirmed that Team Viewer installation is working normally.
But I tried to run it remotely with TeamViewer, but the mouse and keyboard did not work.
Why?
Hi kangil86,
For TX2 is aarch64, you can’t install “sudo dpkg -i teamviewer-host_armhf.deb” version.
Check teamviewer download center, I don’t find the file support aarch64:
https://www.teamviewer.com/tw/download/linux/
Hi. carolyuu
What is aarch64?
Is not this the toolchain that Ubuntu uses?
Is the toolchain compatible with Jetson TX2 only aarch64?
armhf is the older 32-bit ARMv7-a with hardware floating point (arm32). The TX2 is 64-bit ARMv8-a (arm64/aarch64). There is a compatibility mode armhf possible with the ARMv8-a processors, but one would have to install a lot of compatibility software for it to work, and the performance would be miserable. armhf is not compatible without a lot of modification, and I doubt that modification is available without doing a lot of cross compiling and customization.
